Hey W O T,
I thought I would respond to your inquiry since I got the idea as well from Empty V.
Here's my thread where I shared my pics
zer...enjoy
I got the bulbs from superbrightleds.com, which is the same place Empty V got them from.
For the climate control you will need 4 miniature wedge bulbs and for the clock you will need 2.
I have the part numbers for you....
For the clock, you will need 2 of these...
T1.5-x Instrument LED bulb 1-LED Instrument Cluster and Gauge illumination bulb. #74 type 100 degree wide angle LED bulb installed in twist lock socket base Select LED Color $ 1.79
For the climate control, you will need 4 of these....
NeoWedge Instrument LED bulb NeoWedge series 1-LED Twist Lock Instrument Cluster and Gauge illumination bulb - 2 lumenAvailable in 3mm - 4mm - 5mm sizes and five LED colorsSelect Size and LED Color $ 1.29
Now I'm noticing there are 3 different sizes and that I don't remember. I'm sure Empty V can tell you which size it is, I have the actual measurments at home. If you'd like, I'll reply again with the size.
Hope this helps.
