Andrew224 »
https://forums.nicoclub.com/andrew224-u74975.html
Tue Feb 17, 2009 10:00 am
I changed mine out about a month ago... Couple of tips...
The fuse thing is simple. Pull that fuse and the engine will run about 3 seconds (if that) and die out. Turn it over a couple more times and then turn the ignition off. Put the fuse back in.
It's kind of awkward to get at being above the rear axle. Use a pillow to prop you head up to keep from having to crane your neck the whole time.
With mine, the bracket holding it in place was severely rusted and the screw would not buge. Don't worry about it. You can just push it through from the driver's side to the passenger side.
After loosening the hose clamps you'll have to work them back and forth to get them off. I took a pair of needle nose pliers with a rag wrapped around the teeth to get a good grip (be careful not to damage the hose though!) and then carefully pried them off using a little leverage.
Take the rubber hose off the passenger side first (not much fuel comes out) and then the driver side (fuel will leak out at a slow but steady rate from the gas line and the filter, have a pan ready). You will get some gas on you.
Going back together is easier.
Truck should start up after turning over about 3 seconds.
Good luck.
Andrew
