01 QX4 steering wheel problem.
thaomyt
Car: 01 QX4, 08 Audi Q7, 08 Honda Odyssey
Hi,
I'm trying to figure out what cause my steering wheel to vibrate at high speed(50+ mph). I just had my tires balance and rotate, but it didn't help. I might try to have the wheels alignment, but I'm not sure it's gonna fix the problem.
fueler
Car: 2 Nissan's
2 BMW's
aftermarket or stock rims?
what tires?
thaomyt
stock rims with the Dunlop GrandTrek tires
fueler
Car: 2 Nissan's
2 BMW's
the problem you described sounds a lot like something in the wheels. Like bent rims... out of balance tires.... but it could also be something in the front drivetrain like the axles or front driveshaft?
gwhunt23
Car: 99.5 QX4
You need to read this TSB: http://www.gwcustom.com/mirror/ITB00-049.pdf
I've also heard of people replacing the front wheel bearings which also solved the steering wheel shake. See this walk through of an Xterra, it should give some good insight: http://rkrenn.com/xterra/howto/bearing/bearing.htm
Good luck!
