tsp84 »
https://forums.nicoclub.com/tsp84-u247101.html
Mon Jan 26, 2015 3:48 pm
*** DISCLAIMER *** THIS WILL ALLOW YOUR VEHICLE TO CRANK WHILE IN ANY GEAR. SO BE CAREFUL WITH KIDS IN VEHICLE AND ALSO WHEN WORKING ON VEHICLE.
Step #1 Remove #18 fuse from cabin fuse block
#2 pop hood and locate your fuse/fusible link box (right in front of battery), remove cover this means top and lower cover ( remove 12 mm nut on pos cable in fuse box to make easier removal of lower cover)
#3 strip some of the tape off of wires leading into fuse box so you have some length to cut and work with on relay wire
#4 cut the black/yellow wire that goes to #2 terminal on pnp relay cut as far away from relay as reasonably can to make wiring to constant ground easier but not so long that it's a nightmare to reattach to pnp switch wire when repaired.
#5 connect piece of new wire to ground, strip a bit of yellow/black wire coming out of relay and connect other end of new wire to this, solder or e tape it.
#6 replace #18 fuse with 10 amp
#7 start it up, as long as you have proper connection (ground going to pnp relay terminal 2) it will crank and not pop #18 fuse)
#8 check and confirm you can use 4x4 dial selector
#9 clean it all up and pat yourself on back.
Someone please enlighten me on how to add pictures, I have them just need to upload into post. Thanks!
