01 QX4 Speaker problem
toronto_qx4
Hi guys,
I just got a QX4 a couple of months ago and put in a USA Spec iPod adapter. I love the adapter and the sound, but lately the front passenger speaker has started fading out. I can correct this sometimes by cranking up the volume, and then returning it to normal. Other times it seems like both speakers on the door fade out or seem like they're not at max power--the sound becomes very tingy with loud highs but almost no lows. When this happens, sometimes I can fix it by engaging the power-locks. It's really weird. Does anyone have any ideas? Loose cables, broken amp? Thanks!
tresk21
Car: 2002 Nissan Pathfinder
Sounds like it might be the factory amp.... Aftermarket radio? If not, you might want to think about replacing the head unit and bypassing the factory amp. Is it a Bose system?
toronto_qx4
Yeah it's the original Bose system. It sounds great when it works, but I've got to say it's not the most sturdy. The CD changer broke years ago and so I spent a couple hundred bucks putting in a USA spec iPod connector. Now with the speakers, I don't know. If it's an amp problem, I might just let it go.
Is it true that the QX4 Bose systems have indivdual amps powering the speakers?
fueler
Car: 2 Nissan's
2 BMW's
toronto_qx4 wrote:Is it true that the QX4 Bose systems have indivdual amps powering the speakers?
Yes. in the front its a little one next to each speaker, in the rear its one larger amp hidden in the drivers side quarter panel. Heres a picture I took last week when i had my door taken apart (thats a JBL speaker though, not bose)
I bypassed the bose amps but never removed them from the door
Adnan
Car: 2001 Pathfinder LE 4WD
thats 1 heck of a fine speaker fuel
Modified by Adnan at 10:22 PM 9/19/2008
slickroger
Car: 2001 Nissan Pathfinder
i dont know but i like to troubleshoot from whats been done recently.
if the power locks seem to help you may have a bad ground.
are you sure its not the new Ipod Adapter you just added?
did the problem start when you got the adapter?
do the speakers play fine with CDs or the radio?
whats the
fueler
Car: 2 Nissan's
2 BMW's
Adnan wrote:thats 1 heck of a fine speaker fuel
haha thanks! it sounds pretty good, matched up with the JBL tweeters up in the factory locations.
