VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Tue Jan 17, 2023 9:22 am
Try tapping on the motor with a tack hammer and see if that starts it. If so you have bad brushes in the motor. If not, check for power at the motor when it misbehaves. If none, your Blower Relay has probably gone south (usually located on the back of the cabin fusebox). If both of those check out, Md is probably right and your VBC (resistor) is malfunctioning.
