01 QX4 - Engine whine problem
robins13
Car: 2001 QX4
I have a whine in the engine compartment that increases in pitch with the rpms. Can't pin it down. Any ideas. It seems to have become louder over the past 1000 miles. Thanks!
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
try checking your power steering
pathfinder9035
Car: 2001 Nissan pathfinder
i have the same whine too. when cold. I think it is either my alternator or somekind of pump.
SixGuns
Car: '04 Nissan Pathfinder SE 4x4
Probably pulleys...mine whine sometimes when they're cold, or after I've hosed down the engine bay - Prestone Belt Dressing for the belts and WD40 on the backsides of all the pulleys...works every time. I do it about every 5-6k miles.
robins13
Car: 2001 QX4
Thanks! I'll try it today and post the results.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
I wouldn't put WD40 on the pulleys. Seems like that would make it slip.
Have you checked the fan clutch? If it locks up, the fan spins full speed andwhines. If it is locked up, keep the rev down, you can throw a blade.
jetroy240
Car: S13, AE86
try process of elimination, remove one belt at a time & start the engine, could be alternator,idler pulleys, etc.
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
I going to ask just to ask but do you have an aftermarket stereo?
Billy
robins13
Car: 2001 QX4
No I don't - and my 6 disc changer doesn't work. Would like to replace it.
SixGuns
No, I'm not saying put WD on the belts - behind the pulley on the bearing side of the shaft.
Chuck Tribolet
'87 Chevy Corvette
SixGuns wrote:No, I'm not saying put WD on the belts - behind the pulley on the bearing side of the shaft.
WD-40 is not a lubricant. If you think you gotta lube there, I'd use a light oillike 3-in-one.
robins13 wrote:No I don't - and my 6 disc changer doesn't work. Would like to replace it.
Google around, there are folks who fix them. The usual failure point is a littlebit of white plastic. Or get an MP3 player and rip your CDs to MP3. I have aVR-3 VRFM8BLN which is a nice idea (it's a cigarette lighter plug that takesa USB memory stick with your tunes, and puts them on FM). But it has a numberof annoying attributes. This is probably a subject for another thread.
