01 QX4 Clock and HVAC Lights all out
sixty4
Car: 2008 QX56
1964 Lincoln Continental
Gone:
2006 QX56, 1998 QX4, 2001 QX4, 2000 I30
My clock lights and my entire heating and air conditioning control lights are completely out. I suspect a fuse as they both went out at the same time.
Anyone have any ideas? Hoping I can make it out there to fix it all today sometime.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Check Fuse #61. On an '01 PF, the illumination circuits are fed by it. Note thatit ALSO feeds the tail lights. If you blew a fuse, try to figure out why.
Also check the instrument panel brightness switch.
A third and less likely possibility is the tail lamp relay (it also feeds the illumination circuits).
sixty4
Car: 2008 QX56
Gone:
Thanks as soon as it stops snowing.. We just got done melting 20 inches, here we go again.
Northern VA/DC
sixty4
Car: 2008 QX56
Gone:
I found a 10AMP fuse under the hood that was labeled for "tail lights" replaced it still no luck, the lights are out still. How do I begin trying to locate the short if there is an issue?
Chuck Tribolet
'87 Chevy Corvette
Was the
sixty4 wrote:I found a 10AMP fuse under the hood that was labeled for "tail lights" replaced it still no luck, the lights are out still. How do I begin trying to locate the short if there is an issue?
Was the fuse you replaced blown? Do the tail lights work?
If the fust was blown, and the new one blew, you are looking for a short. Ifnot you are looking for an open.
Modified by Chuck Tribolet at 4:51 PM 1/30/2010
sixty4
Car: 2008 QX56
Gone:
Yes it kept blowing fuses.
However, I figured it out Chuck, thanks for your help. I checked both of the connections my toe bar is making into my brake lights, everything appears to be fine. I disconnected the power lead to the tow bar and my lights are back up.
U Haul tow bar has been on here for about 3 years without issue, I suppose they get to rewire it again considering their lifetime warranty.
Thanks again, saved my weekend!
