drob07 »
https://forums.nicoclub.com/drob07-u70494.html
Fri Apr 10, 2009 2:26 pm
Hey everyone. I love forums and I love how there is always something to learn. Thus, I am writing in hope that someone, or a collection of people, can assist me in this issue I am having with my beautifully made 2001 QX4.
I will do my best to describe this issue with you although I am not very knowledgeable with cars.
Symptoms: high/rough idlepoor gas mileage inability to accelerate at various speeds (seems to stall out and prevent me from accelerating even if i press the gas heavily) This is the big problem that I am currently facing because it makes driving a lot less safe.
Background: I have a local shop near Clemson, SC that does amazing work (protune ... please use them if you live near Clemson, located in Seneca). They are extremely knowledgeable and don't charge for things you don't need. I have used them several times with prior issues (such as replacing an o2 sensor). After an o2 sensor got replaced, the check engine light was NOT on. A few weeks down the road, the light visits me again and has not left. I dropped my car off for 2 weeks at protune to have a thorough investigation of the issue. The computer was sending lean codes which seemed to be the other o2 sensors. After those were found not to be the issue, the next potential cause was the fuel filter/pump. The filter was cleaned and the pump was replaced but to no avail. Next, they tried adjusting the Throttle position sensor and that did not cure the problem. I have heard from other sources that the mass air flow sensor could be the issue, but the shop said they tested it and found no problems. The shops recommendation, after giving it back to me with no answer and no bill , was to take it by an Infiniti dealer to have scanned and assessed. Now, we all know how that is the last resort with ANY issue regarding our car. Please provide any insight or experience that you may have with this situation. I desperately want to take care of this blessing of a car.
Dylan
