01 QX4 Busted Passenger Headlight
yakabod
Car: 2001 Infiniti QX4
My 2001 Infiniti QX4 (US) has been inactive for 2 months because of the stupid catalytic converter needing to pass smog. We finally repaired that and now my passenger headlight is not working. I start the car, turn on the switch and the passenger headlight flickers a few times and then turns off. The only I have checked so far was the fuses under the hood. Limited in tools right now, so i'll do more investigating tomorrow morning. You guys have any ideas on why it would flicker like this after turning on the switch?
I have NOT yet checked the relays or DRL module. Thanks in advance!
zach7685
Car: 2002 Infiniti QX4
2001.5 Nissan Pathfinder SE
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
1968 Mercedes 230-Sold
2005 VW beetle Convertible
2001.1 Nissan Pathfinder LE
Sounds like you need a new Ballast.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
You can swap the driver's side and the passenger side ballasts to see if the problem moves. If it does, you indeed require a new ballast.
yakabod
Where in the FSM can i see on how to change the ballast?
Towncivilian
See EL-34 - it's the "HID control unit". Apparently it's right next to the headlight assembly.
yakabod
Thanks for the quick response. Any idea on the rough cost of those puppies? And with my situation it would be pointless to check the relays?
yakabod
Also, if i were to go to the junkyard, i just ask them for the "HID Control Unit" for a 2001 infiniti qx4? or is this something i can buy from autozone/oreillys?
Towncivilian
This type of failure is common to ballasts, if I recall correctly. I'm not sure any aftermarket ballasts are available, at least I don't see any on RockAuto. I think OEM ballasts were ridiculously expensive last time I checked. I'm sure a junkyard would get the picture if you told them you were looking for a ballast.
yakabod
So my junkyards do not have this part. Looking through ebay and found a couple results.
http://www.ebay.com/itm/OEM-00-01-Infin ... 5c&vxp=mtr
I shouldn't risk this $30 one huh?
http://www.ebay.com/itm/D2S-D2R-D2C-HID ... 130wt_1141
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
http://www.ebay.com/itm/2001-2002-2003- ... 89&vxp=mtr I like this one because you have an extra bulb
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
Stick with the OEM like Zach posted- the aftermarket one you posted will require wiring modifications and just don't last as long as the OEM usually does.
The replacements are dealer only and super expensive.
I would check the bulbs first just to be sure, replacement bulbs are much cheaper than ballasts.
thaomyt
Car: 01 QX4, 08 Audi Q7, 08 Honda Odyssey
If you need a ballast, pm me. i have one that i took off from a broken 01 QX4 headlight (passenger side)
