nichols1992 »
https://forums.nicoclub.com/nichols1992-u118783.html
Mon Nov 03, 2008 8:01 am
Well there are'nt any shorts or opens, at least not in the a/c circuit. I checked the a/c relay to ecm circuit. With the engine running and the a/c switch on the voltage should be 0-1V, and it is. With the engine running and the a/c switch off the voltage should be 11-14V, and it is not. It's below 1V either way. I also checked the circuit for an open or short and there is neither, so I checked the high pressure switch to ecm circuit. Engine running and the a/c switched on the voltage should be 0V and it is. Engine running and the a/c switched off the voltage should be 5V and it is.So I'm assuming the computer either needs to be flashed or replaced. I can't flash the computer so I'm taking it to the dealer this afternoon. I spoke with the service manager and he's never heard of the problem either. With the research I've done on the web, posting on this forum, and talking to the dealer it does'nt appear to be common so I figured I'd give 'em a shot and hopefully all it needs is a good flashing.
