01 Pathy passenger high beam stopped working
fzrr
Car: 2001 Nissan Pathfinder LE
The other day I noticed the high beam on the passenger side of my 2001 LE Pathy had stopped working. I figured it was the filament in the bulb itself that was gone so I bought a new bulb. Swapped it out and found that it's still not working. Tried the bulb from the drivers side just to make sure and still no dice.
Now i've read a few threads on here about people having the opposite problem with the low beam not working and it being the DRL module. Would this be a similar thing if it's the high beam not working or should I be looking at the headlight stalk on the side of the steering column?
Any guidance on trouble shooting would be much appreciated as I'm a bit of an electrical noob.
Thanks
NismoPick
Car: 97 Infiniti QX4
00 BMW 528i E39
94 Geo Metro
87 Toyota Pickup
81 Datsun 280ZXT
Did you check the relays?
fzrr
Ended up getting a DRL module from the wreckers and swapped it out. It's all working OK now.
So yes looks like its the same issue as the threads on people's low beam stopping working.
