Toltec wrote:Hello,
I am glad i have found this site as I am looking for some answers. I just recently bought a used 2001 Pathfinder 4WD LE for my son and have recently got some issues with it.
It won't start, This just happened and here is what i have done so far. I have no noise when i turn the key to the start position, fyi.
I replaced the battery with a new one, did not start
Had a buddy come over and check the starter. After doing some troubleshooting we bypassed some things and hooked up a line to the + on the battery and onto the starter and it started. It still won't start the normal way but the starter is good.
The factory security light goes away when we move to the on position so may not be the alarm. So anyone have any other ideas, could it be the alternator, ignition switch. Not sure on how to proceed.
Thanks.
I have a 99 and the factory alarm is not hooked up to the ignition in any way. It is simply lights + horn + keyless entry.
I know because I have started and driven the car with the alarm blaring
On my 92 Pathfinder the ignition switch was at fault and that led to it not starting.
May want to check that.
GOod luck !
