'01 Pathfinder Fog Lights Not Working
johnhjohn
01 Pathfinder, fog lights not working. Have replaced both bulbs, swapped out the fuse and relay, still no luck. What would be the next logical place to check? Was thinking the switch, which is in the turn signal lever. Any ideas would be appreciated.
Thanks!!
John
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
johnhjohn wrote:01 Pathfinder, fog lights not working. Have replaced both bulbs, swapped out the fuse and relay, still no luck. What would be the next logical place to check? Was thinking the switch, which is in the turn signal lever. Any ideas would be appreciated.
Thanks!!
John
I am incline to agree. I had the switch go bad on my 01 which caused the headlamps to act up.
Billy
slickroger
Car: 2001 Nissan Pathfinder
if the switch isnt the problem than your going to need a multimeter to check the connections for power. One of mine had stopped working and it turns out a line was severed.
