NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Dec 01, 2005 4:08 am
I would stay in it. going past 120k will be a breeze. The pathy is very reliable. I assume you have the 3.5 in it? early 01 still had the 3.3 but in either case they are good running vehicles and have an excellent longevity. Your due for a good once over at 60K and again at 90 k. Make sure you get the trans fluid flushed and a coolant flush if you havent done so already. Other then that maint wont be all that high by comparison. If your a 3.3 engine your t-belt isnt due till 105K. The R50/R51 path is one of nissans higher quality vehicles from tht time frame.
