01 pathfinder 3.5 Is powerless above 3k
spooolin
Car: 1997 nissan 240sx
Hey guys I Just bought a 01 pathfinder with 160k on it and it runs and drives great. Only problem is it has No power above 3-3500 RPM. at idle and just driving the engine is super smooth and has No hesitation off idle.
I cant seem to figure it out. Im almost thinking somthing to do with the Varible valve timing or somthing.
I just sold my TT 96 300ZX because I decided I wanted a better daily driver.
The truck is a 01 with the 3.5L 5 speed manual and the check engine light is NOT on.. soo im lost guys lol can you help?
rwg550
Check out this thread on another forum:
http://x.nissanhelp.com/forums....html
When you get to the end, the guy's problem was a swirl control valve and actuator that were stuck closed.
Adnan
Car: 2001 Pathfinder LE 4WD
I had the excact same issue with my truck for a while nowfrom 4000 rpm-redline pretty much nothing would happenno vvt nothing!
By some miracle i filled her up the other day and on my homei gave it a little gas and it was working perfectly fine eversince :DI was guessing the problem was fuel related,possibly a fuel filter or some sorth but guess not :D
btw what causes the swirl control valve and actuator to stick?i cant click the link cause on the iphone
thanks!
