01 path wipers sizing
versa071979
Car: 07 versa
Does anyone here know if you can use 2 22 inch wipers together or must one be 21" thanks
2001 path le
versa071979
Car: 07 versa
Anyone
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
I suspect nobody's run the experment. We just do what the parts book says.
4xq
I have two 22 Bosch Marathons installed - the tip of the blade on the passenger side is 1/4 inch from the windshield trim and there is about 1/2 inch between the two blades . Snug fit, and in the winter, you must clear snow and ice pretty thoroughly.
But it does work.
versa071979
Car: 07 versa
Ok great because there are some really cheap deals on eBay for sets of 22"
dj_rice
Car: 240sx
pathfinder
As stated earlier, yes 22" on both sides will fit. Sometimes you don't have to go with what the manufacturer suggests. The easier way would of been to turn on your wipers and turn off the vehicle when they are at the top position and measure how much space you have on the top of the windshield and the bottom and then figure out the rest.
