01 Path le fan stuck on HIGH!!!!
Antndrew78
Car: 2001 Nissan Pathfinder le
ok I already read up on the amplifier and just ordered one my question is there another prt affecting this is there a resistor also that needs to be replaced because I was living with the fan on high and now it just quit the a/c kicks on but there is no fan at all please any info would be great thank s here is the part I just ordered http://www.ebay.com/itm/331906028493
yeldogt
Car: 02 Pathfinder 4X LE (X2)
The controller often results in no fan output .... that's an aftermarket part ... no experience. That's what the ACC controller looks like
attofarad
Car: 2001 QX4
No output can be the blower motor. But that doesn't seem all that likely, if it was running all the time on high before you replaced the control amp.
Here's my experience:
topic608593.html
Edit: I didn't see that you have not yet replaced the amplifier (also called "resistor" but is isn't really in these cars). They can fail in more ways than one. I expect it to be fixed when you put in that new amplifier.
Antndrew78
Thanks everyone for the info I orders the amplifier was lucky to find a new one on eBay for $39 shipped I installed and everything is working good as new
