Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Wed Feb 09, 2011 9:41 pm
I believe the wiring harness would identical, after all the FSM does not say anything specific about a Canadian instrument cluster. You should wait for others to chime in though.
I'm assuming you have auto climate control. I would believe that those harnesses are also identical; the only difference might be the firmware of the unit that differentiates the temperature system (F or C) used.
