01 Maxima; p0420 Check engine light ( cel )
AFelix
Car: 2001 Nissan Maxima
01 Nissan Maxima, P0420, any help would be great.
NISTECH
Hey Felix, ANother code huh? Did you have the ECM reprogramed when you had the O2 replaced? If you did you likely have a bad bank 1 cat convertor. Pretty common on the Max. If you are under I think its 70K miles it should still be convered under warranty here in california. If you didnt have the ECM reprogrammed then , There is a reprogram for that code as well. If you had it done with the O2 replacement then you recieved the updated program and the cat is probably no good.
