loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Jun 13, 2013 12:32 am
Ensure you don't have a vacuum leak nor problem with ignition. Normally, a faulty O2 sensor will generate a fault code. As for the MAF sensor, did you buy OEM?
The O2 sensor normally swings from 0.2V (lean) to 0.7V (rich) with mid-point of 0.45V (ideal fuel/air ratio). From the info you have provided, Bank 1 Sensors 1 (front) and 2 (rear) are reading very low with an average of @ 0.2V. This tells the ECU that you have a lean mixture and thus more fuel than necessary is being fed to the engine. I didn't see the voltage from Bank 2 sensors.
FYI, Bank 1 is the right side for cylinders 1-3-5 (towards the firewall) while Bank 2 is the left side for cylinders 2-4-6 (towards the radiator). There are 4 O2 sensors with front and rear mounted in the pre-cat (there is no sensor in the main cat, unlike the earlier Maxima/I30s). There are 3 connectors near the radiator (red, white and blue harness) and one connector (black harness) on the rear pax side near the intake manifold.
I usually go to IoS (Infiniti of Scottsdale) or Sparkplugs.com to find out the part number and pricing of the O2 sensors. The OEM Bosch sensors are expensive, usually over $100 so I use the equivalent NGK/NTK. You can also get it cheaper from Amazon provided you know the part number you are looking for and verify it fits your car.
