01 Maxima ABS lights are on after tire change
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
My son has an 01 Maxima, and it was running just fine, until he took his summer tires and rims off, and put on winter tires mounted on steel rims.Now he has all the ABS system lights lit up on the dash.ABS, traction control and whatever else is tied in to the system.I don't understand, so I'm wondering if changing out to steel rims can trigger or disable the ABS system? Any enlightenment would be grateful.It still runs fine, by the way.Thanks.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The wheels themselves shouldn't cause that.
Are the tire sizes staggered significantly?
mmatheny
Car: 1998 Infiniti i30
He didn't break the wire going to the ABS sensor did he?
marlin29311
Car: 2008 Infiniti G35x
If you put on wheels/tires that are vastly different than the OEM, than you will get errors from the systems, as they are based off wheelspin and rotation.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
As long as all 4 tires are the same rolling diameter, it doesn't matter what size they are, OEM or otherwise. The system looks for differences in rotation, but doesn't compare them against any OEM basis.
Buzzman
One thing that comes to mind after reading the responses is that he didn't check the tire pressures before mounting them.One tire was quite low, so he drove it that way to a gas station a few kms away, and then filled up all his tires to the same pressure. Maybe the uneven tire pressure triggered the fault.How long would it take to reset, or does he have to do it manually?The tires are all the same size by the way, very close to OEM size.Thanks again for your responses.
