01 max passenger window sloooooooww
daesonn
Car: 2k1 maxima, retired 94 maxima
In my 2k1 maxima I recently bought, it seems like the passenger side window just seems to get slower and slower, it slowed down so much tonight i had to sit and cheer it on to get past the middle of its travel. It seems to be fine after it gets 3/4 the way up, but other than that, slooooowwww. What to do?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
If it's only slow part of the way, it might just need to be lubed.
Pull off the door panel and apply white lithium grease to the track and move the window up and down.
maxhopper
Car: 02 Maxima SE 6spd
You could also try a silicone based spay lube in the window channels. If that doesn't help, it may be your motor going out, or the regulator binding.
daesonn
With the spray your saying I can spray it down where the window comes up from without touching the door panel? (sorry, i'm not sure how to explain that)
maxhopper
I'm talking about the channels that guide the side of the glass.
daesonn
ah so either way, i have to remove the door panel, there a quick guide to do this, just so i dont break anything?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There is a screw at the bottom of the handhold cup thing in the arm rest, and another at the upper front corner of the panel (which I believe is hidden by the dash when the door is closed). Remove those.
Then start at the bottom of the panel and pry away from the door. The panel is held in place with plastic clips that will pop out (and potentially break) when you pull. Once you've popped them all out and have all screws removed, the panel just lifts off. You may want to stop by the dealer and pick up a few replacement clips, but it's not really necessary. My driver's door is missing a couple but still sits firmly to the door.
A good tool for prying the clips loose is a flathead screwdriver wrapped in a t-shirt or other thin rag.
daesonn
thanks, but if i listen to you completely, I would have ripped half of my cords off my power windows and etc. lol. But thanks to the site, I read the guide and got it done pretty easily.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Oops, sorry. I forgot about the electrical connections.
