loystock wrote:So you have been driving the car in that condition for more than a month now. You have been given detailed instructions before to address your problems but looks like you haven't done anything. Unless you do something about it, you may have to say goodbye to your car.
Ignition Coil for Cylinder 1 is located in Bank 1, close to the firewall. pax side. It's on top of the engine (LH corner when facing it). Disconnect the connector (push in the green part to release the latch then pull it out). Then remove the mounting screw (better use a socket instead of a Philips screwdriver). Replacing this coil should not take you more than 5 minutes. However, it would be better to check the condition of the spark plug. If the plugs have more than 90K miles in them, it would be better to replace them all.
Yes, unfortunately my attempt in following the instructions was not successful, so I just have up on doing it myself, and I haven't had chance to get a mechanic get it fixed. Because, the one I usually brought the car to said he can't do such things as coil replacement.
I just often times don't understand some of the terms you are using here, and don't even know where to look for specific areas you are mentioning.(Also, English is not my first language)
It would be much more clear for me if the instructions were on a video or at least in images, so that I would know where all the things you are talking about are located. Otherwise, I will probably have to print all your suggestions and take them to a mechanic who will do the job for me.
When you said the car might die, which problem were you referring to? All of them or which particular one is the most dangerous that I will have to fix immediately?(I would assume its the coil problem)
P.SSo, I found a video on youtube(
http://www.youtube.com/watch?v=v-iM5_C9Vh0 )for 4th gen maxima coil replacement. So, the coil is the plastic stick that sits on top of the spark plugs? If that is what is I can definitely replace it myself because I have replaced the spark plugs myself on my previous car. Can I buy coils at Advanced Auto parts or Pepboys or Autozone(by the way which one of them has a better quality?) When I go to the register in the store what do I ask for?(coil or coil pack? what's the exact term) Also, should I buy spark plugs there as well as long as they are not from Bosch brand? Should I replace all the coils and spark plugs or just the one on the 1st cyclinder?
Also, is it easy to remove the engine cover?
Modified by axd1152 at 8:08 AM 2/12/2010
