01 I30 Sound System Doesn't Work Please Help.
94whitert
Car: 2001 Infinity I30
Hello everyone, I am new to the boards and new to the Nissan/infinity automobile.
I just bought a 2001 Infinity I30 and it has the factory bose sound system. The only problem is that The person I bought it off of had an aftermarket sub in the back and two amps. They were not included in the deal, so he took them out which is what lead to the disconecting of my sound system. I know nothing about sound systems, but would like to learn, and not take it to a sound place to get it fixed.
As of now, the car has factory HU, Speakers, But no AMP. There where no wires cut behind the head unit, just two small rectangle shaped small plastic boxes that were wired into the factory speaker wire coming out of the HU, which then converted into RCA wire that ran all the way back to the aftermarket Amps. Those are now removed so it is all factory at the head unit. In the trunk, aftermarket speaker wire was wired into the factory speaker harness, but the factory wires were cut so the factory wires were not sending current to the factory speakers. I wireback the rear two speakers, and they are very quite, which after a little reasearch lets me believe that this is due to no amp. My final question is. What do I have to do to get the Factory setup to work again. Do i just need to get a factory amp and wire it back in, or is it possible that the car did not come with a factory amp, since there does not seem to be a harness for the amp in the trunk, unless it was cut out which is a strong possiblity since the wire colors do not match up. I Will try to figure more tommorow, any input would be great.
94WhiteRT
94whitert
One more question. Are All Bose Amps interchangable between the 01-04 Maxima, and the 01-04 I30/I35. or do they differ by year, or Model(I30 or Maxima).
94WhiteRT
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO.
Here is the Electrical section of the FSM. Audio wiring can be found beginning on page 209.
As for the amps, I'm not sure from year to year, but ones from the same year should be interchangeable.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Maxhopper97,
No link.
If I remember correctly, the amps are built into the speakers themselves.
maxhopper
Dammit, sorry. I must have been sipping too much bourbon.
Here is the link to the Electrical section of the FSM. http://www.nicoclub.com/FSM/i30/2001/el.pdf
94whitert
Thanks for all of the imput, I pulled out the head unit, and all of the excess wiring that was in the car. from what I gather all of the stock wireing is there, so all I need to do is get a factory amp, and the wiring that runs from the amp into the wire harness. I was confused becuase there was aftermarket wire running to and from the hed unit. But when i took it apart, i saw that its was only connect to the factory wire, and did not replace the factory wire.
So does anyone have a factory amp, and the wires that come out of the factory amp.
NissanDriver84
Car: 1997 Nissan Maxima
In 2000 there was a amp attached to the rear deck shelf that was separated from the sub. When u open the trunk it's mounted to the right of the subwoofer. I think the amp used is the same from the years 2000-2004 so maybe you should try looking in a salvage yard or a junk yard for one that has been wrecked, has flood damage, etc.
