01 I30 Fuel Filter
blazncypher
Car: 01 I30
So does this car have a fuel filter? I have been reading all kinds of threads on here and the org. and everyone seems to have a different opinion. If I do have a fuel filter I think it needs to be changed (sluggish performance, horrible gas mileage, etc.) and if I do have a fuel filter where is it located and how do I change it?????? thanks
DevonD
Car: 96 Nissan Maxima SE
Yes your car has a fuel filter. If you plan on keeping this car you should go out and get a work manual for it. Haynes has one and others do too. The Haynes one is pretty good for the "do it yourselfer".
But the Fuel filter is mounted on the firewall. near the brake master cylinder, just lower down. Its a silver canister that will look like this.It is very easy to change and you should be able to do it in 20 min our less. http://www.autopartswarehouse.....html
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
of course you have a fuel filter. on 95-99 maximas it's on the right side of the firewall so look there. some cars have them mounted underneath on the frame rail. i don't know about yours but i bet it's still inside the engine compartment.
allensteiner
**** son...you're ****ed. it's not on the firewall but in the fuelpump assembly inside the tank. here's the fsm: http://www.nicoclub.com/FSM/maxima/2001/FE.pdf
DevonD
Yep your right Allensteiner.. I just thought in 01 since they were still using the same VQ30 in the car that not alot of that stuff would have changed. That sucks man! I read a thread on here once on how to change it in an 03. Looks like the same settup. The seat slides out of some clips and the pump should be right there under the seat. goodluck!!!
blazncypher
Car: 01 I30
im gonna do it this weekend i will let you all know how it goes. btw allen i got 245/35/19 and have seen a signifigant decrease in gas since i got them. have you had any issues with your tires?
DevonD
I have 245 on my 18's and yes I have as well. some people have comented that their car has had a really hard time keeping an alignment after they got bigger wheel/tire setups but mine have been fine. just poorer gas mileage.
allensteiner
issue?...if you call the car drifting uncontrollably when one wheel hits a rut...yes they sure drive diferent but handle a lot nicer when cornering. as for the mileage my odo is broken so i can't figure out what i get. i just filled up and drive 25 miles to work and back one day so i'll just have to see how many days i get out of a tank.
19's, wow. i got 245/45/17 so 2" smaller - that might be your fuel loss too. did you get bigger brake rotors? i noticed it's harder to slow down than with stock 205/15".
got pics?
allensteiner
dev...i think they have the vq35 in them. not sure but pretty close to.
DevonD
Well yeah but blazncypher is saying hes got an I30...Not I35. It got the 3.5 in 2002 I believe...
Mike G
Car: 2001 Infiniti I30
blazncypher wrote:im gonna do it this weekend i will let you all know how it goes.
Do tell, mine is in need of this as well. I figure it looks to be about an hour or so job. Just right for a little afternoon challenge...--Mike
allensteiner
you're right. it's called i30 because of vq30 and i35 because vq35.
DevonD
yup Infiniti throws the engine size in the name of the car. Hence the FX34/45, G35, QX56..etc..
blazncypher
Car: 01 I30
got pics?[/QUOTE] I got some older pics on cardomain same user name.
allensteiner
nice rims man. i'm gonna stick with 245/40 because 245/35 are about $150/piece.
blazncypher
Car: 01 I30
Yeah they are super dope they turn heads everywhere I go. True 3 Piece wheels let alone Lexani is def a head turner, it just suck that they are so heavy, have had some issue with brakes, gas, alignment, etc. I guess thats the price you pay to look good. I got my car lowered now with projector headlights and a lip spoiler and clear fronts so it looks real clean.
blazncypher
Car: 01 I30
They are for sale also $1500 for the set and tires.
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
Here is a how to link its for an 2k2 but I think it's the same or close to the same set up. Good luck though it looks kind of tough.
http://www.innerbean.com/housecor/fuel_filter.html
