PapaSmurf2k3 wrote:Reading your whole thread, I kept thinking "vacuum leaks", but I guess you checked that.
There's no obstructions or kinks in the line going to the IACV is there?
Negative. I checked that and found it was clear. I did read about a knock sensor wiring issue. Now I did not mention I had a code for the KS as well... I did not think it would relate it any way shape or form... however i think it may. The only two codes I had were the iacv and the ks...
Upon reading another thread I saw there was issues with the shielding of the KS sensor wire grounding out and causing a short... I looked into the wiring some more and found that the iacv wiring was showing continuity in one another at both the plug and the ecu. I found continuity between other wires as well leading me to believe that there is a short somewhere...
I decided to depin the iacv plug and the wires for it at the ecu and with some extra wrecked harnesses I made a direct harness... by doing this I believe I have eliminated the ecu as a culprit due to two reasons...
First when hooked up to the diagnostic software it shows the iacv output... second with the iacv direct with my sub harness the code is gone....
Now with that said the idle is unchanged... the iacv does not make any noise prior to KOER as stated it should in the FSM... mind you the iacv is brand new but I'm thinking that it may have shorted to fault.
I don't remember off the top of my head but is the iacv always open and controlled to close or always closed and controlled to open?
Now with this subharness the iacv code is gone as I stated... but now low and behold I have a new code, because what would diagnosing be if it were easy and you solve one problem, you solve em all.... code for MAF sensor popped up now...
pisses me off because without going through the flow chart and just seeing the voltage on the diagnostic software it is within range..... at 2500 since I can not get the idle to drop...
Only thing i have done to see the outcome is I've pulled the vacuum line on the diaphragm that pushes the throttle slightly and taped up the iacv opening on the filter side and it idles pretty well... however obviously is not the right way to get this idle down :p
Any ideas? I'm leaning towards a shorted engine harness, possibly from the damn power steering fluid leak on this pos...
Is the engine harness standalone to the ecu? I didnt notice any plugs to disconnect it at the firewall so I'm guessing so and what a b**** it will be to pull out.
