JohnCampbell08 »
https://forums.nicoclub.com/johncampbell08-u205017.html
Sat Jun 02, 2012 12:50 pm
Hello everybody, I have a 00 Q45 145k with a few small issues (hopefully small).
The car runs perfectly at times, and then all of a sudden, it feels like a misfire. There is a pretty serious studder when accelerating, and the idle is rough with small amount of jerking. The wife said that the traction control light and slip light came on once before, but did not come on since I cleared the codes the first time. And the second time it was running bad like this, the lights did not come on.
I pulled 4 codes :
P0340 Cam Position sensor
P1320 Ignition system or misfire
P0400 EGR Valve
P0325 Knock Sensor 1
My research has shown me that the CPS is pretty serious, and can be causing these problems. But I cannot find a DIY yet...I will keep looking.
I was reading that the ignition system code could be related to a coil, but how can I narrow down the search? I don't want to overhaul every single coil, esp if my problem happens to be due to the CPS or other.
The EGR valve is mainly for emissions....for the sake of this thread, we can ignore this issue for now, since all I care about is having the car running right, and then I can chase down the gremlins.
I have been reading that the knock sensors are very common issues with these cars, and I am sure mine could be due for them. Could the other problems such as the misfire throw the code for the knock sensor though? So in other words, my knocks could be working fine since they are reading that the car is misfiring?
Since I have not worked on Infiniti before, I would usually start with trying to correct the CPS first. Hopefully this could be causing my misfire, bad idle, and sluggish acceleration? Could it also be causing the ignition code and the knock code?
Car recently drove on a long road trip with no issues. Back in town for about 2 weeks, and then this happens.
LAST THING, this temperature sensor is driving me crazy. The needle jumps up and down with every gas pedal movement, sporadically, with no rhyme or reason. Are these common issues with these cars?
Thanks for everything in advance!
