00 Q45 fog light question
Y33 CIMA
Car: cars
does anyone know how to wire the fog lights to turn on without having the headlights turning on at the same time on 99-01 Q45? Thanks in advance.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I have been trying to do this for a while, and if you find something let me know.....
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
metoo - BTY anyone have after market fogs saw a bunch for $50-100 at jc whitney but a local shop told me to stick w/ factory cause the aftermarkets can not take the beating. there is a Q in my area licsence plate # 1 fast Q who has aftermarket retangular/oval blue ones that look sweet. i took out my fogs when i installed the HID headlamps was gonna pit wire mesh in holes>
97Q45t
Car: Viper RT/10, Ford Explorer 4WD
That because of the fog light relays are connected to the Positive power pin on the low beam but not the battery. Now if you cut that wire (fog light relay power wire) and connect it straight to +12V source then the fog lights will be on whenever you turn the fog light switch on.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
97Q45t wrote:That because of the fog light relays are connected to the Positive power pin on the low beam but not the battery. Now if you cut that wire (fog light relay power wire) and connect it straight to +12V source then the fog lights will be on whenever you turn the fog light switch on.
Wouldn't one want a fuse on that direct line?
97Q45t
Yeah, add a fuse also. 20A or 25A is good.
jamesmost
do u know where the relay is located in a 95Q
