00 QX4 Not starting
cjsmith0703
Car: QX4
Hey. Last week I bought a 2000 QX4 from a friend. I’ve drove it since then. This morning, I went out to crack it up and nothing happened. The lights/gauges came on when I turned key over, but when I kept turning the key, nothing happened. No noise, nothing. What should I check? Thanks
PapaSmurf2k3
Site Admin
A jump start would rule out any battery issues. If you hook the cables up and it still doesn't start, its most likely your starter that has gone bad.
cjsmith0703
Car: QX4
I hooked up my multimeter when I got in from work today. Battery showed 12.3v . From what I know, it should at least be 12.6, right? Thinking about just going to get new battery tomorrow. Every time I’ve had a starter problem, it’s alwats clicked. This is giving no noise. I noticed the displays were dimmed today too.
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
12.3V battery is not necessarily bad until its load test indicates so.
cjsmith0703
Car: QX4
Ok thanks. I’m going to take it in the morning to get tested
PapaSmurf2k3
Site Admin
QX4ME wrote:
Fri Dec 29, 2017 6:43 pm
Bingo.
Also, make sure your terminals and cables aren't corroded or anything.
AlanAZ
Car: 2003 Infiniti QX4 RWD
I don't know the differences between a '03 and a '00, but a failed starter relay would give those symptoms.
cjsmith0703
Car: QX4
I went and got a new battery first thing this morning. Put it in but still no luck getting it cranked. Lights came on and all gages, but still no noise when I tried to turn it over. Only noise I heard was a clicking in the dash when I turned the key. Any other ideas of what it could be?
QX4ME
11 MB C300 Sports
06 Honda Odyssey
I think battery + terminal has two wiring cables, one goes to starter through a fusible link(?) the other goes to rest of other things. Have you checked the fusible link see if it's open? My next guess is the bad starter or bad starter connection.
cjsmith0703
Car: QX4
Where is the starter relay located? I tapped the starter with hammer and it did not help anything.
QX4ME
11 MB C300 Sports
06 Honda Odyssey
Somewhere in this forum you can find factory service manual (FSM?). It should help you a lot. Could starter relay be under the hood in one of the fuse boxes? Or could it be the relay you said you can hear behind the dash when you turned the key?
AlanAZ
On an '03, the starter relay is a relay box on passenger side behind battery. If you hear a click there, the relay is good. No clicks, the relay could be bad.
PapaSmurf2k3
Site Admin
Most likely the starter itself.
Did the battery actually test bad and that's why you replaced it?
Here's FSMs:
www.nicoclub.com/fsm
cjsmith0703
Car: QX4
The guy at Auto part store said the battery was swelling pretty bad so I went ahead and got one. The relay must be different in the 00. I’m not seeing it anywhere in the fuse box behind battery. No click noise there. It’s coming from the one inside the car
cjsmith0703
Car: QX4
http://s1274.photobucket.com/user/cjsmi ... 9.jpg.html
Hopefully that link worked. Could it be the terminals? They are pretty disgusting. Battery has power though as it turns everything on, just does nothing when I turn key
QX4ME
11 MB C300 Sports
06 Honda Odyssey
If the pictured terminals are what you have now, that is so terrible. 12V will drop a lot t the starter side due to the high contact resistance. All other electrical stuff take much lower current so they are okay. Treat both terminals and cable clamp (so called?) with battery terminal brush, put them all the way down to maximize the contact area, screw them on tight, and coat them with vaseline or special terminal spray to prevent corrosion.
Hope the starter is good.
cjsmith0703
Car: QX4
I just did that. I cleaned the mess out of them. Still turned the inside stuff on but no crank, just the clicking. I may be taking off the starter and taking it to get tested. That just looks like such a pain
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
maybe try applying power directly to the starter before removing it to see if it will crank.
cjsmith0703
Car: QX4
How would I do that on this car? Starter is located underneath and not really easily accessible
cjsmith0703
Car: QX4
I rememeber that the service engine light was on before I parked it. Would it benefit to buy computer to pull codes? Will it still read it without cranking? If so that would help greatly bc I really don’t want to keep spending on parts
cjsmith0703
Car: QX4
Does anyone know what the relays are above the fuses in the cabin box? I’ve figured that is where clicking is but I cannot seem to find any diagram to let me know what those relays are for.
04pathse
cjsmith0703 wrote:
Sat Dec 30, 2017 6:02 pm
Yes, definitely get the code or codes that present, you do not need to be able to crank, just need to turn ignition key to "run" to get the codes.
04pathse
cjsmith0703 wrote:
Sun Dec 31, 2017 12:05 pm
The clicking you are hearing is most likely the "ignition" relay
page EL-341 is engine, bay page EL-342 is cabin
http://www.nicoclub.com/service-manual?fsm=QX4/2000/EL
cjsmith0703
Car: QX4
Thanks. I was having trouble finding that and the FSM was a huge help. I will check that out. Is it possible to check with multi meter?
cjsmith0703
Car: QX4
Have not had much time to mess with it today. I did get code reader and it read P-1605 that comes up transmission communication I think? I can hear fuel pump but nothing else. I felt the relays and the accessory relay was the one that was clicking. I could hold it while turning key and felt. The others did nothing I think.
From a quick glance of web, does not look like the p1605 code should not keep it from running
cjsmith0703
Car: QX4
SOLVED!!! So I posted earlier about pulling code and getting P-1605. After that I decided to just brave the cold and go check the a/t fuse. I checked it yesterday but it was not blown. I just decided to switch that 10a fuse anyways since I had some extras. Car cranked right up after that! Hopefully that’s it and there will not be anything else. It’s a 2000 with 240 Miles so will prob be back soon hahha
04pathse
Did you say you checked all the fuses in the cabin fuse box?
This person had a similar issue but on a 2000 Frontier which are very similar to the Pathfinder and QX4 and it turned out to be a blown Engine Control Fuse (10Amp). He was also getting the P1605 code.
https://www.youtube.com/watch?v=9bqiFsv_Q7E
