loystock wrote:Start with checking the level and condition of the transmission fluid. A transmission flush is highly recommended. However, if your car has >85,000 miles on it and has no record of transmission service, most shops will refuse it due to liability issue. Your other option will be to do a pan drop, clean the pan and magnets, check/replace the filter then install new gasket followed by multiple drain and refill.
You may have problem with sensors/switches so it would be better to get a free scan from Autozone and the likes and get a printout of the trouble code, if any.
Loystock i really appreciate you took some time to give me some advice, thanks a lot!
Now i can start my process of elimination, i'll be taking it in to a shop this weekend.
again, THANKS for the help
