carnal_c30 »
https://forums.nicoclub.com/carnal-c30-u10930.html
Mon Mar 10, 2008 4:23 pm
2000 Infiniti QX4 4wd Automatic 178k miles
Preexisting condition- Needs a tuneup bad (Cyl 3 misfire fouled plugs)
The QX was idling and stalled, and failed to start afterwardsIt did start the next morning yet only stayed on for a minute before shutting off again and refusing to start again.
It turns and seems like its about to start but just doesnt make it.
Fuel pump is priming, starter is turning, and charging system power is there
there are two CEL codes- Cyl 3 misfire and P0340 camshaft Pos sensor came on later
There is spark and then when its tested later there is not spark, its kind of odd
Ok, now I know I need to start off with the cam pos sensor, but anyone have some other ideas of where this can lead? possible a crankshaft pos sensor, bad MAF, etc?
thanks
