00/01 Qx4Nav.,Stereo,Climate Control,CD
BrettShannon
Car: Infiniti QX4
My girlfriend has a QX4, she is the original owner. The car has 77,000 miles, and the stereo, navigation, climate control is not functioning. I want to replace the unit, and am having difficulty finding one that matches. Please help.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO! Sorry to hear that your girlfriend's truck is having trouble.
You may not know this, but we have an incredible SEARCH feature on this forum. Please take a moment to read through these threads:
So it's finally time to replace my stock headunit
2001 QX4 head unit replacement inquiry
Any luck checking eBay for a used one? Also try your local salvage/junk yards.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Found one on eBay for you, but it is missing some buttons and has an issue according to the listing.
http://www.ebay.com/itm/QX4-Navigation- ... zq&vxp=mtr
atraudes
Car: 2001.5 Infiniti QX4 4WD
For the stereo, you can locate replacements on eBay pretty easily for <$100, though I'd recommend just buying a new one. You'll get better sound and more options for probably less money.
The navigation is a little trickier. You didn't say what exactly was going on with it, so I'm going to assume it's missing some critical buttons or is completely inoperable.
If you're a DIYer and looking to delete or install an aftermarket navigation, you can use the information in this thread. Since the navigation has the climate controls built in, you'll need to rewire things a bit to accommodate the climate controls from a non-navigation version of the QX4/Pathfinder. Reading through that thread is recommended regardless so you have an idea of the situation of things.
The second option is to locate replacements and simply swap out the bad units for some working ones. The navigation units are hard to come by, usually quite expensive ($800+), and are generally going to be missing one or more buttons. I have one for sale here if you want to go that route. Just be warned that any used unit you buy may start losing buttons at some point as well.
The last option is to send it to a repair place (the dealership can do this) and have it fixed, but it's going to cost multiple thousands of dollars to do so. For that you could bring it somewhere and have them do the aforementioned rewiring and have a top-of-the-line aftermarket navigation put in.
Sorry to be the bearer of bad news. Factory navigation units like these turn into huge white elephants as the car ages. Let us know what you go for and how it works out!
BrettShannon
Car: Infiniti QX4
Thank you all for your responses. I will read the recommended posts, and go from there. I will probably use the ala carte method and mix and match. More to come......
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
What altraudes said.
This is why I hate it when car manufacturers integrate everything together. One thing breaks, and you're having to replace more than what's necessary. And with all the new dashboards, that stuff is so integrated you can't even install an aftermarket radio. Good luck, and don't forget about the FSM here at NICO!
