0 gauge wire run by ecu ok?
Post all your Nissan electronics, car audio and stereo questions here!
onosqv
Car: '92 240sx Vert
Is it ok to run a 0 gauge wire on the passenger side next to the ecu? Or will that cause interference or something?
Thanks!
xekushnr
Car: '90 Nissan 240SX Hatch
i dont think you would have a problem. dont run RCAs down that same side though, or else you will get lots of noise.
onosqv
Car: '92 240sx Vert
Ah yes, no rca's near power wires. Ok, cool - just wanted to make sure that situation didn't apply to ecu.
Thanks!
kamikazestorm420
my rca wire runs right next to the power wire and i have yet to have any noise issues tho
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
My RCA is next to the power wire from under the back seat into the trunk to the amp, and I never get any noise either. I think if you use high quality RCA cable you won't have that issue.
PoorManQ45
Plain and simple, you won't have a problem
xekushnr
1991S13 wrote:My RCA is next to the power wire from under the back seat into the trunk to the amp, and I never get any noise either. I think if you use high quality RCA cable you won't have that issue.
sometimes you do, sometimes you dont. maybe you do and you dont notice it. it depends on a lot of things (proximity, quality of RCAs, size of wire etc, surroundings etc). but as a rule of thumb i never run RCAs down the same side of the car I run the power wire.
bryanmenard
Car: 1993 Nissan 240SX SE Fastback
2001 Infiniti QX4 4X4
2003 Infiniti QX4 4X4
Use shielded cable....no problems no matter what you run it by.
xekushnr
bryanmenard wrote:Use shielded cable....no problems no matter what you run it by.
true, but nowadays you can easily spend over $100 just for a good set of RCAs. most people dont really have $100 to drop on a cable, so this way is more practical. but if you can afford the good stuff, by all means thats the way to go.
bryanmenard
xekushnr wrote:true, but nowadays you can easily spend over $100 just for a good set of RCAs. most people dont really have $100 to drop on a cable, so this way is more practical. but if you can afford the good stuff, by all means thats the way to go.
OR, for the same price as buying pre-made, go to a local electronics/electrical house and get the cable, connectors, and a tool to do it and make your own for like 1/10 the price.
xekushnr
bryanmenard wrote:OR, for the same price as buying pre-made, go to a local electronics/electrical house and get the cable, connectors, and a tool to do it and make your own for like 1/10 the price.
ah, the joys of DIY. i have ~500ft of Cat5e sitting in my garage, once i buy some connectors i can start making big ethernet cables. and the best part is i got the spool for free
