smokin240 »
https://forums.nicoclub.com/smokin240-u15929.html
Thu Nov 04, 2004 6:32 am
Could be your injectors, catalytic conv., plugs, vacuum leak, plug wires, MAFS, accelerator resistance node, and a few others things but those are the main things that could be causing it. If you have the patience to look into them go for it, you'll find the problem with one of them im sure of it, I had the same problem. Those are the sort of things that can cause it, except I had it about 20x worse on my s13 (93) 167k mile engine.
