I H8 UR DSM »
https://forums.nicoclub.com/i-h8-ur-dsm-u121.html
Tue May 13, 2003 11:51 am
the lights tell you if you've staged shallow or deep....whether the first light stays lite or goes out....i shallow stage...
neither is 'better' or 'worse'..you can argue for both, if you have the perfect reaction time (which i have far from) stage deep...if you stage shallow your MPH should be higher, but et will be higher also...if you stage deep, your et should be lower....figure shallow stage you arent at a complete stand still when you break the lights
at the level 'you're' probrobly on, it wont make a difference in times
