NY S13 SR wrote:S13 KA and SR manual trans speed sensors use the same color gear, they are interchangeable. We have swapped them around many times and they both work.
The one that came on the SR trans should work fine, we did 3 auto-to-manual swaps and all 3 worked fine like that.
If that doesn't work look for shorts in the speedo wiring by the ECU or switched wires.
______________________Jeff HoldenHeavy Throttle
