0-60 3.5 CVT
All things Altima Coupe.
DAAN.
I found times vary, up to 6.6 seconds. What is the actual value - seems 6 manual is 5.6s The search did not help "Your search for 0-60 returned no results."
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
DAAN. wrote:I found times vary, up to 6.6 seconds. What is the actual value - seems 6 manual is 5.6s The search did not help "Your search for 0-60 returned no results."
it does vary... don't think a consensus was reached... I think the best reported time for the CVT was 6.2 seconds .. and 5.8 fo the manual... where did you se 5.6 for the manual at bruh?
DAAN.
thank you for giving me an idea
edmunds http://www.edmunds.com/insidel...23955 have the cvt at 6.4, car gurus list it in the 6 to mid 6 range depending on transmission http://www.cargurus.com/Cars/O....html, autofiends places the manual in the 5.9 seconds time trap http://www.autofiends.com/2009...e-6mt/, motor trend finds the manual in the 6.4s timeframe http://www.motortrend.com/road....html, top speed in the 5.8s manual http://www.topspeed.com/cars/n....html and cardomain lists the manuals in the 5.x-6.x range depending on transmission http://www.cardomain.com/MakeM...rward. i recall someone listing a 5.7 manual on here, but with so much information scattered all over the map ...
pfew
marlin29311
Car: 2008 Infiniti G35x
I've gotten a 5.9 in my CVT before...but that's probably a little off as it was self timed...
ILoveJDM5
Car: None of your business
automatic stock - 6.2manual stock - 5.8
08coupedriver
Car: 2008 Nissan altima coupe 3.5SE CVT
I have a youtube video of under 6 secs, but then again I have tastefully modded engine http://www.youtube.com/watch?v=r_WYDc-Iak4
ILoveJDM5
i clocked it at 6.1 bro and 6.0 so iuno maybe i did it wrong?
funkee
Car: '08 Altima Coupe 3.5 SE
Bringing this thread back to life. I did two 800rpm launches today:
5.42 using combination of manual and CVT modes
6.2 in CVT mode
Both were timed by my passenger.
I didn't get a chance to do any manual mode only runs, or higher rpm launches.
I also don't have any performance parts; only coils, wheels, sway bar, tails, and borla axle back.
I will repeat the manual mode and cvt combo run on the drag strip soon to confirm.
EDIT: Using an app called UlysseSpeedometer, I clocked 0-60 in 5.95 using CVT only. And 1/4mi at 12.92. I'm not sure how accurate the 1/4mi reading is.
jmann
Car: 2017 Mercedes GLC300 4matic
2015 Infiniti QX70 AWD
Car & Driver has the 2008 CVT at 5.8 seconds, not sure if that number has changed for later models. They usually get the best times compared to other magazines.
http://www.caranddriver.com/reviews/200 ... -road-test
Ranga14
Car: Boosted 08 Altima Coupe 3.5
0-60 sounds normal in the 2nd one but that 1/4 mile is BS, lol.
altystreet
Car: 2.5 CVT Altima Coupe; nismo exhaust; k&n typhoon
12 sec quarter? damn
altystreet
with enough mods to a 2.5 cvt do you think my 0-60 time can get to 6.0 or around there
funkee
altystreet wrote:with enough mods to a 2.5 cvt do you think my 0-60 time can get to 6.0 or around there
Definitely. A stock 2.5 coupe should be able to do 7.5 seconds. You can get down to 5 with a turbo at 4-5 psi, even if you have a CVT.
If you don't want a turbo, you can still hit 6. Just have to get rid of weight and let the engine breathe. Get some light-weight wheels, dump the spare and the rear seats. Then get a new intake, headers, wipe out the cat with a ypipe, midpipe and exhaust. That should get you down to 6 no problem.
I'm still testing out various ways of using the manual mode and CVT modes together in a single run. Once I have some real concrete numbers to back it up, I'll make a write-up.
