Nissan Forums / Infiniti Forums - NICOclub > GTR Forum / Skyline Forum > R33 HEATER PROBLEM (Printable Version)
Post Title: R33 HEATER PROBLEM
Posted by: REEKER at 1:59 PM 7/1/2009
i have an 96 r33 . lately the heater unit has been blowing out hot air even when set to cold and when the air con is on , and even when i turn it off. any 1 have any ideas about this problem . and how to fix it... :
Post Title: Re: R33 HEATER PROBLEM (REEKER)
Posted by: Gold Digger at 8:04 PM 7/1/2009
Could be that the motor that switches between the hot and cold isn't working, not allowing the cooler air to enter.
Or it could be the climate control itself not working properly.
I would suggest trying to find a climate control unit first as that's the easiest to get out. If that doesn't work, you may have to replace the motor inside the vents.
Post Title: Re: R33 HEATER PROBLEM (Gold Digger)
Posted by: prtrillaboss at 2:57 AM 7/2/2009
Theres a valve at the firewall that allows flow, its in line with the heater core hoses. Check that. If you need any replacement parts email me I have 2 complete heater/climate systems
Posted by: REEKER at 10:02 AM 7/2/2009
sound wil try that
Post Title: Re: R33 HEATER PROBLEM (prtrillaboss)
Posted by: REEKER at 10:04 AM 7/2/2009
do i have to take out the dash to find that valve and what side is it on drivers or passenger
Posted by: prtrillaboss at 3:10 PM 7/2/2009
Its in the motor bay, slightly behind the motor on the drivers side
Posted by: REEKER at 4:09 PM 7/5/2009
thanks for the help . went to try what u said . but didnt end up having to , :[IMG][/IMG]the car mended its self . :
Posted by: HeavyDuty at 4:12 PM 7/6/2009
I read where you stated it repaired itself, but I had a similar problem on a 91 Q45. Turns out the outside temperature sensor was going bad intermittently. When it was reading incorrectly, it thought the outside temp was something stupid like -150 degrees. So using that as a reference point, it had to blow fire out of the vents to get the temperature *up* to 65 deg or whatever I had it set on.
Do our cars have a similar setup?
Post Title: Re: R33 HEATER PROBLEM (HeavyDuty)
Posted by: REEKER at 12:17 PM 7/7/2009
dunno for weeks my car just blew out hot air. temp guages were all reading ok . then what ever happened . it just back working proper
Posted by: prtrillaboss at 12:31 AM 7/8/2009
Quote, originally posted by REEKER »
weird.. glad it worked out for you
Posted by: REEKER at 9:54 AM 7/10/2009
---my problem is back again to haunt me
Posted by: prtrillaboss at 11:05 PM 7/15/2009
Check that valve, if its stuck it could be the issue or one of the motors on the blower box is fail. Check and tell or email me
