P0159
-open short
see above
P0158
-open short
-see above
-High fuel pressure
-possible injector leaking
This is what one of the jerk offs from auto zone wrote down.
Its a 99 Nissan Maxima 3.0 v6.
I'm thinkingchanging the fuel pump and cam sensor, any ideas? Thanks
Post Title: Re: 1999 Nissan Maxima Trouble code questions (nlacke001)
Posted by: loystock at 11:44 PM 7/1/2009
DTC Code P1320 refers to problem with the Ignition Signal Primary (Ignition Coil) - ignition circuit harness or connector; power transistor in ignition coil; condenser; or crankshaft position sensor.
Please download a copy of FSM (Factory Service Manual) and go to EC (Engine Control System) chapter. It will give you instructions on how to do your own diagnostics, interpret the DTC codes and isolate the problem.
< Contact Us - NICO
