Nissan Forums / Infiniti Forums - NICOclub > Maxima Forum & I30 / I35 Forum > 02 Maxima Spark pug tube seals. (Printable Version)
Post Title: 02 Maxima Spark pLug tube seals.
Posted by: xerexabante at 3:14 PM 6/27/2009
Can anyone source out these seals? Oil is leaking from valve cover to spark plug ports getting my spark plugs drenched with oil.
Thank you in advance.
Post Title: Re: 02 Maxima Spark pLug tube seals. (xerexabante)
Posted by: xerexabante at 10:39 AM 6/28/2009
I think I found a fix. I update you guys.
I found tube seals for vq35de. I ordered a seal and valve cover gasket to takle the #2 cylinder tube seal issue. If this works there is hope for Vq35de motors not to buy a a valve cover from the dealer for this issue.
Wish me luck.
Posted by: xablian at 3:03 PM 6/29/2009
I tried to find one but ended up replacing the valve cover 200+ dollars.
Post Title: Re: 02 Maxima Spark pLug tube seals. (xablian)
Posted by: xerexabante at 4:32 PM 7/3/2009
Well I did a 2 step fix. I was leaking in #2 so it was easy. I pulled valve cover and had some silicone on the tube seals. I kept looking at it for about a week, NO leak. Good to go.
Today I did a Spark plug change for all 6. I did a reseal for the tubes as well even if it was not leaking on the back(under plenum) valve cover just to be sure. Did the Plugs with a cooler temp plugs to eliminate the Ping I had.
All is well now no ping and no leaks. New Plugs, New Valve cover gaskets left and right bank, all 6 tube seals resealed
