Nissan Forums / Infiniti Forums - NICOclub > Sentra Forum / Infiniti G20 Forum / NX Forum > Clutch issues (Printable Version)
Post Title: Clutch issues
Posted by: fiendelico at 11:05 AM 6/25/2009
I am having clutch issues on my 2001 Nissan Sentra SE 2.0. I push my clutch in and it does not return. I put my foot behind the clutch pedal and pull it up and the operation of the clutch slowly returns and works for brief time before not returning again. My clutch fluid is gray and dirty and was just below the minimum level before I added more. There are no visible leaks on the line. I will pull back the boot cover and check for a leak. Is it hard to replace the clutch master cylinder if that is what it is?
Post Title:
Posted by: nametakennow at 7:27 PM 6/25/2009
First bleed and replace the fluid. If there's no improvement, it's probably the master.
Post Title: Re: Clutch issues (fiendelico)
Posted by: Xtream Friction at 3:53 AM 7/2/2009
is this a new clutch or an old clutch?
Posted by: Xtream Friction at 3:54 AM 7/2/2009
did you brake it in ?
brake in is 500miles regular driveing~
Posted by: Xtream Friction at 3:55 AM 7/2/2009
did you bleed the clutch?
Posted by: Xtream Friction at 3:56 AM 7/2/2009
if you did not bleed the clutch then that the problem!
Posted by: Xtream Friction at 3:57 AM 7/2/2009
did the clutch sound like if it would grind in the tranny?
Posted by: Xtream Friction at 3:58 AM 7/2/2009
if so the clutch *throw out bearing* might of grinded through the pressure plate teeth!
Posted by: Xtream Friction at 4:00 AM 7/2/2009
or if you resureface the flywheel the might of done it wrong tand took to much off it!
Posted by: Xtream Friction at 4:01 AM 7/2/2009
check thickness of clutch disc? and make sure the offset part is facing the pressure plate not the flywheel...
Post Title: Re: Clutch issues (Xtream Friction)
Posted by: ProudNissanFreak at 7:47 AM 7/2/2009
Wow, way to be a prick trying to get your 10 posts.
Post Title: Re: Clutch issues (ProudNissanFreak)
Posted by: ABNRML4U at 11:21 AM 7/2/2009
+1
