Clutch issues
fiendelico
Car: 2001 Nissan Sentra SE 2.0 5 speed
I am having clutch issues on my 2001 Nissan Sentra SE 2.0. I push my clutch in and it does not return. I put my foot behind the clutch pedal and pull it up and the operation of the clutch slowly returns and works for brief time before not returning again. My clutch fluid is gray and dirty and was just below the minimum level before I added more. There are no visible leaks on the line. I will pull back the boot cover and check for a leak. Is it hard to replace the clutch master cylinder if that is what it is?
nametakennow
Car: '06 MINI Cooper S
First bleed and replace the fluid. If there's no improvement, it's probably the master.
Xtream Friction
Car: s2000 with a nissan skyline GTR
is this a new clutch or an old clutch?
Xtream Friction
did you brake it in ?
Xtream Friction
brake in is 500miles regular driveing~
Xtream Friction
did you bleed the clutch?
Xtream Friction
if you did not bleed the clutch then that the problem!
Xtream Friction
did the clutch sound like if it would grind in the transmission?
Xtream Friction
if so the clutch *throw out bearing* might of grinded through the pressure plate teeth!
Xtream Friction
or if you resureface the flywheel the might of done it wrong tand took to much off it!
Xtream Friction
check thickness of clutch disc? and make sure the offset part is facing the pressure plate not the flywheel...
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
Wow, way to be a prick trying to get your 10 posts.
ABNRML4U
Car: Nissan B13
