Nissan Forums / Infiniti Forums - NICOclub > J30 Forum / M30 Forum > electrical issues (Printable Version) Click here to print this topic.
Post Title: electrical issues Posted by:johnfaze at 1:54 PM 6/21/2009 hi. i have a problem with the windshield wipers cutting out in the rain.the fan motor cuts out at the same time as does the side power mirrors. any idea where to start looking? its a 93 j30. thanks
Post Title: Posted by:driverdriver at 6:41 PM 6/21/2009 Sounds almost fuse related.
Here's the section of the FSM that will be of interest to you:
Post Title: Posted by:yodawill2000 at 8:28 AM 6/22/2009
Only happens in the rain ?? Sounds like a uninsulated wire somewhere.
Post Title: Re: (yodawill2000) Posted by:johnfaze at 2:50 PM 6/22/2009 thanks guys. i was also told to check for clogged/leaking drains from the sunroof. hope its not too bad.
Post Title: Posted by:driverdriver at 11:47 AM 6/23/2009 To clear clogged sunroof drains, use canned air(the type used for clearing computer keyboards). The drains are in the front corners of the sunroof frame. Spray air gently into them, don't force it. The drain tube gets delicate with age.
Post Title: Re: (driverdriver) Posted by:salaguinto at 12:29 PM 6/23/2009 Speaking of fuses, reason I was scanning this forum was I was looking for discussion on a specific electrical problem - while driving home, my dashboard lights all went out (all dashboard gauges, heater/ac/console background or outline lights - although the heater/ac display is ok and radio is aftermarket so its still on) and my headlights are stuck on high-beam.
Tried looking for similar discussion until I got to page 12 and didn't find any. Any thoughts? Thanks.
Post Title: Posted by:yodawill2000 at 12:35 PM 6/23/2009
Sounds like the dimmer switch over on the left of the steering wheel. Give it a good SMACK and see if they come back on. If so you have a cold solder joint on the connector or the switch is bad.
The headlights thing may be the headlight relay in the engine bay. Common problem on the J's.
