Nissan Forums / Infiniti Forums - NICOclub > Quest Forum > Odometer/Gas Gauge partial display missing (Printable Version)
Post Title: Odometer/Gas Gauge partial display missing
Posted by: 05questowner at 9:23 AM 4/27/2009
I have a 2005 Nissan Quest and part of the display and odometer numbers do not display. Over the course of the day they come back. They will eventually all come back. Anyone else have this issue? or know what could cause it? Also my gas gauge seems to beact weird. It will read correctly for a while the drop to about half a tank then come back up to full.
Thanks!
Post Title: Re: Odometer/Gas Gauge partial display missing (05questowner)
Posted by: renee0069 at 3:39 PM 6/2/2009
My 2005 Quest has the same problem. Sometimes it works and sometimes not - more not Also, we just replaced the timing chains so be careful because it happens right around 60-65k miles from what I am told and it is very expensive. Let me know if you find anything out on the odometer because they want to charge me $500 to fix. Thanks!
Post Title:
Posted by: ricebike at 8:01 AM 6/10/2009
to the OP, you have a "short" somewhere... there's an online manual on this site for your vehicle...
to renee, i thought these run on timing BELTS... then they need to be changed in a timely manner or the INTERFERENCE engine will bend valves when the belt breaks... on my 3.3L engine that is... 105,ooo mile interval
i dunno about the 3.5L if they switch to timing CHAINS...there should be no interval changes for a chain...
edit: you got ripped off if you changed out the timing chains on your 3.5L 2005 quest this early in the game!
Quote »
It uses a detuned Z engine of 3.5 liters and twin overhead cams. The timing belt is gone, and a chain now does the job of moving camshafts. Will our customers change the oil enough times to keep the chain in shape? Time will tell.
keep the oil clean so the hydraulic tensioner will keep the chain "tight"
ps: also heard the rear spark plugs are a biatch for this engine
Quote »
I researched the service procedures and when the rear spark plugs were removed, it starts with "drain the coolant." I am not liking this. The rear spark plugs are now a major job, which is a real step backward. Were technicians thought of when this new van was designed? I would say no. It is futuristic but that future is not the one a technician dreams about. We want to have access to those parts that normally wear out, need replacement or service. As I have said so many times before, a little thought ahead of time would save techs time, customers service dollars, and warranty claims would be less expensive.
Modified by ricebike at 11:11 AM 6/10/2009
