When I read p3-4 of my EX manual, I thought this offered the same, but then noticed that there was no mention of the sunroof ... hm, OK.
However, the other day, I happened to need that function and found out that the key-in-the-lock trick only closes (or opens) the front windows, even though the manual clearly states "The driver's door key operation also allows you to open and close all door windows."
So, has anyone else tried this? Do I have a problem with my car, or is this feature simply "incomplete" in its implementation and erroneously documented in the manual?
TIA,
David
Post Title: Re: Opening/Closing Windows with the Key (dividedhighw)
Posted by: Mark Booth at 11:16 PM 5/30/2008
Perhaps the operation of all four windows and/or the sunroof via the key-in-door is something that can be turned on/off by an Infiniiti dealer? I know that my Lexus (traded for the EX35) could be "programmed" in a variety of different ways in this regard.
BTW and FWIW, you can also lower the front two windows by holding down the unlock button on the keyfob. The lock button does NOT roll them back up though.
Mark
Post Title: Re: Opening/Closing Windows with the Key (Mark Booth)
Posted by: dividedhighw at 7:44 AM 5/31/2008
Yes, you can use the key fob to open also and that's covered in the manual, but I didn't want to cloud the situation by mentioning that.
If the dealer might be able to affect certain things, is it done using an OBD-II port? Where is this port on the EX? Has anyone got a reference to what data blocks are associated with what functions?
TIA,
David
Posted by: RCF at 8:11 AM 5/31/2008
... just kidding!)It's clearly shown in the graphic on p3-4 of the manual, and it's certainly there on my car!!
As the preceding page of the manual shows, there's a small slider on the backside of the key fob that releases the mechanical key. It's this you use, once you do find the keyhole.
Posted by: RCF at 7:45 PM 5/31/2008
I specifically asked if there were any OBD data blocks that could be changed to affect the operation of this, but they told me no.
Particularly for a self-professed "intelligent" car company, this makes no sense. Yes, this function lets you air out the car on a hot day, but it's equally useful when you turn off your car, forgetting to close all windows. This is MUCH more likely for the rear windows than the front ones. Plus, if this affects the rear windows, surely the first capability (airing out the car) would benefit as well.
I insisted the Asst Service Manager escalate it to Infiniti to see if anything could be done, and he agreed, but I'm not too hopeful. (So far, I'm extremely "underwhelmed" by the service at 417 Infiniti, but I'll post more on that when I have more time.)
Anyway, if anyone has more info on this, I'd very much appreciate it if you could post here.
TIA,
David
Posted by: rn79870 at 11:32 AM 6/14/2008
| Quote, originally posted by dividedhighw » |
Hm ... you might want to look again - when you're sober. ( ... just kidding!)It's clearly shown in the graphic on p3-4 of the manual, and it's certainly there on my car!! As the preceding page of the manual shows, there's a small slider on the backside of the key fob that releases the mechanical key. It's this you use, once you do find the keyhole. |
If your EX is like my G, it would be a good idea to find the "secret" spot for inserting the key in case you ever need to start the car and the intelligent key battery is dead. It wouldn't be that easy to find mine in the dark.
Also, I've heard that it is a good idea to change the batteries in the fobs about every 18 to 24 months - before they go dead. I've seen the battery for 99 cents on the Internet. I'll bet they are much more at an Infiniti shop.
Post Title: Re: Opening/Closing Windows with the Key (rn79870)
Posted by: dividedhighw at 10:06 AM 6/15/2008
| Quote, originally posted by rn79870 » |
| If your EX is like my G, it would be a good idea to find the "secret" spot for inserting the key in case you ever need to start the car and the intelligent key battery is dead. It wouldn't be that easy to find mine in the dark. |
Good point! In the EX, the fob must be inserted into the "Intelligent Key Port", located below and to the left of, the steering column - see manual p0-6 (item 8) for an illustration and p5-8 for full details.
| Also, I've heard that it is a good idea to change the batteries in the fobs about every 18 to 24 months - before they go dead. I've seen the battery for 99 cents on the Internet. I'll bet they are much more at an Infiniti shop. |
The required battery is a disc type CR2032 (see p8-21), commonly available at many electronics outlets and even some dollar stores. As I near the 18 month mark, I intend to keep a couple on-hand (perhaps even one in the glove box).
Posted by: dividedhighw at 8:53 AM 6/21/2008
I've now been dealing directly with the service manager and I must say, he's been excellent.
Unfortunately, the news isn't good. He tells me that the key-activated window feature is tied into the "express" up/down feature. Since the rear windows don't have this, there's no way to include them.
This sounds believable, so my hope for any better outcome is dwindling. That said, there are a couple more points to consider:
i) the sunroof does have "express" operation (i.e. one button press opens/closes fully) yet it's still not covered by this feature
ii) as previously said, Audi/VW has had this capability for many years; if Infiniti is using the same chipset, it's possible there's a "backdoor" way to wake this up to at least include the sunroof, if not the rear windows.
If you stumble across any more info, please share it on this thread!
Posted by: Dodgeyaussie at 9:48 AM 7/9/2008
| A quick update on this ... I've now been dealing directly with the service manager and I must say, he's been excellent. Unfortunately, the news isn't good. He tells me that the key-activated window feature is tied into the "express" up/down feature. Since the rear windows don't have this, there's no way to include them. This sounds believable, so my hope for any better outcome is dwindling. That said, there are a couple more points to consider: If you stumble across any more info, please share it on this thread! |
Sounds about right seeing as how all four windows on the G's can be opened/closed with the key.
Posted by: zozoka1212 at 7:41 AM 7/17/2008
zozo
< Contact Us - NICO
