Nissan Forums / Infiniti Forums - NICOclub > 240SX Forum / 180SX Forum / Silvia Forum > m tr4nch's restoration/build thread !! (56k = death) (Printable Version)
Post Title: m tr4nch's restoration/build thread !! (56k = death)
Posted by: m tr4nch at 3:07 AM 4/16/2008
what's up everyone, my name is matt, and here you will find my long overdue s13 restoration/build thread. i'll use this as my introduction also. i'll try to keep the text as short as possible since i know people don't like to read
so here's how the story goes...
i've been into cars since around the time gone in 60 seconds came out (like '98-'99), i was in 7th grade. my older brother and i were going to get a car to build back in '01-'02, but could never find the right one. he eventually lost interest in cars and this is when i "discovered" the 240sx. i fell in love (lol) with the s13 fastback. i didn't even know what drifting was back then. i was 14 at the time so i decided to wait until i was 17 to get one when i had my license (now that i look back i shouldn't have waited ).
i ended up getting my 240sx in june '04, a month after my 17th bday (after a good 3-4 months of searching). 1992, 132,700 miles, 5 speed, base model, bone stock, little bit of rust, no mechanical problems, no body damage (except for a few door dings), clean carfax, ONE owner. paid $1600 cash.
picsha time...
when i first got the car
and more random pics
(current DD in the background)
rusty engine bay
then i started collecting some parts, starting with suspension stuff
new front 5-lug hubs and some hardware
z32 calipers/rotors/lines
all new suspension bolts
some jdm padding in the box lol
i had all the dings taken out professionally, pieces of tape to mark them off
finally on jack stands.. the decision was made to start tearing it apart in june '05 after my inspection sticker expired and i knew there was no chance in hell this thing was going to pass. so i said fcuk it.
(as you're reading this thread, keep in mind i have no previous automotive experience at all.)
"i can't see sh*t!!"
beadblasted headlight assembly
subframe/diff rustyness
more rusty sh*t underneath, the muffler goes here
painted calipers and other stuff
disassembly of the front end
dirty as HELL
"GTFO my engine bay!!"
KA coming out
obligatory engine bay shot
ahh, so much easier to take the rest of the crap out..
the ol' rusty KA, had to cut the downpipe since ALL of the studs/bolts/nuts holding the entire exhaust system together were rusted beyond hell
zomg RB25????
already has nismo FPR
not sure about the condition of the turbo..
broken exhaust manifold stud
cut up harness (not as bad as it looks though)
built a dolly with my dad
anyone wanting to know how i made the chassis dolly, here's my write up: http://forums.nicoclub.com/zerothread?id=284025
aaaand away for the winter (winter '05-'06 that is )
the rest of the car...
closet full of new parts
Post Title: Re: m tr4nch's restoration/build thread !! (m tr4nch)
Posted by: m tr4nch at 3:11 AM 4/16/2008
begin spring '06, out of hibernation
interior completely gutted, dry ice is awesome.. also stripping the excess seam sealer off everything
stripped engine bay. rusty and dirty as hell
rusty seams in front wheel wells
bottom of passenger side quarter panel
inside..
driver's side not nearly as bad..
burning the bushings out of the subframe
and so the rust attacking commences...
started grinding those front shock tower plates
this crap was way too deep and i could see stuff hiding under there still, so i decided to just drill it (both sides) off, good thing i did
sandblasted clean
one coat of rust bullet sprayed on
upper radiator support next.. there's a LOT of rust hiding sandwiched between here
got to sandblasting a little bit. here is my sandblasting outfit
after spraying with rust bullet..
new shock tower plates cut out and painted
front wheel wells and battery tray are next...
yes i know this cut-out is horrible, i drilled 4 holes and used my dad's sawzall with a POS blade and it came out like crap
battery tray patch cut out and welded up (i was a n00b at welding back then )
wire-wheeled all the rubber/grime out of the wheel wells
stopped for a couple months for winter
picked up again spring '07..
i gave up on my radiator supports and decided to just get new ones and replace mine
got the upper support off, test fitting the new one
got the bottom one off, man this thing was rusty as hell on the inside..
engine bay sanded down and rusty spots getting grinded down before sandblasting
decided to cut a few pieces out, i hate rusty seams!!
other side
after blasting and spraying rust bullet
then i welded on the new radiator supports and shock tower plates
then i found another surprise
tried doing a little bit of cutting and gave up, saving it for later..
blasted the front wheel wells next, and coated with rust bullet
xenon lip came woohoo!
summer '07.. someone tell me if i'm crazy
starting on the journey through hell..
after countless hours and days later, working like this..
(yes i know the die grinder is on my balls/crotch)
(this is only 1 day's worth of crap, i was out there for like 5 or 6 days..)
the end result...
man, i don't think i want to ever do that again... being out in the 80 degree+ humid NJ summer weather wearing coveralls/ski mask/etc on my back for a few days.. holy SH*T is all i have to say..
after that i figured it was time for some welding
and painted up with more rust bullet
also finally painted over these welds
just some comparison pics of the engine bay after the rust fixage
now the hard part...
started on the rear section first (basically from rear seats back)
after sandblasting
and some rust bullet
and then... a full coating of rust bullet
started the floor section next
rusty seat mount
where the e-brake cable goes through
glad i got that off...
more surprises
wtf, i thought i was done with this crap...
after a little bit of cutting and poking
after a lot of cutting
okay... this is where i stand now, the last pic was from sept '07, the car's hibernating again and will come out in less than a month for me to continue working on it. btw, so far ALL of this work has been done only by myself.
i have decided to cut those sections of frame rail out and replace with clean metal. also i will have more pics up later sometime of new parts that i've been getting over the last few months.
i know it's a TON of pics at once haha, yes some things i didn't get a chance to snap during the moment. keep in mind this "project" has been going on for the last almost 3 years now. but now that i actually started a build thread, i will have tons more pics from here on out.
in short, my plans for the car is to be rust free with brand new parts everywhere (i will get pics of the rest of my new parts later), basically a "brand new" car that i can drive daily on the street and is reliable (for the most part).
a brief list of what's left to do:
finish fixing rust on floor section
remove glass and sand everything down for paint
get most of the suspension powdercoated
new poly bushings installed
throw everything back together
anyways, i guess that's about it for now. thanks for looking and let me know what you guys think.
Posted by: offroadbob at 4:20 AM 4/16/2008
Awesome work! Very nice progress. I can't wait to see it finished.
Posted by: Shift__BODOM at 5:48 AM 4/16/2008
I admire your dedication. I'd like to think I wouldn't quit halfway through and just sell off all the parts, but I probably would. Serious kudos for sticking with it and doing all that hard work by yourself. I can't wait to see how everything comes together.
Posted by: numbnuts240 at 6:00 AM 4/16/2008
you missed a spot . jk, looks real good man, i wish i had the time and funds to do all that with my car. i'm loving your engine choice btw.
Post Title:
Posted by: StricNyne at 6:32 AM 4/16/2008
hey turd sniffer you didnt post your most important peice of equipment your FnFIII Poster !!!!! seriously it looks awesome man now i gotta search up a AWESOME jpeg you havent seen and post it up
Post Title: Re: (StricNyne)
Posted by: StricNyne at 6:41 AM 4/16/2008
there we go..
Posted by: homeslicej2 at 7:03 AM 4/16/2008
Nice job so far I too admire your dedication. I hope to restore mine in future as well. I think Nissan still sells those front frame rails. I've seen someone post them up here on NICO. It might be easier/better to just get new ones (if they still sell them), cut the old ones out, and weld in the new.
Post Title: Re: (homeslicej2)
Posted by: kouki-gymkhana at 7:50 AM 4/16/2008
Holy shiznit! Awesome work! I admire your dedication and the shell looks awesome so far. Be careful with that RB25...make sure you take the time to sort it through thoroughly before you drop it in. It will save you a sh*tload of headaches down the road. What mounts are you going to use? Might want to think about banging in the firewall where the starter will sit before you finish painting the bay to make it pretty. It will hurt your heart a little less if you do it now than when it's all painted. Don't ask me how I know...
No plans to stitch weld the frame to stiffen it up? Might as well think about it since it wouldn't be that much of a stretch to do at this point.
I look forward to seeing more updates soon. Keep up the good work!
Posted by: mirochuki13 at 8:03 AM 4/16/2008
This is my favorite pic.
My whole car would be blue if I marked all the dings on it... lol.
Also, I think you should try to get sponsorship from rust bullet.
Post Title: Re: (kouki-gymkhana)
Posted by: BMAR240SX at 8:14 AM 4/16/2008
Did you hit the effin lotto?
Post Title:
Posted by: Hijacker at 8:33 AM 4/16/2008
Subscribed. I'm digging this resto project, and I totally understand your hatred of rust. My car is an ex-jersey car and had the fortunate luck to be pulled out of there many years ago. The few years it did spend up there did damage though, which I've been slowly fixing. Just not to the extent that you're doing. I don't have the patience or garage space to sideline a car for years to do what you're doing.
Post Title: Re: (Hijacker)
Posted by: white90esex at 11:06 AM 4/16/2008
wow, seems like way more work than its worth lol.
good luck with it.
Posted by: homeslicej2 at 11:33 AM 4/16/2008
Kouki-gymkanan....whatever, made me think of something, other than take your time to make sure the RB install is great. Look into the SKYO mounting kit for the RB25. I looks like the best one out there right now.
Post Title: Re: (white90esex)
Posted by: Hijacker at 1:00 PM 4/16/2008
Quote, originally posted by white90esex »
good luck with it.
It is a lot of work, but so long as he enjoys it, it's worth it. Not to mention he's doing a great job at it so far.
m tr4nch, Are you going to respray the underside with rubberized undercoating? They make it in a spray can and it's worth every penny if you do do it.
Posted by: the converted at 1:44 PM 4/16/2008
Damn..... that's some attention to detail. Just keep it up.
Posted by: Rellik27 at 1:52 PM 4/16/2008
wow looking good keep it up
Post Title: Re: (Rellik27)
Posted by: nwmrkt at 2:05 PM 4/16/2008
damn man nice job! You knew I was waiting for this thread.
Post Title:
Posted by: Lopin18 at 2:17 PM 4/16/2008
holy, at first i was like Restoration my *** this thing is brand new!. then i saw the dings out and i was like, ok, looks more NEW, then i saw the stack of stuff i was like, hmm ok thats overboard, he wants to assemble the whole car?, then freaking doing chassis work cleaning, now rb25, OMFG, LOL THIS IS ONE HELL OF A COOL PROYECT, this car is gonna be BRAND new, beautiful. IM IN, Love this car, thread, work, everything!
Posted by: 2.4Loflove at 4:51 PM 4/16/2008
your rust problems are somewhat worse than mine, and you tackled them! good luck on whatever is coming. where did you get all the $$$ for the OEM parts?
Posted by: m tr4nch at 5:20 PM 4/16/2008
thanks for the comments everyone. it's really hard work. i actually almost gave up on it a couple of times but i figured what i had done up to that point would have been a waste, so i stuck with it and now i'm almost finished
i'll try and answer everybody's questions.
Quote, originally posted by homeslicej2 »
yeah i've seen people get those frame rails, i heard they are discontinued now? either way it's just that section that is rusty (where the rail bends upwards). the reason is because there's another layer in there for added strength (you can see it in my pics) and that hole there isn't such a good idea, so it just started rusting in between the layers. so i will get some sheet metal from the metal fab place around here and make some new one foot long sections for both sides.
Quote, originally posted by kouki-gymkhana »
yeah the RB has been sitting on the engine stand for over 2 years now so i will pull things off that generally need to be replaced when doing a swap.
as for mounts, i am almost 100% sure i will be going with the SYKO mounts. i already have the r33 crossmember, and when it's all said and done it will be cheaper than getting mckinney's.
speaking of banging in the firewall, would you (or anyone) happen to have a pic of where exactly to do this? and how far in?
you know, i was originally thinking of stitch welding the whole chassis, but i decided against it. for a street car i don't think it would be worth it. plus i can always add a cage in the future for added stiffness if i ever wanted to.
Quote, originally posted by BMAR240SX »
lol i wish...
Quote, originally posted by Hijacker »
lots of people don't take care of their cars around here during the winter (mine's a prime example). it looks like the previous owner parked it in the damn ocean for a while, lol.
good luck with it.
maybe, i guess we'll find out hehe, thanks!
yesssssir. i got my 5 cans of 3m rubberized undercoating sitting in my basement.
Quote, originally posted by nwmrkt »
haha yes i know you were thanks!
Quote, originally posted by Lopin18 »
thanks man! yep everything (mostly) will be brand new. i really need to go downstairs and take some pics of my last nissan order
Quote, originally posted by 2.4Loflove »
haha thanks. $$ is from me working for 5 years and saving most of it.
Post Title:
Posted by: op.tic at 5:54 PM 4/16/2008
Ive actually been waiting for this thread, the pic in your sig got me interested in this build.
I have a 90 240sx hatch that i used some parts off of, theres rust here and there just like yours, this really makes me want to restore it and give it another chance, rather than giving it to a junkyard.
Post Title: Re: (op.tic)
Posted by: slipipinoi at 7:12 PM 4/16/2008
soooo manyyyy partsssssssss
Post Title:
Posted by: baoweezee at 7:34 PM 4/16/2008
been waiting for your write up ina long time..Gj btw, hey wat do ya use for sandblasting? and can u take a picture of the rust bullet ur using? wanting to do this on my car
Post Title: Re: (slipipinoi)
Posted by: 3down1togo at 7:42 PM 4/16/2008
Ummm Ummm Ummm all i can say is You Are The S***!! lolz congrats on your progess times a MILLION...
Post Title:
Posted by: xckid at 7:56 PM 4/16/2008
will you marry me lol
damn man sweet restoration though...omg !!! this thread is so getting marked
Post Title: Re: (3down1togo)
Posted by: Gottoknow at 8:15 PM 4/16/2008
Right now you are my inspiration.
Post Title: Re: (baoweezee)
Posted by: m tr4nch at 9:56 PM 4/16/2008
Quote, originally posted by baoweezee »
for sandblasting i use one of these guns with the hose attached
with my air compressor
and a bucket of sand
edit: forgot about the rust bullet lol... all i'm using is their automotive version. i also got some of their blackshell to try out. both are kind of thick and you're not supposed to thin them or it can screw up its rust inhibitive properties.
for everyone saying i'm inspiring, thank you
i got all of my inspiration from people that have done this sort of thing: "powerhousemike" on vwvortex forums (white 240 coupe in FL), sillbeer, etc. thanks to them as well
Modified by m tr4nch at 4:21 AM 4/17/2008
Post Title: Re: (m tr4nch)
Posted by: m tr4nch at 10:10 PM 4/16/2008
some more parts pictures..
sold the tein he's and bought a set of stance gr+ back in october
main reason is that i want to use the z32 knuckles in the rear and for some reason tein is "unable" to send me some rear z32 mounts..
my cleaaaan J30 vlsd and axles (thanks to UNISA JECS on zilvia)
jdm chuki sideskirts with no cracks
catco high flow cat
now for the good stuff
new fuel tank and sending unit
all new weatherstripping
e-brake T cable, hood lock cable, hood latch assembly
random clips/screws/floor plugs
overflow tank, rear view mirror, mirror glass, front bumper emblem, wiper arms
new combination switches (since every s13 has sun faded switches), pedal pads, door stuff
headlight bezels
all new lamps (front turn signals, front and rear side markers, 3rd brake light, license plate lamps)
clutch hardline, fenderwell plastic, door moulding also stuffed in there
will have more soon, maybe tomorrow
Modified by m tr4nch at 4:54 AM 10/10/2008
Post Title: Re: m tr4nch's restoration/build thread !! (offroadbob)
Posted by: Didderson at 10:47 PM 4/16/2008
I've always wondered what your sig was about. Now I know. You're one crazy perfectionist! Big props on the real restoration and not doing tube frame. It'll be nice and OEM one day for barret jackson hehe.
subscribed. finish it this summer!
BTW great choice on the motor. Had I had more time and money I'd love to have done an RB25.
Modified by Didderson at 12:31 PM 4/17/2008
Posted by: pflicht at 11:50 PM 4/16/2008
Damn dude, thats fcuking amazing@ I would have been pissed at the whole damn thing and just did a shotty job and would have finished it up within a year. Way to stay motivated and not cut corners. And for the DIY on everything, +100
BTW, when you are done, I will allow those rust killing hands to come out to Kansas and clean my car of rust! jk
I will definately be looking for updates!
Post Title:
Posted by: Hijacker at 6:56 AM 4/17/2008
Matt, do you have the part numbers on hand for the light and wiper switches? Convertibles tend to get theirs sun faded worse than other 240s, so I've been wanting to replace them and I've been having trouble pricing out the wiper switch. I'll have a lot better luck with a p/n
I'm actually surprised that you got a lot of the parts you did. It seems every time I go to order something oddball, Nissan has it on backorder.
Posted by: homeslicej2 at 7:15 AM 4/17/2008
Holy crap. Nissan must love you cause I'm sure most of that stuff is $$$.
...I'm actually surprised that you got a lot of the parts you did. It seems every time I go to order something oddball, Nissan has it on backorder.
I bet he had to wait awhile for a lot of those parts to come in from Japan or something.
Post Title:
Posted by: urcaptnspeaking at 11:39 AM 4/17/2008
this is nuts. I love it
Post Title: Re: (urcaptnspeaking)
Posted by: m tr4nch at 12:17 PM 4/17/2008
thanks guys yeah hopefully it will be drivable by the end of the summer, or at least rolling on the ground.
headlight switch: 25540-44F00
wiper switch: 25260-44F00
and yeah, every time i place an order it takes at least 3 weeks since i order all the random sh*t lol.
Post Title:
Posted by: Hijacker at 1:01 PM 4/17/2008
At least your parts dept. orders it Mine has been notoriuos for forgetting to order stuff. A set of main bearings for my motor rebuild comes to mind.
But everytime I go to order something oddball, like a set of power mirror interior sails, it seems to be on indefinite backorder.
Posted by: Didderson at 1:09 PM 4/17/2008
wtf 2xpost sry
Post Title:
Posted by: Flicktitty at 1:17 PM 4/17/2008
That is an awesome build! you very dedicated to your build! let me just say it's easy to tear **** apart put having to put it back together is where it gets tricky, then again i geuss everything you have is brand new in bags so you shouldn't have a problem.
Did you go through a nissan dealership to get the parts or a website?
Posted by: m tr4nch at 4:20 PM 4/17/2008
Quote, originally posted by Flicktitty »
haha, that sucks. i go through http://www.midwaypartsteam.com in AZ. talk to mike jones there, he's taken care of most of my orders, awesome guy. he will get what you need, unless it's discontinued. or you could go through courtesy nissan's catalog online. midway's a little bit cheaper though
thanks! i actually think it will be much easier to put back together than tear apart. most importantly because i wont have to deal with bolts/nuts/screws that are rusted to sh*t.
Post Title:
Posted by: Lopin18 at 9:07 AM 4/18/2008
O.O Whats your real name man?
Mat Gates Nissan? or something around nissan? thats a lot of EXPENSIVE things there, the beauty of oem stuff
can we get an estimate on how much have u spent buying all that stuff (i mean the oem stuff only, vsld and all that are normal stuff to buy, but ALL that oem stuff is off the hook!)
Posted by: Hijacker at 9:20 AM 4/18/2008
Quote, originally posted by m tr4nch »
I used to order from Midway a lot, but when I'm ordering just one item at a time, the NICO discount doesn't really amount to much, and after shipping, it's cheaper to go through my local dealer.
And when I do a big order, I have some good hookups out here. I just don't like to take advantage of it too much.
Out of all the seals you ordered, did you happen to come across the part number for the seal that goes around the door handle and the one that goes in front of the handle key cylinder? Mine got painted over and I want to replace them before I reinstall the handles into the doors.
EDIT: Nevermind. I just got off the phone with my parts guy, and I'd have to buy the whole handle to get those seals. I guess I'll see if I can't try to save the ones I have
Posted by: bmart at 9:37 AM 4/18/2008
Quote »
You would hate Canada if you think that that car was bad. A 240 In the condition that your car was in when you bught it would be worth 5-6000 dollars around here. What your doin looks great though. keep it up.
Posted by: blinker_fluid at 9:59 AM 4/18/2008
When your done with that feel like restoring my car...jk. Seriously its looking like its all gonna be worth it in the end. So good that I'd be almost scared to drive it with all the bungholes on the road. What part of ocean you live in, if you need help with the motor install lmk I'm good with electrical and mechanical stuff just don't have a knack for body work. Hope to see it cruising soon, good luck.
Post Title:
Posted by: m tr4nch at 5:02 PM 4/18/2008
alright, more pictures..
rusty subframe
new unrusted subframe from CA (thanks to killswitch on zilvia)
KA crossmember
r33 crossmember
here's why i got a new e-brake T cable...
rusty headlight brackets
non rusty headlight brackets
remember my quarter panel? this will replace it
thanks to tearlessj on zilvia
zero rust baby!!
some power window/mirror stuff (thanks to bamracing and ebay)
and this is how she sits right now
and the motor
Modified by m tr4nch at 4:58 AM 10/10/2008
Post Title: Re: (Lopin18)
Posted by: m tr4nch at 5:13 PM 4/18/2008
hmm let's see.. all the suspension bolts/nuts/etc. was around 500. then all the other stuff adds up to about 3k.. and i'm not done yet
ah true, yeah i don't recall a seal around the handles, idk lol
Quote, originally posted by bmart »
yeah that definitely sucks for you guys in canada, idk what i would do.. i'd have to move south somewhere haha.
Quote, originally posted by blinker_fluid »
lol yeah i know what you mean, people around here SUCK at driving big time NJ really needs to make the license test a LOT harder so we can get all the douchebags off the road.. oh and i don't mean ocean county over there << haha, i'm in monmouth though. thanks for the offer man, i'll keep that in mind if i need help.
Posted by: mirochuki13 at 5:44 PM 4/18/2008
I think the underbody looks better and better every time I check this thread.
Are you going to keep the car black?
Post Title: Re: (mirochuki13)
Posted by: m tr4nch at 6:32 PM 4/18/2008
Quote, originally posted by mirochuki13 »
yup, the plan is to get the whole car sprayed in KH3 super black again
Post Title:
Posted by: NismoJ30 at 6:56 PM 4/18/2008
Huge props to u my friend, i thought i put huge blood and sweat into restoring my Integra, but nothing like this u definitely own me there. good luck and dont quit
Posted by: AE240SX at 6:58 PM 4/18/2008
Matt,
Wow.... For claiming to not know anything about what you were doing you sure as heck are doing everything right. Time is money and you have so much invested in that car. I'm glad you mentioned Silbeer as that is one of my fav S-chassis cars ever. That car will be something to keep and give to the grandkids when your done with it. Goodluck.
Posted by: bamracing at 7:16 PM 4/18/2008
I've been waiting to see your build too. After seeing it, I'm not sure the door panels, power window, and power mirror parts I sent you are worthy. Keep up the great work!
You wouldn't happen to still have the old steelies lying around? My son and I could use some spares for our dirt tracker.
Post Title: Re: (bamracing)
Posted by: KFL at 11:12 AM 4/19/2008
Wow.. super clean build up.. you have a lot of paitence and time. I'd be super anxious to get it up and running already.
Once our cars are running me and carlos gotta check that out and lend a hand if u need. -alex
Post Title: Re: (KFL)
Posted by: lucky03602 at 12:52 PM 4/19/2008
great job on the restoration, another subscriber here!!
i do feel bad for you when you have to put it all back together though...thats ALOT of work and always 1000% harder then is was taking it apart
looking at your pics. and living up in nh, i think ill end up sandblasting the checking my engine bay, seeing how all your rust was really on the inside.
Post Title: Re: (lucky03602)
Posted by: darkspoon at 5:45 PM 4/19/2008
As well, another subscriber here, great way to waste time at work, i've gone over the pictures a few times and i'm getting psyched up to do my own 240 restore. (I'll try to get pics, but you'll cry at the rust i'll be facing)
What kind of welder are you using?
BTW Thank you for the picture intensive thread, it is a great write-up of sorts. As well as the write up on the 240 dolly.
Just keep those pictures coming
Post Title:
Posted by: boost4life1 at 8:36 PM 4/19/2008
This guy is NOT F U [ i |\| G around!!!!!!!!!!!!!!!
Post Title: Re: (boost4life1)
Posted by: bloodsport at 8:43 PM 4/19/2008
Quote, originally posted by boost4life1 »
really?
Post Title: Re: (bloodsport)
Posted by: B-Boy DuB-L at 9:14 PM 4/19/2008
Hey man if u still have that crossmember ill gladly take it off your hands for you
Cuz im looking to do a 5 speed swap. So if u have ny other parts ill take those to. Of course with some compensation
Post Title: Re: (darkspoon)
Posted by: Young_240_Guht at 3:36 AM 4/20/2008
Welder was probably set on pulse, and you weren't using the right settings? IDK, I wish i could have helped you with those welds after seeing how much work you've put into this car.
Kinda like what the older guys do with theyre classics, maybe if more of us would do this, Nissan might bring the S chassis back and more tasty engine choices
Post Title: Re: (Young_240_Guht)
Posted by: JaeTea at 5:01 AM 4/20/2008
You must have money to burn.
Post Title: Re: (JaeTea)
Posted by: 240life at 2:04 PM 4/20/2008
I like it good luck this car should be sweeeeet when you finish!
Posted by: m tr4nch at 6:48 PM 4/20/2008
Quote, originally posted by bamracing »
haha, they are definitely worthy! i'm so sick of having to lean over and roll the passenger window down (and mine too) all the time (my DD has manual windows as well). and i do believe i still have the steelies in my other shed, although the tires are pretty much bald. you can have them if you want to pay for shipping to TX.
Quote, originally posted by KFL »
thanks man
Quote, originally posted by darkspoon »
i'm using a lincoln electric, model SP135T mig
thanks
Quote, originally posted by B-Boy DuB-L »
the KA crossmember? sure.. one of the motor mounts wouldn't budge so i started grinding the nut/bolt from underneath and never finished it. i don't have any extra 5-speed parts though...
Quote, originally posted by Young_240_Guht »
what's wrong with my welding? i don't really care how it looks, i always grind them down a bit anyways. i just care that i get good penetration, which i am. i prefer the one-spot-next-to-the-other method as opposed to the long straight bead.
thanks for looking out though
Posted by: Nis-240sx-san at 7:31 PM 4/20/2008
WOW! .....This is a really nice build. You must have a lot of patience to do this kind of extensive work. +12467432 for the great work
Posted by: Ericb at 5:19 PM 4/28/2008
Your awesome.
Im lost for words with this build.
Posted by: pflicht at 5:25 PM 4/28/2008
I would really like to have your motor!
Post Title: Re: (pflicht)
Posted by: Ericb at 5:38 PM 4/28/2008
I would like to have this mans heart (not in a gay way) and determination
Post Title:
Posted by: 240 GTR at 5:51 PM 4/28/2008
wow. i knew you were restoring your 240, but i didnt think you were doing all of this. it's amazing!
i dont know if you remember, but i bought the tein he's from you. i'm glad to see that you are still going to put coilovers on it.
keep it up man. looks like your almost there!
Post Title: Re: (240 GTR)
Posted by: dalzell240 at 6:58 PM 4/28/2008
i wish i had time and money for somethin like that
Posted by: eldewen at 8:43 PM 4/28/2008
I'm also needing to get a sandblasting setup going and am kind of a n00b about it so far. By "and a bucket of sand," do you mean literally, like a bucket of sand from the backyard, or do you need to buy some special fine grit sand?
Also, does your sand blaster...
...have a hopper for the sand or does it siphon it?
Post Title:
Posted by: sommmatt at 8:54 PM 4/28/2008
If you didn't spend so much time taking pictures you would be done by now.
Post Title: Re: (Ericb)
Posted by: m tr4nch at 10:10 PM 4/28/2008
Quote, originally posted by Ericb »
lol i get what you're saying though. thanks!
Quote, originally posted by 240 GTR »
of course i remember, haha. i've changed my aim sn since then (took the P out). how are the coils treating you? and how's your cars doing?
Quote, originally posted by eldewen »
Also, does your sand blaster have a hopper for the sand or does it siphon it?
yes, i literally mean one of those orange paint buckets from home depot with sand in it. the gun siphons the sand from the bucket. and don't get sand from your backyard, or even worse, the beach.. i got 2 bags of sanitized play sand to use (also from home depot). i sweep up the sand when i'm done for the day and filter it through a screen. i haven't even opened the second bag yet.
Quote, originally posted by sommmatt »
hahah.. if you divide the number of pics i have by 3.5 years, i think i would be lacking in the pic department.
thanks for all the great comments
Posted by: Jeff822 at 10:24 PM 4/28/2008
Wow dude this a pretty sick build, wish I had the money to do something like this.
Posted by: pflicht at 10:43 PM 4/28/2008
Its been ~11 days since some pictures... This thread has delivered THUS far... I want more, more, MORE, MOAR!!!!!
Post Title:
Posted by: Mista Lee at 10:50 PM 4/28/2008
damn mann, you have love for this car
this is real dedication.
great job so far, and i'm lookin forward to seeing you finish it up!
good luck!
Posted by: datsun2401972 at 11:28 PM 4/28/2008
Yeh, I was gonna comment on your welds too, but I see perfect welds every day... It's not just penetration you want, but also resistance to cracking. A good rule of thumb, if it "looks" good, it is good. But even a good "looking" weld can crack. If you can find a good weldor that's been in the industry for a while(that's not an *******), you can learn alot from em'.
But regardless, this project is much deeper than how your welds look. And it's downright motivational for me. +1 for DIY!
Posted by: m tr4nch at 12:46 PM 4/29/2008
Quote, originally posted by pflicht »
i know i know.. in about 2 weeks i will be starting to get **** done again. can't wait!!
Quote, originally posted by datsun2401972 »
hmm i see.. i guess i will just practice some more then. thanks man.
oh and sometime in the future, my next "project" will probably be an S30 i LOVE that car. (going by your name)
Posted by: datsun2401972 at 5:38 PM 4/29/2008
My s30 was my first car purchase with my own money...I was 17 at the time. I still have it actually, it's just on some lawyers property...and he's being a dick about it.
Awesome cars though. I would love to have a cherry one with an SR or RB25 in it. It just takes too much money to make those old engines roar. And then I bought my s13 coupe, so all funds for my s30 were moved to the s13...
Anyways, keep the inspiration coming!
Posted by: perkeset at 12:36 AM 5/5/2008
first off, props man one of the best builds i have ever seen on a s13. now as for the starter placement in the fire wall, i installed my rb and had to bang the fire wall back a good 2-3" to clearance it. depending on the kit you use yours will sitt different than mine, but you seem to be pretty good at welding so i would say you may want to make your own mounts we did and we sat the rb25 back about 2" from where it sits with the McKinney kit better weight balance for the car. yes that meant even more customizing of the fire wall but i think it was worth it.
oh and did i mention much respect for a bad azz build, oh yeah man if i ever see you at a show. . .i am buying you a beer cause after this build your gonna need it
Post Title:
Posted by: gregfarz78 at 10:52 AM 5/5/2008
God damn man thats a nice build! Your nissan dealership must hear cha ching when you walk in the door lol I feel your pain about jersey cars though the road salt and salt water near the ocean just destroys everything around here, I bought my car from a guy in texas so I wouldn't have to deal with rust.
How much did the weatherstripping run you I need to replace all mine too...oh and where did you get that sandblast gun?
Posted by: PhopsonNY at 12:43 PM 5/5/2008
Hey Matt,
Great work here...
With all this work, I suggest you also get at all the parts that are not accessible with a rust converter/inhibitor.
You seem to have got quite a bit of it, but for some extra safety, I would do it.
The areas I was worried about when I did my car;
Inside frame rails
Inside rocker panels,
Inside the quarter panel ( you seem to have taken care of this)
I got hold of one of these kits and blasted those areas
http://www.eastwoodco.com/shop...21310
Good luck with all the good work
Post Title: Re: (datsun2401972)
Posted by: m tr4nch at 5:41 PM 5/5/2008
S30 with rb25 =
Quote, originally posted by perkeset »
thanks i mentioned before back on page 1 that i am most likely going with the SYKO mounts. i guess i'll worry about the firewall when i get to the point of dropping the motor in.
Quote, originally posted by gregfarz78 »
yeahh that's one of the bad things about living around here.. the weatherstripping ran me about $600. that's for everything: the 4 pieces for the doors, the door mouldings along the top, the hatch, and hood.
the sandblasting gun i got at home depot for like $15 or $20
Quote, originally posted by PhopsonNY »
Hey Matt,
Great work here...
Inside frame rails
thanks man, yeah one of those undercoating guns is definitely on the list. when i'm done, i will have gone over pretty much every inch of this thing
Posted by: gregfarz78 at 7:28 PM 5/5/2008
Yeah hope you plan to garage keep that bad boy when you're all done it really makes a huge difference my spec is 6 years old its been garage kept most of its life and doesnt have a spec of rust on the underbody or anywhere. Did you spray that rust bullet or brush/roll it on?
Post Title: Re: (gregfarz78)
Posted by: m tr4nch at 10:55 PM 5/5/2008
definitely will be garaged kept when i'm done.
for the engine bay and front wheel wells i sprayed on both coats of rust bullet. for the underbody in the rear i brushed on the first 2 coats over the sandblasted areas with a foam brush, and then sprayed on 2 coats to cover everything. so the sandblasted areas have a total of 4 coats now just in case. i'll be doing the same for the floor section as well.
Post Title:
Posted by: gregfarz78 at 1:42 PM 5/6/2008
Nice like I said mine has no rust but after drooling over this thread I'm going to paint my entire interior with rust bullet even though it will be garaged and never see snow.
Posted by: LeMoine at 3:40 PM 5/8/2008
If you ever sell this car then you might aswell just never buy a 240 again because no other s13 can be close to as nice as this will be when finished. Great project tho get some pics up i want mooree
Post Title: Re: (LeMoine)
Posted by: dray3OOO at 8:52 PM 5/25/2008
wow def. inspirational a tru project. cant wait to see it done and its not even my car
Post Title: Re: (dray3OOO)
Posted by: __CURRTISS__ at 10:42 PM 5/25/2008
omg....i wish like many others that i had the time to do this....damn
Post Title: Re: (__CURRTISS__)
Posted by: Ghostdrifter88 at 11:39 PM 5/25/2008
You have some serious patience.
This build is freakin awesome. great job dude.
Posted by: fitlife240sx at 10:57 AM 5/27/2008
wow its coming out really good so far...good luck
Posted by: Flicktitty at 11:11 AM 5/27/2008
Quote, originally posted by LeMoine »
X ALOT!
lovin the build just stopped back for any updates.
Post Title:
Posted by: s13gebala at 1:48 PM 5/27/2008
very nice, any engine mod plans with the rb25?
and do you think powerwash(water n air) would get rust off?
Post Title: Re: (s13gebala)
Posted by: m tr4nch at 10:17 PM 5/27/2008
thanks everyone! updates coming sooon, i promise.
Quote, originally posted by s13gebala »
very nice, any engine mod plans with the rb25? and do you think powerwash(water n air) would get rust off?
for now i am just gonna leave the rb25 stock and get used to it. maybe some bolt on's in the future. i'll be shooting for low 300's, maybe like 320hp, but i will figure all that out later.
and for your other question, i don't think powerwashing rust is a good idea. first i don't think it will get it off, and second it will probably make it worse (water/air and bare metal = rust). so i'm going to have to advise against that
and on a side note, as of right now i am officially 21!!! w00t!!
Posted by: fourLUG_hero at 11:23 PM 5/27/2008
Happy birthday dude. I give you INSANE amounts of respect for tackling a rusty car like that. And I thought MY car was rusty.
Post Title:
Posted by: robbie2009 at 8:28 AM 5/30/2008
Hey nice project man. I would never have patience for something like that. About that Ka Crossmember, would you be willing to sell it?
Posted by: tfreker at 2:01 PM 5/30/2008
good luck cant wait to see the end result
Post Title: Re: m tr4nch's restoration/build thread !! (tfreker)
Posted by: Kalypso at 1:01 AM 6/2/2008
great job - its exciting to see that many new parts, well done
Posted by: speedyrb at 6:15 PM 6/22/2008
hey nice project you have going there. where did you get all the oem parts for the radiator support? did you go stright to a nissan dealer or is there a website you got them threw?
Post Title: Re: m tr4nch's restoration/build thread !! (speedyrb)
Posted by: Dittoz7 at 6:39 PM 6/22/2008
SEX!
Post Title:
Posted by: cemtoes at 7:25 PM 6/22/2008
amazing build thread, subscribed!
I hope all goes well with the rest of it.
Post Title: Re: (cemtoes)
Posted by: future240owner at 7:57 PM 6/22/2008
Amazing job. I can't imagine how much you have learned from this. Keep up the good work man. We are all going to want a grand total in the end. Something like this has always been an idea but to much time and money need to be dedicated.
Do you go to school? Where do you work?
Post Title:
Posted by: UsJdmTuner at 4:28 PM 6/27/2008
nice build very inspiring.. can you tell me your setup on sand blasting..
Post Title:
Posted by: iandrew89 at 4:47 PM 6/27/2008
great job your doing with this car keep us posted
Posted by: Kalypso at 2:01 AM 6/28/2008
are you going to paint it in the garage?
Post Title: Mace?
Posted by: WhiteKnight at 3:55 AM 6/28/2008
Do u know there a MACE hanging on your doorknob in one of the photos? Are you near Newark where u would need it?
Post Title:
Posted by: tjmhillz at 6:29 AM 6/28/2008
damn matt i didnt even know u had a build thread going.. get that **** done.. u and los with the never ending projects lol...
Post Title: Re: Mace? (WhiteKnight)
Posted by: MastaYu at 9:22 PM 6/29/2008
THis restoration has inspired me
Post Title: Re: Mace? (MastaYu)
Posted by: nightsauce at 9:24 PM 6/29/2008
lol gotta have the newark jokes. i'm from born and raised in newark. never had a problem.
O and GOOD work on the restoration. i'd love to see the final product. looks like you have a long road ahead of you
Post Title: Re: Mace? (nightsauce)
Posted by: lazyboi444 at 2:17 PM 7/1/2008
HEY M TR4NCH...I was wondering the Suspension Bolts you ordered and All the little things you ordered did you order them as individuals or as like a bolt kit...What company did you order thru? Same for the Fuel tank sending unit
Post Title: Re: Mace? (lazyboi444)
Posted by: pflicht at 2:42 PM 7/1/2008
So uh... where are those picshurz you promised???
Post Title: Re: M TR4NCH
Posted by: RCA at 4:54 PM 7/1/2008
You better hurry up!
You need to make it to E-Town!
Post Title:
Posted by: pntang at 10:10 PM 7/1/2008
WOW...dedication is an understatement...u living my dream...i wanted to do that when i first got out of high school but couldn't find the time to do it...and i can't afford a second car...now i'm on my 4th 240 but i think it'll be my last cuz as soon as i'm done w/ college my dream will be realize...good luck w/ everything man and major props
Post Title: Re: (pntang)
Posted by: m tr4nch at 11:03 PM 7/2/2008
alright, i know i've been slacking with the updates lately. for the last 2 or so weeks i've been working on building a rotisserie. i got this far and i realized this is taking way too long and i'm only like half way finished so i'm abandoning that project for now.
i started with 2 bed frames that my dad had lying around in his garage, and ended up with these:
definitely not done as you can see..
so back to the car.
got the 2 chunks of frame rail off.
then i started on the seam where the floor meets the rocker on the passenger side.
also got my sweet undercoating gun from canada to spray inside hard to reach areas like my frame rails and crap.
so that's about it for now. tomorrow i am going over to the metal fab shop and picking up some sheet metal for the frame rails and i'll be doing some more cutting on the floor/rocker seam on the driver's side:
stay tuned
Modified by m tr4nch at 5:00 AM 10/10/2008
Posted by: m tr4nch at 11:22 PM 7/2/2008
thank you all for the nice comments. they keep me motivated
to answer some people..
Quote, originally posted by speedyrb »
i order all my nissan stuff from midway parts team in AZ, http://www.midwaypartsteam.com
Quote, originally posted by future240owner »
i have definitely learned a LOT through all of this. yes i go to school. i work at a movie theater making minimum wage (almost)
Quote, originally posted by UsJdmTuner »
(page 1) i use an air compressor with a sandblasting gun and a bucket of sanitized play sand. all i do is wheel the car out into the driveway and blast in the open so i don't get sand all over the garage. when i'm done i just wheel it back inside, sweep up the sand and run it through a screen to remove all the crap.
Quote, originally posted by Kalypso123 »
i want to do it in the garage myself but my mom doesn't want me to for some reason so i gotta take it somewhere to get it done.
Quote, originally posted by WhiteKnight »
LOL yeah i know, my older bro got it from medieval times like 20 years ago
Quote, originally posted by nightsauce »
thanks. you go to njit eh? i went there for a semester a couple years ago..
Quote, originally posted by lazyboi444 »
i wish there was a bolt kit.. i ordered them all individually from nissan. same with the sending unit. read up a little in this post for midway^
Quote, originally posted by rcabrita »
yeahhh i'm trying we'll see what happens though.
Posted by: RCA at 3:15 AM 7/3/2008
ROFLMAO!
OMG, only you would stop an awesome full car resturation to make a rotisserie!
You are quite the character!
I stoped suscribing to this thread.
I am waiting for the official:
m tr4nch's rotisserie build thread
Post Title: Re: (rcabrita)
Posted by: hbpignosePA at 5:37 AM 7/3/2008
lookin good man, thats the approach im gonna take with my s30....
im thinkin tube frame
Post Title: Re: (hbpignosePA)
Posted by: m tr4nch at 4:47 PM 7/3/2008
alright another update! got a lot of ish done today.
so i went to the metal fab shop i went to last time and they didn't have the gauge of metal i needed for the frame rails, so on monday i'll be going to this other place around here to pick some up.
did some more cutting and grinding on the floor/rocker seams. DONE with that until i start sandblasting
cancer..
Modified by m tr4nch at 5:01 AM 10/10/2008
Posted by: 2.4Loflove at 5:31 PM 7/3/2008
now that's some dedication, keep the updates coming!
Post Title: Re: (2.4Loflove)
Posted by: StandardProspect at 5:35 PM 7/3/2008
your build never ceases to amaze me
you really know how to fix up a 240 the right way!
cant wait to see more
Posted by: g love at 5:57 PM 7/3/2008
Your a doctor to the cancer know as rust on that 240, kick its a$$ seabass!
Post Title: Re: (g love)
Posted by: op.tic at 6:38 PM 7/4/2008
Dude you have seriously inspired me to start up my 240 build. Ive started taking pictures at the end of every day i work on it, so maybe i'll start a build thread some day with a huuuge thanks to m tr4nch for the motivation.
Btw, im going to try and duplicate your chassis dolly tomorrow.
Modified by op.tic at 11:48 PM 7/4/2008
Posted by: mirochuki13 at 10:46 PM 7/4/2008
lol... Do it.
Post Title:
Posted by: Black on Gold at 9:23 AM 7/5/2008
Great ****ing thread. I'll continue to watch this one.
I hope to one day be able to do this. Being 19 and not much $$$ doesnt help. But im working on it
Post Title:
Posted by: naladude911 at 2:34 PM 7/5/2008
I wonder how much rust I have..... im in NY to, and I see a lot of what I hope is surface rust...
Post Title: Re: (naladude911)
Posted by: snwbrdr435 at 2:39 PM 7/5/2008
nala rust is like an iceberg. You only see the smallest portion at the surface. What is really going to sink your ship is underneath.
Post Title: Re: (snwbrdr435)
Posted by: m tr4nch at 7:54 PM 7/5/2008
Quote, originally posted by snwbrdr435 »
every time i went and looked harder i found something else
Post Title:
Posted by: UsJdmTuner at 12:29 PM 7/6/2008
nice man.. props to you.. thanks for answering my questions.. i was wondering if you have pictures of the foam brush you used to paint using RUST BULLET.. i read somewhere that you foam brushed it and sprayed it( did you mean spray gun or rust bullet come in spray cans?)
Post Title: Re: (UsJdmTuner)
Posted by: m tr4nch at 12:18 AM 7/7/2008
i use one of these to apply the first couple coats, they are like $0.49 each or something cheap like that at home depot:
and then i spray 2 coats with my sharpe fx300 spray gun:
the rust bullet unfortunately does not come in a spray can.
Posted by: sped56737 at 4:52 AM 7/7/2008
this is awesome! lol my first post, just had to post in here. hope to see the updates.
Post Title: Re: (sped56737)
Posted by: nissandrftr88 at 7:15 AM 7/7/2008
Im glad i live in the south where the rust aint nearly as bad!!
This is an awesome build,but i don think i would trust that rotisserie.
Posted by: op.tic at 8:30 AM 7/7/2008
Have you used any of the rust bullet black shell yet? got any pics of it applied? How hard is that stuff anyway, can it be chipped off at all?
Posted by: RCA at 12:09 PM 7/7/2008
Does that bad boy do paint as well?
Also when useing rust bullet isn't there a special cleaning procedure you must do to your gun to insure that the paint residue doesn't harden in the gun it self?
Posted by: k00laid83 at 12:20 PM 7/7/2008
yea that gun shoots good....and also you can pick up a three guy paint gun set in a case sold by napa...i have that set and i've shot my cars roof.. my cousins cars...and a three stage house of color paint job on a harley. i think they cost me 120 for all three!
Post Title:
Posted by: livinglegend2100 at 2:24 PM 7/7/2008
this is by far the sickest build ive ever seen. you sir, are a god. more pitchassssssss please =D
Post Title:
Posted by: 240sxDrifter1126 at 6:03 PM 7/7/2008
very nice build...i cant wait to see it finished
Posted by: m tr4nch at 9:15 PM 7/8/2008
Quote, originally posted by sped56737 »
thank you! welcome to nico!
Quote, originally posted by op.tic »
i painted the lower radiator support with the blackshell before i welded it on. the finish is pretty much the same as the regular rust bullet. it looks powdercoated and doesn't chip. both the regular rust bullet and the blackshell are pretty tough coatings. i'll try and get a picture of it tomorrow when i'm in the garage.
yes it does.
you have to keep the paint flowing or it will start to dry inside the gun. the directions on the rust bullet say not to let it sit more than 15 (?) minutes. after i'm done i run a bit of toluene through it and thoroughly clean it which works really well.
Quote, originally posted by k00laid83 »
that's not bad for 3 spray guns.
still using my sig? i fixed the "1" if you want it let me know.
update
V
Posted by: m tr4nch at 9:19 PM 7/8/2008
did a little more cutting today.
got the driver's side draft duct cut out in the rear.
cut the bottom of the passenger side quarter panel off finally
still have to cut the duct part on the inside..
tomorrow i'll be cutting the duct, and i will be attempting to cut out the piece where the door hinge bolts up on the driver's side
(pic to refresh your memory)
Modified by m tr4nch at 5:03 AM 10/10/2008
Posted by: RCA at 10:58 AM 7/9/2008
Wow Awesome!
After all is said and done...
what do you think all of this is going to do with the structual integrity of the car? You pretty much replaced it with welded together pieces of metal...
Posted by: k00laid83 at 11:49 AM 7/9/2008
yes it does.
update
V
oh yea huh dang ive actually have been wanting to get rid of it man. and yea bro check those guns out!
Post Title: Re: (k00laid83)
Posted by: tEknoS13 at 11:56 AM 7/9/2008
that spray gun, i saw some on ebay and they have different tips i think, they got 1.3,1.4, 1.5,..... which one do u have?
Posted by: m tr4nch at 12:22 PM 7/9/2008
Wow Awesome!
i think it will be fine, if not better. i mean all a car really is is pieces of metal spot welded together in a million places.
just bustin your balls man lol.. i'll have to take a ride over to napa one of these days and see what they got.
Quote, originally posted by tEknoS13 »
ah yes.. i bought the gun with a 1.8 tip which is said to be good for spraying primer. i bought a 1.4 tip set to see if it would atomize the rust bullet a little better since it's pretty thick but i haven't really noticed any change.
i read that 1.4 is good for basecoats, and 1.2 for clear
but it looks like i won't be doing either of those myself so i'll be good with my 1.8/1.4 combo.
i'll have some more pics up later tonight hopefully
Post Title:
Posted by: naladude911 at 4:20 PM 7/9/2008
what do you use to cut the metal?
Posted by: m tr4nch at 5:19 PM 7/9/2008
didn't get a lot done today...
went and picked up my new frame rail pieces
old vs. new:
double 16 gauge layers vs. the stock 16 on outside and 18 on inside:
still have some trimming/bending to do obviously
got the duct cut out on the passenger's side:
started the door hinge area.. wtf...
didn't even realize there was another layer in there.. mmm crusty...
ran out of juice in both batteries for my drill, so i will finish drilling the spot welds and cutting tomorrow.
just keeps getting worse and worse it seems
Modified by m tr4nch at 5:04 AM 10/10/2008
Posted by: RCA at 3:59 PM 7/10/2008
^ DON'T GIVE UP!
We are all rooting for you! I swear one of these days I am going to pass by and help by getting in your way.
Post Title:
Posted by: Traldan at 4:38 PM 7/10/2008
I have an immense amount of respect for the work you've put into this car. Keep it up, man. I'll definitely be watching this.
Post Title:
Posted by: gregfarz78 at 7:51 PM 7/10/2008
my god that car has a lot of rust you just keep finding more and more...don't give up though
Posted by: m tr4nch at 9:07 PM 7/10/2008
^ DON'T GIVE UP!
haha.. i'm not giving up. it's just a friggin PITA
Quote, originally posted by Traldan »
thanks!
did a little more today. i took a break and got sidetracked reading about welding and stuff online.
anyways.. got this bitch taken care of...
i guess i'll be stopping by the sheet metal shop again haha
i'm going to do the other side also, just to be on the safe side, although i'm sure it's not going to be quite as bad as that^ but still a little rusty nonetheless.
not sure if i'll get anything done tomorrow.
Modified by m tr4nch at 5:06 AM 10/10/2008
Posted by: Kalypso at 11:19 PM 7/11/2008
KEEP GOING!!
Post Title:
Posted by: Briggs at 7:53 PM 7/12/2008
Dude, I just read all 4 pages, and you are the man. I give you a lot of props for this huge project. Suuuubscribed.
Post Title: Re: (Briggs)
Posted by: m tr4nch at 8:26 PM 7/15/2008
Quote, originally posted by Briggs »
thanks, much appreciated.
little bit of an update...
first off, here's a pic of the lower rad support with the black shell on it for those who were wondering. it comes out looking like it's powdercoated.
(don't mind the silver specs, it's just a little overspray from when i painted the welds)
here is what the pass. side upper door hinge mount looked like. can't really tell from the outside if there's anything going on in there..
and DONE
i figured out why this happens. when the cars were originally manufactured, the pieces are spot welded together as bare metal. then the car gets an e-coat applied (electronically coated, for adhesion and to fill in everywhere). well those layers were so tight against each other that the paint didn't get in between them so over time the uncoated metal just rusted inside there. this may also be the reason why my frame rails rusted where there was the double layer.
anyways, that's it for now.
almost forgot, these bad boys showed up on my doorstep today:
edit: 600th post, w00t!!
Modified by m tr4nch at 5:07 AM 10/10/2008
Post Title:
Posted by: StricNyne at 9:29 PM 7/15/2008
gittem gittem dont stop !!!
Posted by: Kalypso at 7:56 AM 7/16/2008
Posted by: 2.4Loflove at 9:11 AM 7/17/2008
Posted by: slow40 at 10:05 AM 7/17/2008
wow man, if I had an original 70's Dodge Charger with all options and all it needed was fixing rust like yours, I would have to pass no matter the worth of the car when done, Barrett Jackson or whoever. Much love for keeping the car alive, I would have just found another chassis.
Post Title:
Posted by: supra33202 at 4:07 PM 7/18/2008
Good job and strong dedication! Keep us updated!
Post Title:
Posted by: sr20-thoj at 4:37 PM 7/18/2008
What sand blast gun are you using? looking to get one like that as well.. brand?
Post Title:
Posted by: EW at 9:54 AM 7/19/2008
Nice work but it should be a lesson to you guys up north to buy a non-rusty car from a southern/western state.
Post Title: Re:
Posted by: nightsauce at 2:34 PM 7/24/2008
what are you gonna do with the stock trans? I would be interested in purchasing it. i just purchased an auto 91 hatch.
Post Title:
Posted by: gregfarz78 at 3:27 PM 7/25/2008
yeah what did you ever do with the old KA and trans was it shot?
Post Title: Re: (EW)
Posted by: Kalypso at 9:56 PM 7/25/2008
Quote, originally posted by EW »
true indeed, I have to rust treat mine before I bring it back to NYC
its a florida car.
Im not sure what I need to do that. but some goggles, a brush, and jackstands is a start.
Post Title: Re: (Kalypso123)
Posted by: hbpignosePA at 2:49 PM 7/26/2008
u my friend are a god of rust killing
wish i lived a bit closer to NJ, im gonna need all the help i can when i start the s30.... i might just try and source a new shell from AZ or cali....
if i do go for a new shell ill donate the one i have to u,
Posted by: nightsauce at 10:41 PM 7/26/2008
Quote, originally posted by hbpignosePA »
u my friend are a god of rust killing.....
i'd pay him money to fix the minor rust i have.
Post Title: Re: (nightsauce)
Posted by: 240_hero13 at 11:23 PM 7/28/2008
Sick build good luck..
but where do you guys get the ****ing $$ and time to do this??
so fast nicely and rapidly
DO YOU DO FOR WORK?!?!
TELL ME NOW!
Post Title: Re: (sr20-thoj)
Posted by: m tr4nch at 1:10 AM 7/29/2008
Quote, originally posted by sr20-thoj »
already covered this. the new one i got is made by husky.
definitely a lesson learned!! never will i buy a car again with rust.
i sold the motor & tranny a looong time ago. the block was pretty rusty on the outside, exhaust smoked a little, it was on it's way toward a rebuild i would say. the tranny was in decent condition except for the 2nd gear synchro going.
its a florida car.
just take care of it man. no snow/bad weather/etc.
haha thanks man. i would def. look in az/ca for a clean s30 shell. when i finally get to that point of getting one that is what i'm going to do. learned the hard way this time around lol.
i'll have some more pics up sometime soon hopefully.
Post Title:
Posted by: gregfarz78 at 8:39 AM 7/29/2008
I recently picked up some rust bullet (b/c of this thread alone) man that stuff is great I can see now why you use it so much I wish I bought a gallon of it now. Goes on thick like molassis and dries rock hard, I brushed mine on only thing was it leaves obvoius brush marks its probably better to spray it on I was kinda afraid of clogging up the spray gun though. Don't get that crap on your skin either it takes a few days to come off lol
Posted by: RCA at 12:23 PM 7/29/2008
I just realized, the next time you purchase a S13 you will know every in-and-out.
You will know exactly where to look and figure out its value based on were and how bad it is rusted.
This is some serious knowlege. I can only hope you make a thread in the 240sx purchaseing advise section of NICO. You are unoffically NICO's rust guru.
Posted by: m tr4nch at 12:24 PM 7/29/2008
haha yeah man, the finish is pretty damn tough. and yeah spraying it on looks much nicer, but it doesn't cover everything (even though it looks like it). so i brush on the first 2 coats to make sure i get the coverage/thickness, and then spray 2 coats to make the surface pretty and even. made the mistake of not brushing it on first in the engine bay so now i have to go over it again and yeah that stuff won't come off for like a week if it gets on you lol
Posted by: m tr4nch at 12:42 PM 7/29/2008
i know the s13 chassis like the back of my hand now haha.
from what i've seen on my car and other people's threads, rust will start anywhere there is a seam (between 2 layers of metal). and in my case, start rusting from the inside out (like the frame rails & lower rad support).
the most common place i've seen rust forming so far is the top of the front shock towers where the reinforcement plate is:
Posted by: m tr4nch at 9:35 PM 7/29/2008
alright so here's what i've been up to lately. haven't got a whole lot done since i've been having to work a little more.
got the quarter panel piece trimmed down and test fitted:
got some patches cut out:
started welding up the hole in the floor from the seat mount:
yeah so not a whole lot but i'm getting there...
Modified by m tr4nch at 5:09 AM 10/10/2008
Posted by: ProphetZ_TuninG at 10:23 AM 7/31/2008
good stuff! keep us updated its rare to see people do things right!
Post Title:
Posted by: kick_it_sideways at 3:03 PM 7/31/2008
Hey man are you just filling most of those useless interior holes with welds?
Post Title: Re: (kick_it_sideways)
Posted by: m tr4nch at 2:04 AM 8/6/2008
Quote, originally posted by kick_it_sideways »
nah, that small weld spot you saw on the floor is me plugging up a screw hole since the previous owner had an amp drilled straight through the floor with some wood screws
and yeah looks like i hit the bandwidth limit on my photobucket :/ which will get reset on the 10th since i don't feel like spending any money on their pro account.
i haven't really got anything done lately since i've worked 51 hours in 4 days since last thurs
Posted by: m tr4nch at 2:09 AM 8/6/2008
so here's the news... i found some very disappointing shit...
sorry for the HUEG pics but this is the only way to see:
some other places...
i've emailed rust bullet about this to see what the fuck is going on
we'll see what happens..
i might try some por-15 on the floor section and see how it holds up compared to rust bullet.
edit: to clarify, those spots of rust coming through are only in areas where there was previously rust that i sandblasted. the rest of the undercoat i did in the rear for example still looks perfect.
Modified by m tr4nch at 5:28 AM 8/6/2008
Post Title:
Posted by: StricNyne at 5:22 AM 8/6/2008
aww that sux man ! if u want i can make a photobucket acct for u man and host some pics for you if u want
Post Title:
Posted by: UsJdmTuner at 5:23 AM 8/6/2008
oh wow... that is messed up.... i would defnitely try to get my money back....
Posted by: UsJdmTuner at 5:28 AM 8/6/2008
also.. ive used por15 and never had any problems... you might want to try using ZINC PRIMER.... zinc is good for inhibiting rust.. there are a few companies that sell them... i found zinc spray cans : http://www.safetyvests.com/S00...pound
........... that is the approach im going to take.... and then maybe layer it with por15 and rubber coating....
Posted by: homeslicej2 at 6:38 AM 8/6/2008
Sorry to see that man. Many of your pics don't show up right now bc you've exceeded the bandwidth on photobucket. Are you sure that you removed all the rust when you blasted it?
Posted by: m tr4nch at 1:12 PM 8/6/2008
so i got an email back, and basically what they are telling me is that it's not thick enough in those areas. so maybe i'll go over them again and see if it really stops it this time around...
yeah i might try out some por-15 on the floor. i think if i want to use it on the other places though i'd have to strip all the rust bullet off to the bare metal again for it to work. which would be like starting over. i got some weld thru primer also which is basically a zinc coating.
i definitely removed all the rust.. even if i didn't, the rust bullet is supposed to work directly over rusty metal anyway..
sometimes i just want to get a rust free shell and forget about this sh*t..
Posted by: RCA at 1:19 PM 8/6/2008
M Tr4nch I would start a Myspace account for your thread.
They use unlimited bandwidth that plus al the pictures end up the same size.
I accidentall deleted all my S14 pictures from my Myspace account and Myspace still has them up and running.
Post Title:
Posted by: kick_it_sideways at 1:22 PM 8/6/2008
Damn that sucks. I'm going through "project POR15" right now and seems to be working well. How long ago did you coat that area where the rust came back?
Even if there may have been small small amounts of grease/oil, the "rust killer" won't stick worth ****.
Posted by: m tr4nch at 1:41 PM 8/6/2008
then i'd have to go back and fix every picture link lol
that first pic is what i did last summer underneath in the rear (right around the muffler location, on the side of the frame rail). the second pic was my old rad support that i did in november 2006, and the other 2 are in the engine bay done in april 2007. i mean don't get me wrong, other than those spots, it's holding up really well.
and yeah after blasting the rust, i wiped down the metal with 3m adhesive wax and mark remover before coating, so that shouldn't be a problem.
Posted by: RCA at 1:48 PM 8/6/2008
Well I guess your only other option would be to go with the photo bucket pro then.
Just trying to save you some $
Posted by: m tr4nch at 1:54 PM 8/6/2008
you sure it's unlimited bandwidth?
Posted by: RCA at 2:12 PM 8/6/2008
Well I will be honest.
Idk for sure, but I have heard other people from this forum and other forums that it does use Unlimited Bandwidth.
But I am sure a email to Tom or a look at Myspace's policy would do the trick
Posted by: BIGTIMER_240 at 3:49 AM 8/7/2008
can you pls tell me all the part numbers for the radiator support thanks i just had a car accident and remember of this thread,
Modified by BIGTIMER_240 at 6:32 PM 8/7/2008
Post Title:
Posted by: xckid at 4:22 AM 8/7/2008
hey what happend to all the other pics? in the thread
Post Title: Re: (BIGTIMER_240)
Posted by: m tr4nch at 10:51 PM 8/7/2008
Quote, originally posted by BIGTIMER_240 »
lower support: 62530-53F25
upper support (89-90): 62510-40F00
upper support (91-93): 62510-53F00 (has the reinforcement pieces)
if you just want the entire front core: 62500-53F00 (upper support has the reinforcement pieces)
Posted by: m tr4nch at 10:56 PM 8/7/2008
Quote, originally posted by xckid »
so anyways.. i did a quick search on google for por-15 and rustbullet, and apparently i'm not the only one having this problem of the rust coming back from using rustbullet .. so i will be getting some por-15 and using that for whatever else i have left
pisses me off though that i had to find this out now after already using it
hopefully i can just patch up those areas that are showing rust-through (with my remaining rustbullet) and spray some rubberized undercoating over it so no air/moisture can do that again.
and if worse comes to worse i will just strip the rustbullet off the places i sandblasted and recoat with por-15. hopefully i won't have to go through all that though.
Posted by: op.tic at 12:22 AM 8/8/2008
hmm.... well i ordered some rustbullet a couple days ago for my 240 project and my truck frame. thats weird that rust would be forming on/coming through the rust bullet. maybe i'll look into doing a coat of a zinc primer first. i was thinking eventually getting all the areas coated with rust bullet top coated with something like eastwood's ceramic rust inhibitor for a harder and better looking satin black finish... that stuff looks indestructible.
good luck man. keep up the good work
Posted by: BIGTIMER_240 at 2:30 AM 8/8/2008
thanks alot oh and your project
Post Title:
Posted by: xckid at 2:34 AM 8/8/2008
ohhhh bandwith ftl
must have read over that ....my bad keep up the good work!
Post Title:
Posted by: gregfarz78 at 4:28 AM 8/8/2008
That's disappointing news about the rust bullet I used it on my floor boards but I think I'll use something else for the wheel wells and engine bay. Zinc primer is supposed to be good **** they use it a lot in commercial construction to coat welds since the actual weld bead is the first place rust is going to start.
Post Title:
Posted by: UsJdmTuner at 9:27 PM 8/9/2008
just sand the rusted areas i guess.. and coat por15 over it....i was so close to buying rust bullet.. well we all learned a lesson this time.. DONT GIVE UP... you put lots of work and effort already... keep doing what you are doing...
Posted by: Neil at 4:32 AM 8/13/2008
OP,
You are indeed a madman. It's too soon to be performing ground-ups on an S13. If it were a 240Z or a 510 I'd understand. That is not to say I'm not blown away by your patience and aptitude, I'm just saying I'd have a difficult time placating you if you told me you were perfectly sane.
p.s. I use Bill Hirsch rust-stopping paint and it sometimes does something similar. The rust continues to form and it cracks open the surface of the paint a week after it cured. But that's usually an indication that what I'm painting over isn't the complete source of the problem.
Post Title: Re:
Posted by: Murdered_T at 1:12 PM 8/13/2008
awsome build man, you pay attention to detail like you have been doing this for years.
Post Title:
Posted by: ca20det at 8:10 PM 8/13/2008
dude welcome in the insane club but you deserve the title of the insaniest ! damn man it must have cost you a buttload of money!!!
its pretty much as rusted as mine was!! nice results so far!! keep it up!!
Posted by: Huncity240 at 2:32 PM 8/21/2008
why didnt you acid dip the whole car. would have gotten rid of the rust,seam sealer and undercaoting ****. this is after you stripped every last piece of metal plating and everything.
Post Title: Re: (Huncity240)
Posted by: m tr4nch at 11:08 PM 8/21/2008
well, maybe i'm an idiot or i didn't do enough reading/searching before, but i figured out that after sandblasting i should have used some kind of metal prep on the bare metal before painting with rustbullet or any other rust stopping paint. i thought the 3m adhesive/wax/mark remover would be enough but apparently not. i came across this stuff picklex20 and got a spray bottle. seems to be working really well so far.
also in my researching, i came across this thread Rust Preventive Product Test and what it shows is that rust bullet, por-15, eastwood, masterseries, etc. all basically do the same thing and perform similarly.
i bought some masterseries silver, satin black, and gloss black to use on the parts i have left to do. check it: masterseries
Post Title: Re: (Neil)
Posted by: m tr4nch at 11:15 PM 8/21/2008
Quote, originally posted by Neil »
OP,
yeah i know i'm nuts haha. thanks for the compliments.
Quote, originally posted by GOnissanTOM »
thanks!
Quote, originally posted by ca20det »
haha yeah man! thanks for checking my thread out, you definitely are beating me with getting sh*t done though haha.
Quote, originally posted by Huncity240 »
i thought about doing this a long time ago actually. but it's pretty expensive, and it's a lot easier said than done. there's a lot of work you'd have to do afterwards to get all the metal coated again... ALL of it. so i went this route instead.
Post Title:
Posted by: mrgreeneyes at 11:29 PM 8/21/2008
after battling rust on my coupe during its restoration this past winter... i found spots that are rerusting under my undercoat... i was just as pissed as you are now... so now i gotta throw her in the air again, strip it back down... and redo it
Post Title: Re: (mrgreeneyes)
Posted by: DruidAT at 12:56 AM 8/22/2008
What kind of welding are you doing?
Posted by: Huncity240 at 8:10 AM 8/22/2008
isnt there another dip that they put the car in thats a coating and you have to take it off for paint and undercoat so its pretty much just in the frame rails and stuff. Idk man i know its expensive but the idea of 100% zero rust is awsomw. like if you miss one tiny little spot in the frame rails or something its all just gunna come back later. props tho this is amazing thread.
Post Title:
Posted by: s13gebala at 5:00 AM 8/23/2008
youre crazy with the oem nissan ****!
i know that those paddle combo switch lights are 200$ and you have so much oem stuff!
Post Title:
Posted by: n.r.wyatt at 3:34 PM 8/31/2008
Your build is inspiring to continue to push through the rust and junk i find on my build. You have any pics of the new sections of frame rails you welded in?
Thanks
Nick
Post Title: Re: (n.r.wyatt)
Posted by: sldewyz at 11:56 AM 9/2/2008
this thread is down right amazing. this is exactly what i want to do to a s13. tear it down fix everything, start rebuilding it then have fun w/ it. you are doing an amazing job at everything. is anybody helping you with this? i know you said youve done it all by yourself but i didnt know if your dad or someone else helped ya out alot.
this is especially sweet because you are doing everything correctly. Where are you doing it all? in your garage?
Post Title: Re: (sldewyz)
Posted by: S13_love at 12:10 PM 9/2/2008
that is some true dedication right there, well anyways im about to get an s13 240, so can anyone tell me should i be expecting some major rust problems, cause i heard thats what 240's were known to have
Posted by: m tr4nch at 10:01 PM 9/2/2008
Quote, originally posted by mrgreeneyes »
def. does suck
Quote, originally posted by DruidAT »
mig
hahaha. i just made another order from nissan actually. should be here in a few weeks
Quote, originally posted by n.r.wyatt »
Thanks
Nick
thanks man. glad to be inspiring
i actually haven't got to replacing those pieces of frame rails yet. will definitely post pics when i do (as usual).
Quote, originally posted by sldewyz »
thanks so far everything up to this point has been done only by myself. my dad helped me out with the dolly and loaning me some of his tools every once in a while, but all the car related work has only been done by me. and yes, it all goes down in my garage.
Quote, originally posted by S13_love »
depends on where you live, how the previous owner(s) took care of the car, etc. imo, look over the car really good before you make any decisions, especially underneath. if some pieces of the suspension are rusty and the actual chassis is good, i would still get it. those kinds of parts can be easily replaced. but cutting/welding on the chassis is a lot harder obviously. just do some looking around for the right one and be patient.
Posted by: DruidAT at 4:51 PM 9/3/2008
where do you get your oem parts? i need some frame parts to be replaced on my kouki.
Post Title: Re: (DruidAT)
Posted by: BMAR240SX at 6:14 PM 9/19/2008
You are out of your mind man, i support you but than its like. What are your plans for this car are you going to keep it forever or something?
Post Title:
Posted by: ny240gtr at 7:24 PM 9/19/2008
god bless your 240
Post Title:
Posted by: UsJdmTuner at 8:34 AM 9/20/2008
any updates?
Posted by: 240lookis at 12:30 PM 9/20/2008
the is probably the most in depth and ridiculous build ever.
Post Title: Re: (240lookis)
Posted by: nstabl at 1:03 PM 9/20/2008
Post Title:
Posted by: ANVIL at 1:31 PM 9/20/2008
so when do you plan on having it back on the road
Post Title: Re: (ANVIL)
Posted by: m tr4nch at 4:08 PM 9/20/2008
updates are coming. i've been real busy lately.
Quote, originally posted by BMAR240SX »
yeah i plan on keeping it forever. unless it gets wrecked beyond repair somehow.
Quote, originally posted by ANVIL »
honestly i don't know. i hope to have all the rust gone by the end of the month/beginning of october. once i get over that hump, it will be a lot easier for everything else to get done.
Posted by: Wongger at 4:31 PM 9/20/2008
You.... You are awesome. I would not have the patience to do what you are doing... You must be very loaded..... NICE WORK
Post Title: Re: (Wongger)
Posted by: Adictd2b00st at 4:34 PM 9/20/2008
thats some dedication right there, nice job saving her!
Post Title: Re: (Adictd2b00st)
Posted by: BrownDogg at 9:01 PM 9/23/2008
Awesome build! At first i was like... your cars rusty. lol, But damnn has it come along way! Good luck man
Post Title:
Posted by: exhsturbine at 1:44 PM 9/27/2008
i just found this project.... and all the photos are blocked because you have exceeded your bandwidth. and from all the compliments it seems like a good job... i want to see!!!
Post Title: Re: (exhsturbine)
Posted by: rsdans240sx at 2:36 PM 10/2/2008
:bump: fix your pics please
Post Title: Re: (rsdans240sx)
Posted by: tEknoS13 at 9:13 PM 10/8/2008
DEMAND updates with LOTS of pictures!!! lol
Post Title: Re: (tEknoS13)
Posted by: Ghostdrifter88 at 9:14 PM 10/8/2008
i second that
Posted by: m tr4nch at 2:38 AM 10/10/2008
Quote, originally posted by Wongger »
Quote, originally posted by Adictd2b00st »
Quote, originally posted by BrownDogg »
thanks to all.
Quote, originally posted by exhsturbine »
Quote, originally posted by rsdans240sx »
bandwidth got reset today. i made some more photobucket accounts and updated my older posts with new links so that i don't go over anymore
alright so here are some updates.
got the bottom quarter panel piece welded up. i tried my best not to warp it, but it still warped a little. not that big of a deal though since that area will require a little bit of bodywork anyways.
how's my welding now?
can't really tell that well from this pic, but rear bumper fitment is like perfectly aligned.
ready to blast the interior.
blasted and treated with metal prep acid.
remember these areas?
BAM!
and this guy:
patches cut out and trimmed down, prepped, and ready to be welded up:
Post Title: Re: (m tr4nch)
Posted by: m tr4nch at 2:53 AM 10/10/2008
did i forget to mention i got some new parts?
picked up an authentic gp sports g-sonic type r rear valance.
AND... i got my latest nissan order
z32 2+2 e-brake cables
fog light kit. came with everything but the switch and directions :/
speaking of switches...
cigarette lighter assembly, door strikers, hood bumpers
hood hinges, transmission shifter boot
all new lock cylinders. before anyone asks, yeah they are all different and each come with a different set of keys. ALL of the packaged sets were discontinued, and this was the only way to get new ones. i'm gonna have to get them all repinned to one key to make everything easier.
picked up this jdm tyte lighted ignition key ring from ebay
z32 e-brake shoe set, front/rear caliper hardware
front s14 dust shields
new door handles (the dull area is just grease from lubing that spring)
zomg new power window switch bezel/door handles (with new passenger switch)
these actually have a texture on them. not like the shiny worn down ones you always see.
new rear 5-lug hubs and expensive z32 bearings with the lip
bunch of random screws/bolts/nuts/clips/plugs/etc
i guess that's it for now. got a little more sandblasting to do. then some welding and painting underneath, and it will be ready for the body shop!
Post Title:
Posted by: StricNyne at 5:37 AM 10/10/2008
gettttttttttttttttttttttem **** is lookin nice man !!!
Post Title: Re: (StricNyne)
Posted by: tEknoS13 at 10:26 AM 10/10/2008
nice work man. seeing all that oem nissan stuff makes me happy perhaps its because i just got my order for z32 brake hardware
Posted by: AreszONE at 11:22 AM 10/10/2008
Wow! Awesome build. This thing is going to be showroom quality when its finished. Great stuff man.
Posted by: RCA at 11:24 AM 10/10/2008
OMG Tr4nch!
You make my head hurt.
You take 0 shortcuts and do it 100% right!
After seeing this thread I could estimate that this car is worth 10k+.
It is brand new!
HOLY SH*T it is comming out great!
Posted by: sbird1 at 7:20 PM 10/10/2008
First time viewer, but I'm already a big fan. Amazing work so far.
Post Title: Re: (sbird1)
Posted by: Ghostdrifter88 at 7:51 PM 10/10/2008
i think you should get a custom title for this great ****.
great work man.
Post Title:
Posted by: gregfarz78 at 7:25 AM 10/11/2008
holy crap you must've spent a small fortune on all those oem parts
Posted by: Ghast at 12:11 PM 10/11/2008
I can promise you that it is not anywhere near a SMALL fortune.
And the car will easily be worth WAY more then 10 Grand when hes done.
I would say at least, 14 Grand with everything but the engine in it.
Tr4nch you better not Ever sell it. And if you one day decide oh i wanna give up on it i will be the first on the list. I would be more then happy to pay that much for that thing Painted with no engine.
Do you plan to race it? or just restore it and collect it? maybe a little bit of both?
Beautiful man, Just beautiful! Keep up the good work!
Are you keeping record of all the part numbers you are ordering?
Post Title: Re: (Ghast)
Posted by: MastaYu at 4:05 PM 10/11/2008
wow nice bunch of parts
Post Title: Re: (Ghostdrifter88)
Posted by: m tr4nch at 5:53 PM 10/11/2008
thank you everyone for the comments
Quote, originally posted by Ghostdrifter88 »
great work man.
if i could get one, it would have to be "insane rust killer"
apparently my chassis dolly write up isn't worthy of a custom title so i was thinking if i have time i might do one for how to fix rust the right way
as for the cost of the oem stuff. it's actually not all that bad. only thing i regret getting was the stupid expensive z32 rear bearings with the lip on them. i could have sourced the "other" anchor pins for the e-brake assembly and got the cheap non-lip bearings and saved myself almost $200 oh well.
i was going to get all new glass also but it would have been another $2,300 for everything after the 20% discount i might still just get a new windshield but i'll worry about that later.
and like i said before, i don't plan on ever selling it. my plan for the car is mostly daily driving, only in nice weather of course. i probably won't drive it in the rain anymore, and definitely not in the winter (or at least up until the first snow falls). the only water this car will see is when i wash it haha. and it will be garage kept. i will be doing spirited driving and might do some autocross at the track occasionally just for fun, but that's about it. most likely won't be doing any drifting. i think grip is cooler anyways
and yes, i have a huge excel sheet with all the parts i've ordered, and others on there if i need them in the future.
Posted by: tEknoS13 at 8:58 PM 10/11/2008
About that custom title..... how about "240sx Porn Director" great job
Post Title:
Posted by: Logan76 at 9:22 PM 10/11/2008
The company I work for does abraisive blasting, Sand, Glass Bead, Alluminum Oxide, steel shot. Ive done them all when we slow down and theres no mechanical work for me to do, and Ive always wondered how a car would turn out if it was blasted, well now Ive found out. Looks great man. Nice project.
Posted by: m tr4nch at 8:27 PM 10/12/2008
haha
Posted by: tEknoS13 at 8:30 PM 10/12/2008
I know you like
Posted by: 137 at 8:53 PM 10/12/2008
This thread was badass, subscribing if possible.
Post Title: Re: (137)
Posted by: adollarwodbnice at 6:15 PM 10/13/2008
This thread makes me wanna get a 240 so much more now....
Post Title:
Posted by: QuicksilverFX at 6:36 PM 10/13/2008
Where did you order all your parts from? If you don't mind me asking.
i can't wait to see more on the car. i wish i had the money and a garage to do something like this to my s13, i got lucky on getting a decent chassis tho so if i keep it clean it wont get any rust.
Posted by: tEknoS13 at 10:18 AM 10/14/2008
dude he posted where he got his parts from like 3 times already. http://www.midwaypartsteam.com
Post Title: Re: (QuicksilverFX)
Posted by: m tr4nch at 10:56 AM 10/14/2008
Quote, originally posted by QuicksilverFX »
yes i did, thank you haha
Post Title:
Posted by: tjmhillz at 11:00 AM 10/14/2008
damn matt your car is coming along nice.. when i get home ill help out.. ill be carless for a while though dropping my car off in delaware to get some goodies done to the motor heheheh
Posted by: tEknoS13 at 11:17 AM 10/14/2008
Quote, originally posted by m tr4nch »
You're welcome.
Posted by: m tr4nch at 9:13 PM 10/14/2008
alright, got some good news and some bad news. bad news is that i have to get my car out of the garage by saturday but the good news is that i am renting a garage about 20 mins from my house with lights/electricity i just need a trailer to transport the car there.
Modified by m tr4nch at 1:42 AM 10/15/2008
Post Title:
Posted by: gregfarz78 at 5:15 AM 10/15/2008
rent a uhaul?
Posted by: tEknoS13 at 9:00 AM 10/15/2008
That sucks man I know how it feels when you're under pressure due to parents complaining about the garage.
Posted by: sbird1 at 3:33 PM 10/15/2008
At least you still have a place to work on the car. When my parents wanted my shlt out of the driveway, I had to sell everything for super cheap.
Post Title:
Posted by: TwoJayZee240 at 7:26 PM 10/16/2008
Hey Matt, I was wondering where would you purchase dry ice? and how did you use it to remove the black sealed cardboard stuff that is on the floor boards when you stripped it? I tryed to get it off but its stuck on there pretty good. Thanks-Ryan
Post Title: Re: (TwoJayZee240)
Posted by: ILUVJDM at 7:51 PM 10/16/2008
got my dry ice from my brother wen he used to wrk in the airport. its a simple process just place the dry ice on it until it freezes than hit it wit a hammer n it should just crack juss dont touch dry ice it will burn
Post Title:
Posted by: gregfarz78 at 7:53 PM 10/16/2008
You can get dry ice and most places that sell ice. Go to google maps punch in your address then under find business type in dry ice or call some beer distributors in your area and see if they carry it if not ask them who does they'll probably know.
Posted by: RCA at 8:49 PM 10/16/2008
Or you can pass by a Pharmecy (can't spell) and ask for some.
They get atleast one package of meds sent to them a day covered in dry ice.
Then they throw it out...
Take it off their hands, I am sure they won't mind
Posted by: m tr4nch at 12:18 AM 10/17/2008
i got the dry ice from a mom n pop type of fuel/ice place.
so i got the car moved into my new work area last night. huge thanks to carlos (StricNyne) and my buddy jeff for helping me out. i did end up getting a 6x12 open trailer from uhaul and the car fit in there like perfectly. i forgot to take pics though. we managed to load it, transport, and unload it without any problems thankfully, i just wish i had some more straps to use. now i just have to move my welder and a bunch of other crap in there and i'll start getting some stuff done.
AND, i am done with the chassis sandblasting w00t!
so my car is rust free now, well as much as i can help it anyways. still have to do some small spots on the fenders, doors, random brackets. but other than that, all that's really left is welding up all the patches and some painting
here are some action shots of me doing some sandblasting yesterday before we made the move:
Posted by: MoldyOldy240 at 7:59 AM 10/17/2008
You are my hero right now!
I really like the attention to detail that you are showing here. With that being said, if I send my car to you with a big bag with a dollar sign on it will you do the same for me :P
Good build, keep us posted!
Post Title: Re: (MoldyOldy240)
Posted by: tEknoS13 at 10:59 PM 10/17/2008
m tr4nch, you should shows us the "SHOW STOPPER" next time.
Posted by: nightsauce at 11:18 PM 10/17/2008
i know you said they were expensive, but how much were the z32 hubs/bearings altogether? I'm in the midst of purchasing parts for my 5lug/z32 brake upgrade, but i havent purchased the hubs ( the key component i know :-( )
Posted by: m tr4nch at 12:30 AM 10/18/2008
Quote, originally posted by MoldyOldy240 »
thanks man! honestly i don't ever want to do this kind of crap again lol. it's a lot of hard, tedious work. although they say the first time is the hardest/longest right?
lol wut
the rear hubs themselves weren't bad, they were $101 each. the bearings with the lip though were $204.42 each
the price for the bearings w/o the lip was $90.34 each. big friggin difference. i should have just got those and searched for a pair of the thicker e-brake anchor pins (more info on that stuff can be found here).
oh well, the way i see it is that i won't have to buy new bearings for like another 10 or so years if that. so fcuk it
Posted by: antp at 6:14 PM 10/18/2008
That is the most sweetest thread ever keep it coming. you have just proved that no car is 100% rust free but you will be able to say MINE IS! GOOD LUCK man. JUST AMAZING
Post Title: Re: (antp)
Posted by: m tr4nch at 6:08 PM 10/19/2008
Quote, originally posted by antp »
thanks d00d
and thanks for your first post being in my thread haha.
Posted by: antp at 7:33 PM 10/20/2008
now that we got the meet and greet out the way how much to resore my 96.......
Post Title: Execelent Restore!
Posted by: WOLFANATOR13 at 8:03 AM 10/23/2008
1 million thumbs up on this restore! but also makes me cry when i look at my chassis' and know there is that much rust coming out on mine!
keep up the awesome work!
Post Title: Re: (AreszONE)
Posted by: hsckris at 9:08 AM 10/30/2008
Quote, originally posted by AreszONE »
+1 Keep it going man. Great job.
Post Title: Re: (hsckris)
Posted by: Stripes at 9:51 PM 10/30/2008
Amazing. Just amazing. This is now my new standard for my coupe build.
Quote, originally posted by tjmhillz »
There are goodies for a motor in Delaware?? ...That's news to me
Post Title: Re: (Touge')
Posted by: nightsauce at 8:24 PM 11/15/2008
you know what man. you really inspire me. I just picked up a shell 2 days ago and got into an accident yesterday (good timing bad situation). I need to rebuild my entire front end (rad support, etc.). Its still driving thank God but just needs a cosmetic fix, not to mention my hood and the latch dont line up, not safe. When i get the money i'm goin to fix it right just as you are. thanks for being a great inspiration.
Post Title: This thread is full of win.
Posted by: AreszONE at 7:32 PM 11/18/2008
Dude the more I look at this thread the more I get inspired. This is one of the most amazing 240 restorations I have seen. I can't wait to see the finished product. Keep up the amazing work.
Post Title: Re: This thread is full of win. (AreszONE)
Posted by: StandardProspect at 4:48 PM 11/24/2008
This is def my favorite thread of all time.
I have the exact same car, black 93 base model
first day i got it
mine was rusty as well, but you have inspired me to fix the rust!
my car will be rustfree by next week
Amazing job man
Post Title: Re: This thread is full of win. (StandardProspect)
Posted by: RCA at 7:22 PM 11/24/2008
Quote, originally posted by StandardProspect »
Amazing job man
Its funny because Trench started a thread while spending months and months trying to become "rust free" and you plan on doing it by next week?
I hope the previous owner gave you a 1yr head start
Post Title: Re: This thread is full of win. (rcabrita)
Posted by: StandardProspect at 7:33 PM 11/24/2008
i guess that did sound kind of rediculous
ive been working on my rust for a long time and the final step is getting the frame and part of the floorpan patched. My car is coming back from the motorsports shop next week all patched up
i didnt have as much rust as matt, but he inspired me to get all of mine fixed. his resto however is much more meticulous than mine.
Keep up the amazing work man
this is the best 240 restoration ive ever seen
Post Title:
Posted by: Coolwhip at 8:49 PM 11/24/2008
So this is where you been hiding, damn good thread man, awesome work.
Post Title:
Posted by: Kiwi at 4:33 PM 12/1/2008
that is pretty amazing...
i wish i had that kind of money for a restore like that. keep up the great work man
Post Title: Re: (Kiwi)
Posted by: Kaleo55 at 6:57 PM 12/1/2008
This is one of those great epic threads that are so amusing and amazing. Really good work man and great dedication to restoring this rusty ole 240. One of these days I'm going to get another one of these projects going. Good luck and I look forward to seeing more examples of your dedication and progress.
Post Title:
Posted by: StricNyne at 5:30 AM 12/2/2008
yeah tranch is the man !!! the guys dedication to perfection, and the work he did on my car is a direct reflection of his skill !!! his car once finished it gunna be balls to the wall
Posted by: breadbox at 5:59 AM 12/2/2008
Ahhh the rusting from inside out scares me. I don't want look.
Nice resto. I need those new interior door pieces now.
Post Title: Re: (breadbox)
Posted by: ThatSRguy at 1:54 PM 12/8/2008
i almost hate rust as much as Matt
Posted by: Hydroz at 6:16 AM 12/10/2008
Damn yo.. illest **** ive seen done to a 240 and youre not even finished! mad props to you, keep up the sick work. i too am inspired by this!!
Post Title: Re: (Hydroz)
Posted by: TomeiS13Redtop at 5:35 PM 12/10/2008
i think this is the best thread i seen thus far and im very happy it is inspiring so many people to do the same thing to there 240's. i have been in love with the 240sx ever since i saw my first 180sx drifting in japan. i hope that most of the people inspired by this thread will go threw with restoring theres rather than sending them to a junkyard and keep the s13 alive and strong,for as long as possible at least.
I LOVE MY S13!!!!
Post Title: Re: Execelent Restore! (WOLFANATOR13)
Posted by: m tr4nch at 6:10 PM 12/10/2008
Quote, originally posted by WOLFANATOR13 »
Quote, originally posted by hsckris »
first day i got it
Amazing job man
Quote, originally posted by Kiwi »
Quote, originally posted by Kaleo55 »
Quote, originally posted by breadbox »
Quote, originally posted by Hydroz »
Quote, originally posted by TomeiS13Redtop »
I LOVE MY S13!!!!
thank you everyone for the comments. i'm happy that i'm inspiring all of you it makes me feel good about what i'm doing and keeps me motivated.
sorry there hasn't been any updates in a while, i've been busy with "life" stuff lately hopefully soon though i will have some updates for you guys.
Posted by: m tr4nch at 6:14 PM 12/10/2008
thanks man. i saw your thread best of luck with everything.
Quote, originally posted by Coolwhip »
haha thanks man.
Quote, originally posted by StricNyne »
i try not to half-*** anything
Quote, originally posted by ThatSRguy »
lol
edit: 777th post.. am i lucky? heh
Posted by: carmo at 10:50 AM 12/15/2008
Wow!!!! Talk about going the extra mile. This is probably a pointless offer, but if you feel like taking a night of fabrication off, I can help. http://forums.nicoclub.com/zer...pters
This is a link to my z32 e-brake cable adapters in the Fabricators Market. With these, the whole swap is direct bolt on.
Good job thus far, and I'm looking forward to motor swap time
Post Title: Re: (carmo)
Posted by: m tr4nch at 11:59 AM 12/15/2008
Quote, originally posted by carmo »
i was actually looking at your adapter brackets. i'm holding off on buying anymore parts though until i know how much bodywork/paint is going to cost me. i'll let you know.
Posted by: chitown_240sx at 2:26 AM 12/26/2008
WOW!!! This is the best thread ever ... I usually don't read this things or stay on the forums long enough to read them but, damn. Wut your doing to ur car is the same thing I want to do to mine. I know u put up the links to where u got ur OEM placements parts but, the midwaypartsteam.com link does not work. Are those the only two u use???
Post Title: Re: (chitown_240sx)
Posted by: m tr4nch at 12:26 PM 12/26/2008
Quote, originally posted by chitown_240sx »
thanks yeah they actually changed their website name to http://www.onlyfactoryparts.com so try that instead.
Posted by: jpnissans13 at 8:11 PM 12/28/2008
wow.. dude unbelievable work!
u are like my hero now!!
Posted by: Z_Fanatic at 5:41 AM 1/9/2009
Very cool thread, you really went ballz to the wall with this project. My hats off to you, I used to have a rusty old 91, I did some rust patching and welding on her as well. This thread brings back memories
Keep it up!
Post Title: Re: (Z_Fanatic)
Posted by: ILOVESILVIA(S13) at 10:10 AM 1/10/2009
Is this project still going on? If so, I would love to see some updates!!!!!!!!
Props to you Sir!!
Post Title: Re: (ILOVESILVIA(S13))
Posted by: mcheddadi at 9:06 PM 1/14/2009
UPDATES! I DEMAND THEM!
Post Title: Re: (mcheddadi)
Posted by: m tr4nch at 1:35 PM 1/17/2009
sorry guys, no updates yet. cold weather + snow/rain + 20 min drive each way = nothing done lately :/
as always, thanks for the comments.
Posted by: Kaleo55 at 8:01 PM 1/20/2009
Dude, I hope you have this baby ready by the time we get our Spring meet together...LOL it's been taking us along time to get it together too...
Post Title: Re: (Kaleo55)
Posted by: bagnasco at 7:14 PM 1/21/2009
This is awesome work man. I plan to do this with my car and I was wondering what you are using to find all the parts you need?
Is it a catalog or the internet or what?
Posted by: TroubleBound at 9:05 PM 1/21/2009
how many times...?
Post Title: Re: (TroubleBound)
Posted by: m tr4nch at 10:59 PM 1/21/2009
Quote, originally posted by TroubleBound »
how many times...?
yeah srsly it's been posted about 5 times now. midway did change the url though, it's http://www.onlyfactoryparts.com now.
Post Title:
Posted by: CRyan at 11:21 PM 1/21/2009
I know a little off topic with this thread because this is an S13 car your working on - but I just went to the website posted above and had a quick question someone who would be viewing this might know - The nismo coilover setup - isn't it just JIC with nismo slapped on it?
Posted by: tEknoS13 at 11:50 PM 1/21/2009
3 times, however m tr4nch has a new record of 5 times........
Post Title:
Posted by: [S]eraph at 8:26 AM 1/22/2009
love the painted calipers, gives me ideas...
Post Title: Re: ([S]eraph)
Posted by: mallbor240SR at 10:42 PM 2/1/2009
nice job man, i wish i could do the same
Post Title: Re: (jpnissans13)
Posted by: ca20det at 10:58 AM 2/2/2009
really good job man but you should as much as possible avoid continuous welding beads... you should rather use plug welds and seal the edges of your pieces welded on.... you should also gring a little bit your welds to avoid moisture to stay in all the crevasses of the welds/porosity.... as for the parte you took off from where the front seat was bolted to, you really should replace these because they serve a purpose of spreading the impact load in case of an accident instead of the bolt tearing the surrounding metal
Post Title:
Posted by: spooled240 at 5:37 PM 2/2/2009
man unbelievable amount of work but that is gonna be one kick azz s13
Post Title: Re: (spooled240)
Posted by: slow40 at 12:23 PM 2/5/2009
love the two flood light approach, one for light, other for heat
Post Title:
Posted by: soupmotorsport at 7:59 AM 2/6/2009
good job on it matt! keep up the good work!
Post Title: Re: (ca20det)
Posted by: m tr4nch at 11:57 AM 2/6/2009
thanks for the tips man. the only reason i'm not overlapping the metal and doing plug welds is because i'm trying to avoid the seams rusting between the 2 layers of metal again. and trust me, those seat mounting braces will be replaced with 16 gauge plates on both sides.
the only real big things i have left to do is fab up my patches for the frame rail sections, seat mounts, and door hinge mounts, and that will basically be it. i already have the sheet metal cut out and bent, i just have to trim everything down for fitment and weld everything up.
Posted by: krayzie94 at 3:01 PM 2/6/2009
What thickness of metal will you be using to patch up the rails?
Post Title: Re: (krayzie94)
Posted by: m tr4nch at 10:12 PM 2/6/2009
Quote, originally posted by krayzie94 »
2 layers of 16 gauge. check back a few pages, there are a couple pics of it.
Posted by: Sabot at 1:32 PM 2/7/2009
Nice work man and keep it up cause I can't wait to see the finish product.
Posted by: stevecap at 2:04 AM 2/14/2009
man this project is so sweet i was gonna roll on mine but just got laid off wed night so it has to get put on hold.
Posted by: punk138 at 11:30 PM 2/18/2009
hey great build thread.
i dont know if i missed it, but i was wondering where you acquired your motor from?
im looking forward to my future rb build and definitely using your thread for reference.
Post Title: Re: (punk138)
Posted by: m tr4nch at 10:41 AM 2/19/2009
Quote, originally posted by punk138 »
i got the motor from heavy throttle back when they still sold rb's. they actually sold me their last rb25 back in '05 because they were having problems with their shipper receiving the motorsets with rb20 trannys mounted (i had to wait like 2-3 months before they got a good one with a rb25 trans). thanks to jeff over there, he hooked me up with some free AN turbo coolant lines.
Posted by: jungle at 8:26 AM 2/23/2009
Hey man, been following this thread for awhile now, and definitely have to give you some major prop-age(not a word) for your dedication, passion and hard work.
I almost feel the need to start a donation to get you some heating in the garage so you can work it out during the winter as well.
I, along with everyone else on this forum is anxiously waiting on the conclusion of this rebuild, so please don't give up!!
Some magazine should do a interview on you I swear. But either way, if your garage is anywhere near the city, I'd love to come by one day with some of my friends, just to admire the hard work and see if we can squeeze some advices out of you, and see if we can help out or anything.
peace.
I'll be patiently waiting for your next update!!
Post Title: Re: (jungle)
Posted by: KillTheApex at 12:57 AM 2/26/2009
Respect.
Inspiring.
Keep the updates coming man. I will see this through to the end with you. Like Sam and Frodo...but not gay.
Post Title: Re: (KillTheApex)
Posted by: CM_Nismo at 10:04 PM 3/3/2009
So when are you going to show off some more updates
Posted by: treken2t87 at 10:56 PM 3/10/2009
This is my favorite build thread on Nico, hands down
Keep up the good work and I'm standing in a very long line of people that can't wait to see this thing completed
Post Title: Re: (treken2t87)
Posted by: 5sixS12eight2 at 7:19 AM 3/25/2009
i said i wanted to get a 240 and build from ground up but is it possible for me find one this old without the massive rusting? i figured that his 240 was exposed to way different elements than we see here in the south so that could have contributed big time to his rust problems
Post Title: Re: (5sixS12eight2)
Posted by: wynnEZ at 8:10 AM 3/25/2009
Yes its possible but very hard to find one these days.
Posted by: gregfarz78 at 8:18 AM 3/25/2009
Quote, originally posted by 5sixS12eight2 »
yes it should be possible you live in texas its hot and dry there, if you lived where I do we pay a premium for a rust free 240 everything over 10 years old around here starts turning into a rust bucket unless its garage kept
Post Title: Re: (gregfarz78)
Posted by: XMSducksauce at 3:25 PM 4/4/2009
I have now read every page of this thread, but that's nothing like the dedication to this rebuild. Now subscribed Oh how I want to do this. Amazing work man, and keep it coming!
Post Title: unreal
Posted by: 5thgearks at 9:59 PM 4/28/2009
Now that is dedication holly s*** lol
Posted by: Hijacker at 7:01 AM 4/29/2009
Quote, originally posted by gregfarz78 »
A lot of texas isn't really that dry. Arizona is probably one of the best states to find rust free shells sitting in it.
Post Title: Re: (Hijacker)
Posted by: Philipio at 10:13 AM 4/29/2009
Yeah, we get some rain every once in a while and ice one or two days a year usually. It's not bad though.
Post Title:
Posted by: gregfarz78 at 1:44 PM 4/29/2009
we need updates!!!
Posted by: XMSducksauce at 12:50 AM 4/30/2009
I demand updates! plz?
Post Title:
Posted by: Dmct90 at 11:14 PM 5/10/2009
Bump for update!
Post Title:
Posted by: dsastr_clan at 1:47 AM 5/14/2009
updates!!??
Post Title: Re: (dsastr_clan)
Posted by: Bumnah at 4:41 AM 5/14/2009
Wow. Excellent work sir!
Post Title: Re: (Bumnah)
Posted by: a_ahmed at 5:19 AM 5/14/2009
man i wish there was someone in canada i knew that could restore my 240 the way you are doing it.
Post Title: Re: m tr4nch's restoration/build thread !! (bigtony08)
Posted by: tlkq at 8:09 AM 5/14/2009
Subscribed
Post Title: Re: m tr4nch's restoration/build thread !! (tlkq)
Posted by: m tr4nch at 7:01 PM 5/18/2009
thanks everyone for the kind words and support. updates will be coming soon!
Post Title: Re: m tr4nch's restoration/build thread !! (m tr4nch)
Posted by: MICRoS13 at 7:30 PM 5/18/2009
Great inspiration wish i had your knowledge
Posted by: 1990-240sxsr20det at 8:37 PM 5/18/2009
WOW!!!
That is all I can say about this.
I read through your entire build.
Took forever but well worth it.
Your dedication to doing absolutely everything right is inspirational lol.
Huge props to you man.
Post Title:
Posted by: yoesh! at 6:53 PM 5/28/2009
Can I ask where you get all your OEM parts, like the 3rd brake light and stuff like that?
Post Title: Re: (yoesh!)
Posted by: gregfarz78 at 7:24 PM 5/28/2009
Quote, originally posted by yoesh! »
its in the thread somewhere but you can find OEM parts from courtsey nissan online too
Post Title:
Posted by: StricNyne at 1:43 AM 5/29/2009
yooo tranch postup some pics we goin to e town in june 27 / 28 tooo son
Posted by: TimTurboZ at 7:57 PM 5/29/2009
Reading this thread makes me sooo glad I live in Cali. My shell sat outside uncovered for 2 years before I bought it. I have yet to see rust anywhere...yea All you East Coasters can hate
Post Title: Re: (TimTurboZ)
Posted by: m tr4nch at 7:03 PM 6/9/2009
small update.
here's my car in the new space
currently working on the upper door hinge patches. what a bitch...
left=original, middle=paper templates, right=roughly cut & bent
working on the driver's side first. after some trimming, fits like a gloovvvve
what it looks like without the patch (for comparison):
stay tuned
Posted by: XMSducksauce at 8:01 PM 6/9/2009
beautiful
Post Title: Re: (XMSducksauce)
Posted by: hbpignosePA at 8:12 PM 6/9/2009
hey i heard/saw you were at the meet sunday..... i didnt get a chance to talk to you at all.... nice work. hopefully next time we can see this one there too
Posted by: Didderson at 8:14 PM 6/9/2009
Good to see you got some inspiration from the meet it looks like lol.
Nice job, I pretty much suck at metal fab right now... but considering my lack of fab tools or experience I guess I shouldn't be concerned.
Post Title: Re: (hbpignosePA)
Posted by: m tr4nch at 8:25 PM 6/9/2009
yeah i was there. i talked to didderson for a min, checked out the rest of the cars, went and grabbed the cooler from my car, and next thing you know you guys up and left wish i got a chance to meet/talk with you and white comet. but the next one, whenever that is, for sure
Post Title: Re: (Didderson)
Posted by: m tr4nch at 8:27 PM 6/9/2009
Quote, originally posted by Didderson »
lol yeah man. that's it, i am going to beast this sh1t out and get it done
and thanks, yeah metal fab kinda sucks doing but it's sweet when things come out good.
Posted by: Dizel01 at 8:57 PM 6/9/2009
Yes!! Your back on the restoration!!
I also missed out on meeting you at the S-chassis meet. I was with WC, Didderson and HB Pignose. It was a good showing though. Def gotta do it again.
Posted by: Kaleo55 at 8:57 PM 6/9/2009
Sorry I didn't get a chance to meet you Sunday. There were a lot of people I would've liked to have talked to. Hopefully we can hook up at the next meet/cruise...
Post Title:
Posted by: stockbee at 11:51 PM 6/9/2009
quite a project you've got going on there.
Look forward to seeing the finished product.
Are you leaving the factory turbo on the car initially, or doing some mods to the RB before you put it in?
Post Title: Re: (Dizel01)
Posted by: m tr4nch at 7:55 PM 6/10/2009
Quote, originally posted by Dizel01 »
yessir, next meet for sure.
Quote, originally posted by stockbee »
i will be leaving the engine stock for a while. only things i will be replacing/upgrading for now are the normal swap-maintenance parts: timing belt/water pump/spark plugs/etc.
anyways, i finished the driver's side door hinge patches. just have to drill the holes for the bolts to go through. i didn't think it would come out as good as it did:
i will be working on the passenger's side in the next few days when i get a chance.
Posted by: 1990-240sxsr20det at 9:50 PM 6/14/2009
UPDATES!!! I want them LOL
Post Title: Re: (1990-240sxsr20det)
Posted by: RCA at 2:17 AM 7/7/2009
BUMP for updates please!
Posted by: RamonetB at 11:41 AM 7/17/2009
This... without a doubt.... is the most incredible restoration I've seen.
Do you have any idea the kind of inspiration you've given me to do all I can to keep my 240 going?
First thing I'm thinking of is the rust on the support rails.
SIR, I SALUTE YOU. (and give thumbs up)
Post Title: Re: m tr4nch's restoration/build thread !! (RamonetB)
Posted by: m tr4nch at 11:56 PM 7/18/2009
Quote, originally posted by RamonetB »
thanks d00d, i appreciate it. i love being able to inspire others.
as for updates, idk when that is going to happen because my mom got in a really bad car accident 2 weeks ago so i've been focusing all of my time on being with her.
anyways, before that i had just started working on the frame rail pieces.
so be patient and i will update when i get back into it.
Posted by: Dorgie at 4:02 AM 8/11/2009
wow i could only dream of doing something like this incredible
Post Title: Re: m tr4nch's restoration/build thread !! (Dorgie)
Posted by: barefoot mat at 9:00 PM 8/11/2009
damn .... that car had more rust than my dad's muscle car!
thanks for saving an s-13, hell ya.
Posted by: aefremov at 1:00 PM 9/2/2009
Amazing job!!!
I am actually doing similar type of restoration myself, mine rusted in exactly the same spots. So far I have fixed the drivers side strut tower bottom, both strut tower top plates, both rocker panels(reinforced them with 2x2 16 gauage channels on the inside), fixed driver side rail at the front, fixed rails at the back under the trunk, fixed drivers floor. and currently working on the driver side door hinge mount just like yours.
There is actually another piece underneith the top patch, but I think its ok, cause that thick piece inside where the door bolts go is structural. What gauage are you using for the patch? I am using 22 for the inside and planning to use 18 for the outside patch.
It is great to see someone doing the same type of restoration job.
Post Title: Re: (aefremov)
Posted by: m tr4nch at 9:21 PM 9/2/2009
Quote, originally posted by aefremov »
Amazing job!!! ....
thanks
yeah i know what you're talking about. there are 2 layers there because that's where the a-pillar and that bottom panel meet up so they overlap (over the other structural piece where the hinge bolts go). i found it to be pretty much the same thickness of metal to just throw on a single 16 gauge patch instead of 2 layers of thinner metal again (don't want to run the risk of them rusting out in between them again).
Post Title: Re: m tr4nch's restoration/build thread !! (barefoot mat)
Posted by: S13_love at 8:44 PM 9/3/2009
Quote, originally posted by barefoot mat »
Agreed.
Post Title: Re: m tr4nch's restoration/build thread !! (S13_love)
Posted by: sx moneypit at 5:30 AM 9/4/2009
saw john-s-13 project for the first time yesterday.nice bunch of parts .but i think yours is alot more tough of a project than his is . keep up the hard work it will be worth all the sweat
Post Title: Re: m tr4nch's restoration/build thread !! (sx moneypit)
Posted by: hbpignosePA at 9:33 AM 9/4/2009
dude i looked back through the thread.
i forgot you were going RB!
u think this will be done for the next philly meet?
hope to see it!
on a sidenote did you get the engine crossmember w the motor package?
i am looking for just an r32 crossmember
Post Title: Re: m tr4nch's restoration/build thread !! (hbpignosePA)
Posted by: m tr4nch at 7:26 PM 9/4/2009
hope to see it!
i got the (r33) crossmember seperately from jhot after i got the rb. and as far as being done soon/by the next philly meet, to be honest probably not (see one of my previous posts).
you guys going to d1 tomorrow? i'm gonna try and get there (it's about 20 mins from my house).
Quote, originally posted by sx moneypit »
thanks man. yeah it's tough because of the damn rust repairs, and yeah i hope it's worth it in the end lol.
Posted by: hbpignosePA at 7:50 PM 9/4/2009
ah ic....
nah i dont think we are going (im not)
i want to get alot more done on the s12 this holiday weekend
Post Title:
Posted by: sublimemoment at 10:03 PM 9/4/2009
wow...
Post Title: Re: (sublimemoment)
Posted by: splintercell at 10:49 PM 9/6/2009
INSANE RESTORATION BRO!!!!! im very thankful my car is a VA car. cant wait to see updates!!!
Posted by: comatoseculture at 4:19 PM 9/7/2009
Hey man,
Indeed your thread is truly great. It's unique, descriptive, and very enjoyable.
I wanted to say that I hope everything is ok with your mom. Much respect for being there for her. Hope everything gets better quickly. Thanks for taking all the time to post/read the stuff that was involved in making this thread. I'd like to shake your hand.
Post Title: Re: (splintercell)
Posted by: m tr4nch at 12:10 AM 9/8/2009
Quote, originally posted by splintercell »
thanks dude. i've seen your thread, your car is amazingly clean
Quote, originally posted by comatoseculture »
Hey man,
thanks man i appreciate the kind words. my mom means the world to me, and she's getting better every day so i'm happy. basically if i'm not at work, i'm at her house taking care of her/hanging out with her. so the car is on the back burner for now until she gets better.
... and i'm so close! lol
whoa 43,000 views too huh?
Posted by: adollarwodbnice at 6:29 AM 9/8/2009
Good s*** as usual... would love to build up something like this one day.
Posted by: splintercell at 6:46 PM 9/8/2009
family def comes first...take very good care of her
thanks man im glad i stayed up till almost 2am sat night reading your thread well you def have me beat in the most brand new oem nissan parts...you prob have more than anyone on the east coast...me maybe VA
you inspired me to go the extra yard this winter and finish my restoration and pick over the car with a keen eye.
Posted by: m tr4nch at 12:20 PM 9/12/2009
for sure man. thanks for taking the time to look through the whole thread.
as far as the oem parts, i wouldn't be surprised lol. and just to think, i still have at least one, maybe 2 more orders left to make one of these days
and like i said before, i'm glad i can inspire other people while doing all of this.
Post Title:
Posted by: StricNyne at 12:54 PM 9/12/2009
yeah, tr4nch is the man, hopefully when i get home i can give him a hand! i cant wait to see this rockiing and rolling
Posted by: StandardProspect at 1:09 PM 9/12/2009
Post Title: Re: (StandardProspect)
Posted by: Pdawg at 5:07 PM 9/12/2009
Nice job, i want to do something similar.
You said you had no previous auto experience, what did you use to help you through the project? Nico?
To me it seems like completely stripping down a car and building it back up would be very difficult not having any help/experience..?
thanks.
Post Title: Re: (Pdawg)
Posted by: m tr4nch at 3:24 PM 9/13/2009
Quote, originally posted by Pdawg »
thanks.
thank you. i just read a lot of things, did lots of research, and kept going with it. yeah i used nico, also zilvia, 240sxforums, random places found with google, etc..
but reading is one thing, actually doing it is where the real experience is. also i love doing resto jobs (mostly on smaller, simpler things though) so it's programmed in me and i always wanted to do a car. didn't think it would be my s13 though haha.
Posted by: StylesCD at 3:52 PM 9/13/2009
What're you plans for the engine?
Post Title: Re: (StylesCD)
Posted by: m tr4nch at 7:32 PM 9/13/2009
Quote, originally posted by StylesCD »
don't wanna sound like a dick, but did you read anything on the last page? it's in there, as well as elsewhere in the thread. sorry i'm just tired of reposting everything over again after a few times.
welcome to nico btw. enjoy.
Posted by: 2legit2quit at 7:59 PM 9/13/2009
nice
Post Title: Re: m tr4nch's restoration/build thread !! (2legit2quit)
Posted by: m tr4nch at 8:28 PM 9/13/2009
Quote, originally posted by 2legit2quit »
nice
yeah.
Posted by: Cody240 at 9:32 PM 9/13/2009
Man I can this you are one crazy F**ker man Mad respect i know what your goin through with this restore ive been working on my 1966 mustang for near 8 years trying to get the body perfect and the whole car the way i want it. I hope i can finally get my s14 so i can get back in the game of 240 owner ship and tuning. your thread is my inspiration to take on any project thanks dude for keepin with it
Post Title: Re: m tr4nch's restoration/build thread !! (Cody240)
Posted by: dinger240 at 9:47 PM 9/13/2009
It isn't really yours until you take it apart and put it back together.
Good Luck with the build
Post Title:
Posted by: SR20_FLO at 11:16 PM 9/13/2009
Wow man. amazing project your doing. Congratulations on everything uve accomplished. Truly an inspiration. And theres nothing better than building ur own car. Good luck with it and dont give up on it.
Posted by: StylesCD at 4:03 AM 9/14/2009
no im a
sucker for pictures :P
mostly i just see you're trying to suffocate the sucker using lots of shrink wrap
Posted by: slipknot555_666_69 at 9:23 PM 9/21/2009
thats alot of work money man
Posted by: MeanGreenS13 at 9:29 AM 10/2/2009
i need you to move to FL and work on my mustang with me =) great work bud! keep it up for sure!
Post Title: Re: (MeanGreenS13)
Posted by: TomeiS13Redtop at 5:51 PM 10/4/2009
i want more updates ive been waiting forever!!!!!!!!!!
Post Title: Re: (TomeiS13Redtop)
Posted by: slipknot555_666_69 at 8:01 PM 10/4/2009
second that
Post Title: Re: (slipknot555_666_69)
Posted by: eidk at 9:59 AM 10/6/2009
Such a great job. The attention to detail is remarkable. Cant wait to see more updates on this
Post Title:
Posted by: JoseBronx at 10:24 AM 10/6/2009
Im amazed at the time and patience people have
Post Title:
Posted by: SR20_FLO at 10:34 AM 10/6/2009
No updates???????
WATS GOING ON???
Post Title: Re: (SR20_FLO)
Posted by: m tr4nch at 11:36 AM 10/6/2009
thanks guys
but.. i guess no one was reading my posts on the last page
and josebronx i think you're the only other NT'er on here besides me hah
Posted by: blazinrola80 at 12:45 PM 10/6/2009
nice resto.. alot of man hrs.. spent.. reminds me when i wes retoring my corolla.. good job
Posted by: Weapon at 12:12 PM 10/13/2009
Just wanted to say that I think your rebuild is amazing!
Post Title: Re: (Weapon)
Posted by: MeanGreenS13 at 4:27 PM 10/13/2009
GET ON IT BRO!!! LoL
Post Title:
Posted by: Bumnah at 6:58 PM 10/13/2009
The only real restoration build thread on Nico.
Posted by: lucky03602 at 9:31 AM 10/17/2009
ive been suscribed to this post since withing 2 weeks after your first posting, and ive been watching and getting ideas and such and mainly been quiet but.
not only is this a kick a** time consuming restoration project you got going, but i live in new hampshire and it gives me alot of little nooks to check for rust, luckily i have none yet (car came from georgia) but its an awsome guideline for me! thanks alot!!
Posted by: VG_240 at 2:22 AM 11/11/2009
This is absolutely incredible, always inspires me when I see someone take the time to do a job right, the first time. Increbily thurough job here, and quality work!
Can't wait to find me a 240 and start working on my dream car...
Nice Stuff!
Post Title: Re: m tr4nch's restoration/build thread !! (VG_240)
Posted by: Lonismos14 at 6:38 AM 11/11/2009
Man you dont have one project car you have 2. You can build that escort to be one fast beast. I dont know if you knew, Get the 1.8 bpt deck the head bigger turbo you will be runnin low 13's. http://WWW.CORKSPORT.COM
Post Title:
Posted by: alloverdajoint at 5:39 PM 11/13/2009
Oh Gosh! FTMFW!
Post Title: FN-QR
Posted by: mcheddadi at 8:39 PM 11/13/2009
Post Title: Re: FN-QR (mcheddadi)
Posted by: 93sivliaUsdm at 10:13 AM 11/14/2009
i just read all 10 pages of this and man you have some fckin dedication to do this, you are a true inspiration to anyone that has a dream vehicle.
Posted by: anon563 at 4:43 PM 11/15/2009
updates plz!!!
