Nissan Forums / Infiniti Forums - NICOclub > 240SX Forum / 180SX Forum / Silvia Forum > V1 Short Shifter Install (Printable Version)
Post Title: V1 SHORT SHIFTER INSTALL
Posted by: idahotuner at 3:31 PM 1/20/2008
Installing this was a little confusing for me at first and i did alot of searching so i decided to write on here. for every one else.
I am installing new lower dust boot and the circuit sport short shifter, all the v1's are the same wether it is meagan racing for fidanza. so following these instructions should help with any of the other installs
things you will need:
V1 shifter kit
graphite lube
5mm allen wrench
C clip pliers
10mm socket w/ ratchet or phillips screw driver.
replacement lower dust boot. - you can get them at your local nissan dealership
1. You will need to remove your radio trim along with shift knob and shifter boot. ALSO MAKE SURE THE CAR IS IN NEUTRAL
2. you will end up with something that looks like this.
3. you will take all four 10mm bolt off holding upper dust boot. you can use the screw driver or socket and ratchet for this part.
when you remove it you will have this
4. next you need to remove the lower dust boot. you can cut it off since you will be installing a new one.
mine was torn a little already so it slid off easily.
5. no you will need to remove the C clip holding the short shifter in.
using these
you reach in. inserting each end of the pliers into each of the holes on the c clip and squeeze,
should be able to pull it out no problem
this is the c clip removed
6. now if you remembered to put your tranny in neutral you should be able to slide the stock shifter out.
this is what it looks like with out the shifter
7. now take the new shifter just the lower half. and lube up the plastic part on the bottom.
you can slide the new shifter into the hole now. with it angled back.
EDIT: farther down some posted the rest of the way to do it.......
Modified by idahotuner at 12:16 AM 9/3/2008
Post Title: Re: V1 SHORT SHIFTER INSTALL (idahotuner)
Posted by: tu_bryan at 6:46 PM 1/20/2008
great info, you make it seem so easy! kudos to you
Post Title: Re: V1 SHORT SHIFTER INSTALL (tu_bryan)
Posted by: White Comet at 8:34 PM 1/20/2008
glad u figured it out. see, it wasnt that bad
Post Title:
Posted by: StricNyne at 8:38 PM 1/20/2008
my ****ty short shifter had the plastic bushing fall in the ****in trans and it was like half of the size of the stocker
Post Title:
Posted by: le_ryan at 8:53 PM 1/20/2008
damn, very informative, good stuff man.
Post Title: Re: (vroom-chirp)
Posted by: idahotuner at 9:11 PM 1/20/2008
hey thanks guys.
took forever for me to figure out something to do a write up one. so i kidna gave up. but then when iwent to install this i couldnt find any instructions
so when i figured it out i figured i would do a write up
Post Title:
Posted by: duffman1278 at 9:25 PM 1/20/2008
Good work should come in handy soon for me. BTW, what'd you use to lube the bottom part?
How much stiffer does it feel than the OEM?
Edit: mybad, just read "graphite lube" hehe
Post Title: Re: (duffman1278)
Posted by: idahotuner at 9:37 PM 1/20/2008
it feels alot stiffer then stock. and alot tighter. but i think it will loosen up some when i fill the tranny with new fluid. which is one of the next things i will do. i might end up pulling the shifter back off to fill the transmission. s o i dont have to do it from under the car. but we will see.
i am worried about over filling it. s o if i new the correct amount. then i could do it trough the shifter hole and not worry about it.
Post Title:
Posted by: duffman1278 at 9:41 PM 1/20/2008
Just check the FSM for the correct amount. Thats what I did when I filled mine, drained it and put it in from the top.
Posted by: idahotuner at 9:46 PM 1/20/2008
i read it was 2 and half quarts
fsm?
Post Title:
Posted by: duffman1278 at 10:07 PM 1/20/2008
Factory Service Manual
Posted by: idahotuner at 10:11 PM 1/20/2008
were will i find that. i guess i will have to search.
Post Title:
Posted by: PMSing Chicken at 11:19 PM 1/20/2008
How's the vibration?
Post Title:
Posted by: mrgreeneyes at 2:26 AM 1/21/2008
um, not to be a negative nancy, but the aluminum collar is supposed to go UNDER the stock lower white ring, spacing the shifter HIGHER than stock, allowing the reduction in shifter movement.
so from the bottom, up:
aluminum spacer
wave washer
stock white lower ball pivot-y plastic ring
shifter ball
new white top ball pivot-y plastic ring
then the weird-arse top plate w/ retainers.
i used to have one of these and this is the proper way to do it. your way will leave the small shifter bushing about .5" too far into the trans, not letting the bushing interface with the trans fork piece, but rather letting the "wrist" of your lever make the contact.
Post Title: Re: (mrgreeneyes)
Posted by: White Comet at 3:29 AM 1/21/2008
^ good catch, i didnt even notice
Quote, originally posted by idahotuner »
look around a little. u can download them for free
Post Title: Re: (White Comet)
Posted by: D3stro at 6:10 AM 1/21/2008
Well done how-to. Simple and clean. Good work.
Post Title: Re: (D3stro)
Posted by: idahotuner at 7:32 AM 1/21/2008
Quote, originally posted by mrgreeneyes »
aluminum spacer
wave washer
shifter ball
it wouldn't have worked that way. i tried it. first off there is no wave washer.
the aluminum ring has to go on top, because the hole on the top plate hole isnt small enough to hold the shifter and every thing in. i can take it apart to show you.
the aluminum ring acts as a washer. from what i can tell. and if it was on the bottem everthing would not be held in place.
i dont have time to mess around wiht it today. but i will later. this week
Post Title:
Posted by: mrgreeneyes at 10:54 PM 1/21/2008
i had the exact same one so i KNOW it works the way i said... and the stock shifter has a wave washer.. just tryin to help ya out so when you go to make your first boosted shift, your lever doesnt snap/rattle like a mofo.
Posted by: mrgreeneyes at 10:57 PM 1/21/2008
that image shows EXACTLY what im saying
"collar" is the aluminum piece
Posted by: idahotuner at 11:02 PM 1/21/2008
yea i will pull it apart and see. what i can do. i just dont see how it will work doing it that way. but i will try it again.
Post Title: Re: (idahotuner)
Posted by: Quest4beasT at 1:18 AM 1/22/2008
Those washers are a pain in the a$$, i think they mess with the trany staying in reverse when engaged.
Post Title: Re: (Quest4beasT)
Posted by: White Comet at 7:37 AM 1/22/2008
greeneyes is right, i installed this exact piece as well on a friends car. im not really a fan of these shifters though, i'll stick to my b&m
Posted by: niemczykj at 7:51 AM 1/22/2008
WOAH, the metal bushing goes underneath!... u put that in first, then the plastic yellow piece with the metal cylinders, then the yellow plastic washer/bushing.
the metal goes on the bottom to make up for the higher position of the metal ball on the short throw.
Post Title: Re: (niemczykj)
Posted by: idahotuner at 8:18 AM 1/22/2008
Quote, originally posted by niemczykj »
its a work in progress. i am going to fix that part.
Posted by: s14tan at 8:50 PM 1/25/2008
Hope fully you get it right cause ima be using this.. I just got my Megan racing Shirt shifter.
Post Title: Re: (s14tan)
Posted by: idahotuner at 10:59 PM 1/25/2008
yea sunday i will fix it so settle down lol
Posted by: s14tan at 11:17 PM 1/25/2008
I need it tomorrow!!!! lol
Posted by: derrick113 at 8:01 AM 1/26/2008
great write up man. I had the same fidanza one in my car for about a week and got sick of it casue it felt weak and just didnt seem like it would last and got a B&M. i must say the b&m is a much better unit.
Post Title: Re: (derrick113)
Posted by: idahotuner at 1:27 PM 1/26/2008
yea i wish i had got the B&m shifter but i will make do.
Posted by: White Comet at 2:05 PM 1/26/2008
out of curiosity whats the price on one of these shifters? im curious to see how it compares to the b&m for pricing
Posted by: idahotuner at 2:46 PM 1/26/2008
the price is about 70 dollars for one of these compared to b&m for 250, or 230 which was the cheapest i found
Posted by: mrgreeneyes at 3:35 PM 1/26/2008
Quote, originally posted by White Comet »
haha, the ebay addict asks for ebay prices? lol...
Posted by: derrick113 at 3:36 PM 1/26/2008
yeah i wasnt bashing on ya man, i went through that same process and trying to tighten the nuts up on the plates was def no fun. Then i got the B&M and was very pleased with the shifting throws but d*mn that thing was noisey. I'm a little skeptical about getting the revised version now but who knows. Good luck with the rest of the build.
Posted by: White Comet at 6:47 PM 1/26/2008
i know lol but u forgot i'm lazy. i was also curious to see what he paid for it as opposed to what they're going for. imo i woudl have gone with teh b&m its more but worth it. i dont like these style short shifters so maybe i'm biased.
Quote, originally posted by derrick113 »
up until recently i wasnt even aware these things were making noise for some people. i might have gotten the revised version but my b&m doesnt make a sound
Post Title:
Posted by: hayai_240 at 11:07 PM 1/26/2008
I just paid $180 shipped for my B&M shifter. Cheapest i've found around is $210 shipped or so. Got mine through a vendor that sells B&M shifters on Honda-Tech. =)
Post Title: Re: (hayai_240)
Posted by: idahotuner at 11:49 PM 1/26/2008
Lucky you ^ i wanted to get my motor in my car and thought i need to or it would be easier to install it with the tranny out. and i wanted to save a little money but for 180 shipped that is a a good deal
Posted by: Didderson at 11:54 PM 1/26/2008
Yea Ben I just wanted to confirm once again that Greeneyes is correct. You'll be hurting your synchro slider shaft using the spacer in that position as of now.
I have the same style shifter. I love it, then again, I've never tried anything nicer. But I would reccoment you use the stock bushing that goes on the little ball. It's much nicer for fitment and won't break like the ones that usually come on these shifters.
Fix it or
Post Title: Re: (Didderson)
Posted by: s14tan at 12:56 AM 1/27/2008
I got my Megan Racing one for like 40
Posted by: noneckgus at 2:17 PM 3/14/2008
should it be stiff when its bearly put on or how could i take care of that
Posted by: MRNA at 4:10 PM 3/14/2008
Swell dude, very swell.
Post Title: Re: V1 SHORT SHIFTER INSTALL (MRNA)
Posted by: idahotuner at 8:27 PM 3/14/2008
Quote, originally posted by noneckgus »
lol need to be a little more descriptive dude?
Quote, originally posted by MRNA »
yeah i need to make corrections becasue the auluminum space goes under neath. but i have been busy.
Posted by: Razi at 8:29 PM 3/14/2008
My eyes hurt from the large and blurry pictures. But still a nice writeup.
Post Title: Re: V1 SHORT SHIFTER INSTALL (Razi)
Posted by: idahotuner at 9:06 PM 3/14/2008
lol i have my camera under control now lol
Posted by: s14tan at 10:19 AM 4/17/2008
Update with the right way to do it!!!
Post Title: Re: V1 SHORT SHIFTER INSTALL (s14tan)
Posted by: idahotuner at 11:08 AM 4/17/2008
im sorry i have been busy working with the motor to mess with updating this thread.
Posted by: B-TownSX at 1:58 PM 5/21/2008
Starting with an empty hole.
Put in the spacer.
Like so.
Insert wave washer.
Insert the plastic piece with the rods
Insert the lower half of the shifter, make sure you lube the white nipple.
Now the plastic retainer. If you have a gasket to cover the plastic parts insert now. I don't have it for some reason, but I'm doing without it :-/
Put on the bracket with the C on the bottom with with the nut facing down. Screw the top piece on and then put on the plastic cover. (Sorry forgot to take a pic in between the two steps.
Screw on the second half of the shifter.
Put on the dust boot and the metal bracket.
Then put the consul assembly back on fallowed by the knob.
Post Title:
Posted by: 240sxDrifter1126 at 4:22 PM 5/21/2008
thanks this is very helpfull
Post Title: Re: (240sxDrifter1126)
Posted by: idahotuner at 10:40 PM 5/21/2008
Quote, originally posted by B-TownSX »
Put in the spacer.
Like so.
Insert wave washer.
good job man finishing my write up. lol maybe we will both get half a special title now
Posted by: B-TownSX at 11:00 AM 5/22/2008
When I first put in my short shifter I did it the same way you did. Then I had to drop everything out for the sr swap. I just happened to run into this thread and decided to put the shifter back together out of curiosity. Now only if I can get my sr running...
Post Title: Re: V1 SHORT SHIFTER INSTALL (B-TownSX)
Posted by: bulletx at 2:39 AM 6/2/2008
Will this also work for nissan 180sx? I was just wondering if theres a differences b/w the nissan 240sx shifter to the nissan 180sx shifter. I bought the same V1 Short shifter and when I took out my old stock one on my 180sx, I noticed that it had a shorter end compared to the V1 short shifter and when I put the v1 s.shifter it had a bit of space on the ball joint part, but when I put back my stock shifter it fits perfectly... now is that normal or perhaps I bought the wrong type of V1 short shifter? here is the picture of what I bought.
http://photos1.hi5.com/0035/24...2.jpg
Post Title: Re: V1 SHORT SHIFTER INSTALL (bulletx)
Posted by: White Comet at 5:26 AM 6/2/2008
they should be the same depending on what year your 180sx is. if u have an sr the transmission is essentially the same, if u have a ca, i have no idea
Post Title: Re: V1 SHORT SHIFTER INSTALL (White Comet)
Posted by: ricebike at 8:19 AM 6/2/2008
nice pix-step by step!
from lookin at this, i now know i'm missing a wave washer & that plastic retainer thingie...
is it a good idea to put some blue thread lock on the bolts that hold the C-clamps down? from the past threads about this type of short shifter, i heard that sometimes they'll become loose n pop off!
Post Title: Re: V1 SHORT SHIFTER INSTALL (ricebike)
Posted by: idahotuner at 1:03 PM 6/2/2008
you could use thread lock. but it has locking washers so i dont really see the point.
Posted by: bulletx at 7:44 PM 6/2/2008
Awesome I figured everything out and it worked, thanks.
Posted by: thouster at 8:34 PM 6/2/2008
what's the part number for the lower dust boot?
Post Title: Re: V1 SHORT SHIFTER INSTALL (thouster)
Posted by: idahotuner at 10:13 PM 6/2/2008
i got one some where
Posted by: coolandy007 at 4:46 PM 6/13/2008
Thanks for this write up
Post Title:
Posted by: YellowStarS2000 at 11:14 AM 5/24/2009
I just bought a similar one but I can't seem to get the stock plastic retainer off the stock shifter. Did your kit come with one? The OEM shifter is too big on both sides to get the plastic retainer off
Post Title: Re: (YellowStarS2000)
Posted by: SleepyHB at 1:20 PM 5/24/2009
Quote, originally posted by YellowStarS2000 »
Good point, I don't know how BTown got it off the stock shifter either, but when I did this on my old hatch I just installed the short shifter without it, this is what what I did
Posted by: kc240guy at 2:48 PM 6/17/2009
The plastic piece with the rods will not come out. The rung that held the c clip in is a lip and the plastic piece won't go any further up. I'm only doing a short shifter because someone sawed off the shifter to make it a fake short shifter and got rid of the threads. When I went to put a greddy on, I found the old one was a clamp on knob. I guess I'm abandoning this and going to the junk yard.
