Nissan Forums / Infiniti Forums - NICOclub > Maxima Forum & I30 / I35 Forum > Nissan Maxima reliability (Please sign up if you're new) (Printable Version)
Post Title: Seeking information on Nissan Maxima reliability
Posted by: mkaresh at 6:08 PM 12/2/2006
I wanted more up-to-date auto reliability information that included actual repair rates. So in late 2005 I started conducting reliability research at TrueDelta.com. TrueDelta reports absolute repair rates that make the differences between cars much clearer. Results are updated four times a year, so it's possible to track cars closely as they age.
Thanks to the help of NICO and its members, for which I am very grateful, we've been able to provide results on many Nissan and Infiniti models. But we remain short of Maxima owners.
Participants simply report repairs the month after they occur on a one-page survey. When there are no repairs, they simply report an approximate odometer reading four times a year, at the end of each quarter.
To encourage participation, participants receive full access to all results, not just those for the Scion tC, free of charge.
For the details, and to sign up to help out:
Car reliability research
Modified by mkaresh at 8:08 AM 3/5/2009
Post Title: Re: Seeking information on Nissan Maxima reliability (mkaresh)
Posted by: Beancooker at 12:16 AM 12/3/2006
82k miles, and ABSOLUTELY NO PROBLEMS WHAT-SO-EVER!!! Maxima pwns! Will enroll when I have more time.
*EDIT.... Stepson changed out the alternator at 65K.
Post Title: Re: Seeking information on Nissan Maxima reliability (beancooker)
Posted by: mkaresh at 6:46 AM 12/3/2006
Thanks, I hope you will.
Post Title:
Posted by: AZhitman at 12:03 PM 12/12/2006
Guys, let's get some information in this database and help Mike with his research!
Thanks!
Post Title:
Posted by: MaximA32 at 3:09 PM 12/12/2006
I already enrolled.
Post Title:
Posted by: AZhitman at 8:15 AM 12/18/2006
Guys, I know we have more Maxima owners than this!!!
Post Title: Re: (AZhitman)
Posted by: maxhopper97 at 4:13 PM 12/18/2006
The link posted above returns as not valid.
I have a 97 Maxima that I have owned for over 3 and 1/2 years (approximately from 120k miles to the present 167k miles) and the only things I have done other that rutine maintenance (brakes, battery, wipers, oil changes, trans fluid, coolant) have been to replace the axles due to CV boots being torn...and that was a cost preventative measure as the reman axles with a lifetime warranty are just about $20-25 more than an OEM Nissan CV boot kit.
Post Title: Re: (maxhopper97)
Posted by: mkaresh at 4:16 PM 12/18/2006
Works for me right now. I wonder if the server was momentarily down. It doesn't happen often (that I know of), but it does happen.
Post Title: Re: (mkaresh)
Posted by: mkaresh at 10:23 AM 1/12/2007
Up to 96 owners, but spread thinly over the model years.
Posted by: generation2000 at 10:50 AM 1/12/2007
1996 i30 116k...no major problems so far soo good...fluid changes, wipers, etc basic stuff. torn cv boot. new flex pipe. knock sensor. evap valve. that has been about it.
Post Title: Re: (generation2000)
Posted by: IvoryJ30t at 4:19 PM 1/12/2007
we have two 4th gen maximas, if that says anything...
95 pebble beige gxe- 106k
95 black emerald gle- 195k
the gxe is pristine.
the gle has been with me for 2 months. it was abused, and is currently being rehabbed while daily driven.
since aquired at 69k, the only no-start was a bad starter on the gxe, that i fixed a few hours later. so 6 hours down out of 3 years is pretty good.
the gle recently had the #5 injector fail. it failed closed, and i drove the car to and from work [6 miles] for two days until the weekend, when i had time to fix it.
cost me $50 for a rebuilt injector [oem core] and a few hours of r&r for the upper intake manifold.
Modified by IvoryJ30t at 7:32 PM 1/12/2007
Post Title: Re: (IvoryJ30t)
Posted by: mkaresh at 12:16 PM 3/7/2007
Up to 115 owners. Model years halfway or more to the minimum: 1998, 2000, and 2004. A few others 40% of the way.
I haven't yet decided how old a car I'll collect data on. It'll depend on how far back I can go and still get valid results.
Posted by: 02maxSE at 3:15 PM 4/18/2007
i had a 97' se for three years. the only problems i ran across was replacing the cv boots(torn) and a valve cover gasket started to leak oil. other then that she ran up to 236k miles when she got totaled by a dodge ram! now i have 02' 90k no problems yet( knock on wood.)
Posted by: wrdominicas at 3:50 PM 4/29/2007
I own a 1999 maxima just bought it and the only thing that went wrong is the coils which the dealer replaced for me for free.. beside that car is running strong. but now i am starting to notice the right rear break caliper is sticking and making a loud humming noise at low speed should i be consern or should i have it checked out /???
Posted by: phildee at 9:04 AM 5/25/2007
I have a 2000 GXE w/ 5-speed stick - under 51,000 mi.
I'm in the process of searching for a non-Nissan new vehicle. Plenty of reports about the longevity of Maximas, but they aren't mine! Erratic idle, faulty injectors and harness, engine cut-offs in slow speed turns, noisy heater blower motor, and now a faulty Mass air flow sensor suggests a $580 fix. Quality of tech expertise
at my dealership is suspect. Nearest other dealer is 40 mi., and not sure the service would improve.
Reliable? Not in my experience, with so few miles!
Shouldda Got a Buick!
Post Title:
Posted by: NissanDriver84 at 10:58 AM 6/13/2007
I'm enrolled....2k3 I35 38k problems: Had to replace alternator & batt 6/2007
Post Title: Re: (NissanDriver84)
Posted by: Arcenal352 at 5:41 PM 6/19/2007
I have a 1991 Nissan Maxima SE (5 Speed) with 204K miles. I got it when it had 159K about a year ago. So far, I've has to replace the flex pipe and the catalytic converter due to exhaust leaks. Other than that, routine maintenance has kept it in top notch shape.
I did undergo a strange saga that included me hitting something on the road and cracking my front driver side rim. The wheel then fell off the car while I was travelling at around 70MpH. To prove how strong this car is, the only damage it suffered were a bent fender, a smashed fog light, a bent strut tower, and a ripped cv boot, which were all a breeze to replace.
Posted by: Amstel at 3:59 PM 6/22/2007
I have a 1998 I30T. Until I purchased this vehicle 7yrs ago I had only owned German cars up till that point (with the exception of a Range Rover)
I had always heard that Japanese cars were reliable and "never broke."
I have put 85k on this car. I have done nothing other than brakes and tires. I just recently did Cat back exhaust. This car has been phenominal.
While I work in Finance I do work in the Auto Industry (wholesale) on the side. Thus I am afforded the opportunity to drive almost any luxury car you can think of. I also see the problems and headaches people have with them.
At the end of the day I get back in the Infiniti (which is essentially a Maxima - same engine and body) and I'm happy.
For what it's worth I hope someone reads this and it sways them into buying a Nissan or Infiniti.
One other thing I forgot to mention is that Infiniti was great on the warranty (that was left on it) and recalls.
Posted by: Spectatohead at 9:54 PM 6/22/2007
I just enrolled. I don't come to the forum very often. I have a '97 Maxima SE - 5spd. I have owned it since Feb 2000 when it had 41,000 miles on it. Currently the odo is at 199,070. I had to have the transmission rebuilt at 136,000 or so and the air conditioning evaporator coil replaced in the summer of '05. Other than that just routine maintenance. I'm on my third clutch and second set of brake pads. Everything still works and it is way more comfortable than my wife's 2007 Outback Limited. Not to mention the fact that it gets better gas mileage than the Subaru, albeit, on premium. If the Subaru ends up being half as reliable as the Maxima it'll be a good car for her and in a couple years I can get my G37.
Post Title: Re: Seeking information on Nissan Maxima reliability (Spectatohead)
Posted by: carnal_c30 at 10:15 PM 6/23/2007
i just enrolled
I entered in my cars
1995 240sx (245k miles) owned it for 4 years and changed waterpump,thermostat,radiator, hoses
1997 Maxima (78k miles) owned it for 7 years and havent had a single problem
1996 Maxima (73k miles) 1 year axle boots, knock sensor, maf sensor cleaned
1998 Infiniti I30t (135k miles) owned for 1 year changed axle boots
1999 Infiniti Q45 (101k miles) owned for 2 months changed coil packs, knock sensors, o2 sensor...
Post Title: Re: Seeking information on Nissan Maxima reliability (carnal_c30)
Posted by: mkaresh at 1:18 PM 6/25/2007
Thanks, guys.
Just a couple of clarifications:
1. It's only possible to participate in the main reliability survey with cars you currently own, since this survey collects data going forward.
2. You can report repair histories for cars you no longer own, using a different on-site survey, but that survey is currently only set up for cars back to the 2002 model year. I'll be adding older years in the future, but probably won't go back many more.
Posted by: Larry578 at 7:32 PM 7/12/2007
Purchase a new 98 Maxima GXE 5 speed. Sold with with 200k for 4900.
Replaced one oxygen sensor and the CV Axles. the Started was making noise when I sold it. Other than that nothing. You must use 93 Octane always.
I purchased a 2002 SE one onwer with 28k to replace the 98. I had a Lexus ES 250 prior to the 98. The Nissan is just so much better.
Larry
Post Title: Re: Seeking information on Nissan Maxima reliability (Larry578)
Posted by: wrdominicas at 7:21 AM 7/13/2007
hi I read your treat and i have a 99 maxima gle love it. its got 110k milea and it feels brand new got a great deal 3500 dollars with trade in. first thing i did was to change the ignition coils because i did my reaserch lol:)
car runs new .. nissan maxima for ever baby lol
Posted by: jdonline at 11:18 AM 8/28/2007
My brother has a Maxima with 98K on it and I seriously doubt he's had many problems with in the years past. I believe he's only had to do routine maintenance other than once he had a little trouble with his engine. But he was able to get that fixed fairly easily.
[url= http://www.swengines.com/Engines/Nissan~motors/] Engine Locator[/url]
Mobile, Alabama
Posted by: chriskapinos at 4:00 PM 8/29/2007
maxima = indestructable.
Posted by: Thorzdad at 7:27 AM 8/31/2007
I'll be registering my 2k1 Maxima SE with over 250,000 miles shortly.
Post Title: Re: Seeking information on Nissan Maxima reliability (Thorzdad)
Posted by: mkaresh at 8:57 AM 8/31/2007
I need to think about how to handle cars with ultra-low and ultra-high odometer readings.
How does someone put that many miles on a car? About 40,000 per year?
Posted by: Tmreth at 11:09 AM 9/21/2007
We own a 1998 Maxima GLE that had 3 miles on the odometer when we drove it off the lot. It now has almost 153,000 miles on it. My husband is legally blind and doesn't drive, so this is our only vehicle and is used for everything. We've had a few problems over the last 9 years, but most of them have not been what I consider major. Expensive, but not major.
They are:
2 weeks - the Bose Radio system went out. Replaced under factory warranty.
59,000 - Transmission replaced under factory warranty
84,000 - December 03 - replaced steering rack/cv boot
97,000 - August 04 - replaced Evaporator in ac
June 06 - Replaced radiator. Blew up while driving in 6 lanes of heavy traffic. Quite an experience!
138,000 - December 06 - Replaced Valve Cover Gaskets and oil pressure switch/sending unit - sensor on right passenger airbag
152,000 - September 07 - Replaced ac compressor and electric fan motor.
Other than that, just general maintenance, tires and minor stuff.
It's a great car and I hope we continue to get good service out of it.
I hope this gives you the information you needed.
T'Mreth
Modified by Tmreth at 11:26 AM 9/21/2007
Post Title: Re: Seeking information on Nissan Maxima reliability (Tmreth)
Posted by: mkaresh at 1:28 PM 9/21/2007
Thanks for posting this info, it will help others. For my analysis, though, only data entered through the regular surveys can be included. The details are here:
Vehicle reliability research
Posted by: tightwork at 11:05 AM 10/7/2007
'06 Se... So far so good, Vibration in the steering wheel is driving me crazy, and when going down hill the car seems to drop itself into a lower gear by itself
Post Title: Re: Seeking information on Nissan Maxima reliability (tightwork)
Posted by: sunseeker888 at 9:57 AM 10/11/2007
2002 Max SE with 49,000 miles, This car has been a real good ride, no issues, and still runs/drives excellent. I just signed up, and look forward to joining in these discussions, nice forum, BTW. Anyway Someone mentioned that these maximas are usually solid for 300k miles... Thats amazing to me, many cars cannot even make 100k. My buddy owned a caddie from around 1997 that died with just under 75k miles. PATHETIC!!! Nissans are beast.
Posted by: Gimli G35 at 6:16 PM 10/13/2007
152k miles had since 1996 and it IS a 1995 , not many problems. minor engine maintenence
Only bad thing is that my dad got t-boned in it and it is totaled.
Post Title: Re: (phildee)
Posted by: etag at 8:27 AM 11/13/2007
I had the same problems with my 2000 maximawith auto. 6 cyc. I began reading the boards,
it all looked to be the MAF fix.
I took the MAF off and cleaned it with the cleaner I think its called crc cleaner.
let it dry for 15 min. and wow my car runs like new.
a $3.00 dollar can of spray. Just spray it down real good. it looks like a brass
pin inside the maf. The maf fix will take care of all the issues. im so happy now.
I went one step futher with all this. I cut off the end of the Maf. with my saw
the side with the 4 holes where it bolts up to the air box and sliped on a
high flow air filter. It will slip right over onto the maf tube. Its a perfect fit..
So now I gained more HP. took me a 30 min. for all the work.
Now it runs great I think I might change the muffler to a high flow.
You can really hear the air being sucked when you get down on it.
later I hope this helps all of you people.
Dont get tricked into repairs you dont need. Its the MAF!!!!!!!!!!!!!!!
later Ernie
Post Title: Re: (etag)
Posted by: maximaman at 3:08 PM 11/19/2007
you cut off the pin in the maf? what does that do? from what im told the pin gets hot and messures how much air passes thru by how cool the pin gets and compensates it with the equivelant fuel. or am i trippin?
Post Title: Re: (maximaman)
Posted by: maximaman at 3:10 PM 11/19/2007
disregard the last post. i read it wrong. you cut off the tube to the air filter.
Posted by: dante79 at 7:50 PM 11/21/2007
whats up i got a 95 maxima, just bought it thought and love it already.
its got 149k miles on it....no major repairs on it.
im looking to meet some people to talk about cars and possibly get some ideas on fixing the sunroof and a couple other minor things..
thanks for the help
Posted by: maxima93 at 6:59 PM 11/26/2007
my 93 maxima works fine with only 50k miles on it
Post Title: Re: Seeking information on Nissan Maxima reliability (maxima93)
Posted by: wrdominicas at 4:29 AM 11/27/2007
hi i got a 99 and i can tell you this cars are the best. no problems yet had it for a year now, synthetic oil changes and new drive belts gold package maxima love it.. i hope you take care of yours because it will take care of you..
Post Title: Re: Seeking information on Nissan Maxima reliability (wrdominicas)
Posted by: philosofik at 9:02 AM 12/1/2007
2000 Nissan Maxima - 113k Miles
Changed battery once, Service Engine Light was a problem but was resolved, made a humming noise when the wheel was straight and veered a bit off except on turns there was no noise - could have been the break pad
otherwise it always has been a reliable car. we have two (a 2007 also)
Post Title: Re: Seeking information on Nissan Maxima reliability (philosofik)
Posted by: HogMaxFan at 1:16 PM 12/3/2007
We have 2, and they both run great. Other than regular maintenance, 1 battery, 1 o2 sensor, and a wheel bearing, the wifes has been great!!! We've only had mine for about 2 months now, but so far it's been awesome.
Wife has a 2k SE with 127k on it,
I have a 2k3 GLE with 63k on it.
Maximas
Post Title: Re: Seeking information on Nissan Maxima reliability (HogMaxFan)
Posted by: mkaresh at 4:44 PM 12/3/2007
Thanks for the info.
But a reminder: only information submitted through TrueDelta's survey process can be used in the analysis. I don't yet have enough Maxima and I-Series owners participating to provide solid results.
Auto reliability research -- need more Maximas!
Posted by: Gman8990 at 4:28 PM 1/25/2008
i have a pretty Pearl Maxima 1999... No Problems WHATSOEVER!!!! well... the brakes squeak but they work as well as ever... 109K miles...
Posted by: lucasjsr at 9:51 PM 1/29/2008
I bought my 95 Maxima used. I bought a the Maxima because I had such great service from my 98 Altima I feel once I get this Max fixed up it will be as good or better a car. I totaled my Altima in December and am still working out a few final bugs on my Max but I'll let you know if I run into any repeated issues.
Post Title: Re: Seeking information on Nissan Maxima reliability (Gman8990)
Posted by: lucasjsr at 1:18 PM 1/30/2008
If the breaks are squealing did you check the pads? It sounds to me like you have a wear indicator telling you change pads or buy new rotors and pads. Please do not wait until they start grinding, it will be too late for just pads then. Brakes are great on cars. In fact almost too good they will work as long as nothing major breaks. I have seen cars where they were stopping on the metal backings. If you have good pads have you tried put the blue stuff on the back of the pads? Brakes squeak for three reasons I know of, 1 wear indicators or 2 resonance/vibrasion, 3 would be the wrong material pads which you either replace or live with. Listen to your car it is talking to you
Post Title: Re: Seeking information on Nissan Maxima reliability (lucasjsr)
Posted by: Gman8990 at 7:24 AM 2/2/2008
i know to listen... this is my 3rd maxima ('89 '95) and all of their brakes squeaked a little... it just happens... i tried changing pads and pretty much everything else... it just happens...
Posted by: lucasjsr at 7:36 AM 2/2/2008
Great, I just wanted to be sure you were being safe. I changed the rotors and pads on my Maxima recently and have not noticed any noise, but I will keep that in mind. Thanks and Have a Great Day. I will spend some more of my day chasing a low speed misfire in my Maxima.
Posted by: UzbMax97 at 8:22 PM 2/18/2008
Hi, just bought 97 Maxima gxe, a week ago, with 86000, so far I like it a lot,solid, great engine, I moved from 4cyll.(one thing is gas ). have some strange noise coming from cassete deck,and display showing cass. error,
and alarm signal looks like 2 sensitive, couple times went screaming like crazy... I'll try too keep posting any changes, hope won't be any
Posted by: Ops at 6:46 PM 2/25/2008
1995 Maxima SE (222890 + miles)
Ok where to start. I bought the car about a month ago (taxes) as is. I knew it had a few issues like needs new tires, oil check stuff like that BUT when I start the car in the cold i have to give it a llittle gas to get the the engine running. (*cold starts are hard without giving at least 5% gas) then once the idle levels off at .5 we are good to go.
After driving for apx 20 minutes when the temperature gage is at 50% (i guess normal all day running temp) it starts
the car will stall when i slow down or attempt to go at red light , giving it a lot of gas or just a little it would stall... I would have to put it in neutral just to keep the idle at 1 or 1.5 for a minute then let go of the gas. When the idle is steady at .5 and I put it in drive (with brakes still engaged) the car would die. I start up again (like a cold start) and get the idle to .5 then put it in reverse it would stall.. Finally after trying several times (being in the middle of an intersection!) she would move but struggle until we are over 30mph then we are good to go... that is... until the next red light.
This behavior would only happen once the engine is warmed up. The CEL stays on. the 1st mechanic's diagnostic test yielded the KS (ghost), and the O2 sensor. He was perplexed about the issue and finally ruled that its the ECM $400 and that I would need a new one.
Yarning for a second opinion I just put a H on my chest and handeled it by going to a local Nissan dealership (always expensive). They told me I need a new MAF and that's what's causing the engine to stall and hesitate during acceleration and deceleration. Now I trust their assessment being that its the dealership but I have done some research and a lot of people told me they've replaced the MAF and it did not correct the issue.
The dealership told me if the issue comes up I can just take it back (hopefully)
Other than that I have not had any issues with the vehicle. It rides smooth, accelerates (when she behaves) very fast and can corner better than my old Beretta. The rear defroster works better than my wifes 07 Cobalt SS. The heater/air blower is messed up a bit and I think its from the previous owner or something but it will not work on 1,2, or 3 speed only 4. The heat/air works fine, but sometimes it gets hot on max and I have to turn down the heat dial to make it conferable rather than just turning down the speed (missing that).
The horn is weak (not dominate)
the trunk and gas release latch works like a charm. All the windows roll up and down just fine accept sometimes when its cold the driver window will take a bit longer to completely come down. The power seat is still working.
I would still recommend Maxima's to friends but only if they have had their proper maintenance especially if its 200000+ miles.
Knowledge is Power! ... don't have it used against you...
http://opsec.spaces.live.com
Post Title: Re: Seeking information on Nissan Maxima reliability (Ops)
Posted by: lucasjsr at 9:39 PM 2/26/2008
i bought a Maxima that had set for a few years and ran horrible under 3000 rpm and idled very rough. I spent the LARGE $'s at the dealer and it helped for a minute. I ended up replacing the front O2 sensor and it fixed the Ck Eng lite bit not the drivability and rough idle. There is/or was a guy on Ebay sealing a complete set of injectors for $129 or best offer. I replaced the # 1,3,5 injectors (dealer claimes they replaced #4, #2 looked "newer" so I did not replace 2,4, or 6. It now runs starts idles and performs great. At the mileage you are tlaking I would recommend replacing the fuel filter, cleaning the Idle Air Control Valve, and replacing the injectors. With the injectors, plenum gasket and new fuel filter you should be around $150 (probably far less than just the cost to have the dealer techs lead you around to nowhere). If you decide to replace the injectors it is a lot easier than i thought. You have to get the 4 bolts off the back is the hardest part (I bought the factory manual on CD for $6 on Ebay. The 3 injectors under the plenum look like more work than is really is. Once you get the 4 back bolts off then the rest is easy to get to and is just a atter of unbolting and unplugging everything in the way. If you do get the injectors from the guy on Ebay be aware he ships slow (about 10 days) I hope this helps good luck.
Posted by: c5estrada at 7:24 PM 2/27/2008
I am new to this forum I currently own a 2002 Nissan Maxima GLE with 39000 miles The only problem I've had so far is Ox sensor when car had 1000 miles on it warped front rotors and replaced exhaust muffler and battery other then that car has been very good.
Posted by: Ops at 3:15 PM 2/28/2008
Yes it does help Lucasjsr!
I got my car back from the dealership repair shop and it works out just fine (for now) I thought about replacing the injectors but was deterred when I saw the price. I didn’t even think about getting them off eBay so I am going to try that. I know the fuel filter most likely needs to be replaced and I just got off the phone with AutoZone about to get the new one installed right after I finish typing this.
Now the injectors... would that be the true reason why the car would struggle below 3000 rpm or less than 25mph when I apply 100% gas? I am gonna play it safe and look into replacing the injectors... Just gotta save up for a hott minute... gas is expensive as it is already and that's eating away @ my budget.
Posted by: BDuck at 3:20 PM 2/28/2008
I am a second Maxima owner, this time a 1999 Crimson Blaze Maxima SE-L that I purchased used back in September 2004. It had 67,000 miles then, now has 125k miles. I have had problems with the Oxygen Sensor and EGR Valve, along with Carbon buildup, causing the check engine light to come on and running rough. I have been told that I need to replace both front axles because of the boot deteriorating. After hundreds of dollars to repair, replace and clean, I am very pleased with my Maxima, and would consider buying another one. Love the Bose Stereo and Moon Roof.
Post Title: Re: Seeking information on Nissan Maxima reliability (BDuck)
Posted by: spddemon at 9:43 AM 3/3/2008
91, 185,230 miles only replaced alternator and essentals. Rear ended sept 20,2006 by some jacka$$ not paying attention TOTALED .
Modified by spddemon at 6:27 AM 3/4/2008
Posted by: champride1 at 8:24 PM 3/3/2008
just enrolled
Post Title:
Posted by: .:Kevin:. at 8:48 PM 3/7/2008
Enrolled...Figured I'd make my first post something worthwhile.
Had a 95 SE that only needed one O2 sensor and And Alt(reman that was on it took a dump after 54k) Car had 95xxx miles on it when it was totaled.
02 hasn't had any problems yet.
Posted by: shannonk at 3:07 PM 3/18/2008
I'll try to enroll and provide my info:
I have a 1987 Maxima that I bought in 1997 in Florida with only 59,000 miles on it. It was a Florida car and in a garage up till then, almost mint condition, with dark window tint that's prevented any sun damage to the interior all the way up till now still.
I love the car, it still runs great with a little under 200K on it. I've never been stranded by it, except once when I ran it out of gas -my fault.
The engine burns no oil, the tranny has never given me any hassle.
Never had to do any major work to the engine other than keep the timing belt changed every 60Kmiles. The car has never overheated.
During the 10 years I've had it, I've replaced the suspension alll the way around. I just real recently replaced the front wheel bearings after hitting a pothole.
I also just dropped the gas tank to replace the fuel hoses and found zero rust on the tank.
The undercoating that the car came with back then was absolutely AWESOME! With keeping it washed regularly underneath during the winters here in New York, it's only just now developed some significant structural rust around the right rear suspension. Other than that, the undercoating from back then has really kept rust away. The only other spots are on the bottoms of the passenger doors.
The only maintenance items I've never done yet on the car are replacing the radiator, the steering rack, which is leaking on one side, and the power steering pump, which does not leak, but is loud. All three of these are the original parts and have still never failed.
The interior is in excellent shape, only my glove box is missing now that it got broken. Ieven have the original stereo in the car, which works great too.
I LOVE the ride of my car, even though it's starting to not look so good anymore. I've been in progress with prepping the body to repaint, and it's practically ready to be sprayed, but I've just run out of time and am going to have to move on to another ride. I hate the thought of this, because I can't imagine that another car could be any more reliable than this one has been.
Hope this helps your survey!
Post Title:
Posted by: pahaf at 3:44 PM 3/23/2008
i got a 1995 Nissan Maxima with 96k when i bought it and all i did/ am doing is changing the clutch and valve cover gasket
Posted by: hobbes24 at 12:36 PM 3/26/2008
03 Max SE
198,000 miles
slight noise when going from reverse to drive
no problems besides CD player skipping
Post Title:
Posted by: BlakMax99 at 5:22 PM 3/26/2008
99 max, 141233 mi, got it with 125874, since ownership had to replace a\c compressor, and regulator, and currently needs springs and shock ( i know why the springs, because the car shouldnt be so low w/o an actual lowering KIT ), axles (both), clutch (yes thank God, a 5-speed), flywheel. thats all for now will update later. almost forgot the driver window is moody sometimes it wont go down all the way and you have to curse at it for a while before it might listen and go down all the way
Modified by BlakMax99 at 5:34 PM 3/26/2008
Post Title:
Posted by: sixteenXnine at 1:17 PM 4/4/2008
I recently joined this forum, and my girlfriend and I both have '00 Maximas with 80k.
So yeah, I enrolled.
Posted by: turbobink at 9:57 AM 5/15/2008
99.5 SE L - purchased new in MAR 1999.
Currently ODO reads 93,640.7 mi.
Brake pads @ ~ 48,000 mi.
Coil packs (6) @ 60,000 mi. (as part of 60K service)
EGR system cleaning @ 60,000 mi. (as part of 60K service)
E-fan assembly @ ~ 77,000 mi.
Starter @ ~ 85,000 mi.
Rear Main Seal (RMS) @ 93, 640.7 mi.
Cam position sensor 'O' ring @ 93,520 mi.
A/C currently non-operational. Diagnosis is pending.
Bose CD player currently non-operational.
Valve cover gaskets are currently seeping.
Post Title:
Posted by: guitarpro_1st at 5:52 PM 5/26/2008
own a 92 maxima gxe and an se and love them both havnt had major problems with them yet and the se has 362k and the gxe has 210k
Posted by: Maximus7 at 10:52 PM 6/2/2008
I'v got an 01 Max SE with 94,000 miles that I have had for 4 years. Other than routine maintenance, I have replaced an O2 sensor, the MAF sensor (my bad; didn't clean the K&N for a long time), the speed sensor, and had the upper tie rod ends replaced all within the last 3 weeks. I love my car and it rides and runs like new.
If anybody is looking for new tires, I bought a set of Yokohama S-Drives from Tire Rack about 12,000 miles ago and they are the best tires I have owned (better that Michelin, Kuhmo, and Goodyear to name a few). Thanks for looking and I'll post more later.
Post Title: Re: Seeking information on Nissan Maxima reliability (Maximus7)
Posted by: mkaresh at 7:01 AM 6/3/2008
Are there upper and lower tie-rod ends?
There's a reason "powertrain sensors" are a whole separate category on the survey...
Posted by: Maximus7 at 7:53 AM 6/3/2008
I believe there is only 1 set of tie rod ends but don't quote me on that. I know that the dealer said I needed to replace my lower control arms, but my mechanic said that was a bunch of s**t, they were fine. Beware dealer's "advice" on repairs. I have found that having a trustworthy mechanic will save you thousands of dollars over the years. Unfortunately, I'm not educated enough about car repair to do much on my car myself. That would be the bomb.....
Posted by: mkaresh at 8:34 AM 6/3/2008
I was just teasing you. There should be only one set, so no "upper" and "lower."
With suspensions, wear is somewhat subjective. And shops looking to earn a buck will err on the side of caution.
Post Title: Re: Seeking information on Nissan Maxima reliability (Beancooker)
Posted by: gumgraff at 5:00 PM 6/3/2008
New to the forum, but happy to brag about my 97 Maxima SE. 160,000 miles. One starter, one clutch (5 speed) 2 sets of brake shoes and tires. Did replace the struts, but don't think they really needed replacing
Post Title: Re: Seeking information on Nissan Maxima reliability (gumgraff)
Posted by: joeltender at 6:56 PM 6/9/2008
New here, got a 97 se 5spd, bought it at 190000km (canadian miles)
Currently has 237xxxkm, replaced alternator, axle seal, rims&rubber and routine crap.
Great car.
would buy again, as long as it's stick
Posted by: thomasz at 7:25 PM 6/10/2008
Thanks for your advertising about Nissan Maxima
Posted by: reknab at 11:42 AM 6/28/2008
I have an '86 Maxima with 225k miles. I have had it parked for because the power steering line popped a leak. I had not started the engine for 6 months. Second tap on the ignition switch and it was going. The thing is immortal.
Posted by: RemdA at 7:33 AM 7/9/2008
Maxima 2000 5spd 112k-miles:
i just bought it... clutch is dead...
all the rest is brand new.
thank you.
Posted by: Ricky429 at 7:43 PM 7/9/2008
96 5spd maxx 175,xxx mi all i did was change the clutch :Exedy, intake filter:K&N, and spark plugs NGK G-power.... She runs like a champ
Posted by: sliveslar at 2:51 PM 7/21/2008
I am currently on my fourth Maxima. Obviously, I have gotten excellent service from the first three. In total, I have owned Maximas for 20 consecutive years.
My first was a 1982 Diesel. I bought the car with approximately 80 K. At about 170K, it was so rusty that it was no longer worth repairing. I never had any major problems with the car other than the rust. I think that was common on cars of that era. The car was extremely reliable, except that it was hard to start in cold weather (not unusual for older diesels). As I recall, it only stranded me once when the clutch failed. The biggest repair that I can recall was that the rack and pinion needed to be replaced. This was a result of not replacing torn boots.
My second was a 1987 wagon. I bought the car with approximately 85K. I kept that car until around 175K, at which point I sold it. It was still running strong, but it needed too many little things. The only problem with that car was that it had a very clunky transmission. I had the fluid changed regularly, and just learned to live with the clunks. It only left me stranded once, when the alternator failed.
My third was a 1997 GLE. I bought the car off lease with around 30K. I kept that car until around 137K, at which point it was totaled. I was rear- ended while waiting at a light, and the car sustained a bent frame. The crumple zone worked as it should, and everyone walked away with only whiplash (which was to be expected). The car was drivable after the accident, but my insurance co declared it a total loss the day after the accident. This car also had a clunky transmission. The only significant work was to replace the starter and a rear caliper.
My current car is a 2004 SE. I bought it with only 12K, and it currently has 38K. This car is a delight to drive, and I hope to have it for many years. So far, the car has had a couple of recalls -- one for the lower frame, which rusted prematurely, and the other for tires made in China.
My overall experience is that I have never had any major system failure and never had any fluid leaks. I never replaced any part of the drive train on any car. I service my cars regularly, and don't drive them too hard. As a result, they have been extremely reliable and safe.
Post Title: Re: Seeking information on Nissan Maxima reliability (RemdA)
Posted by: EGMaxmachine at 7:14 PM 7/29/2008
I have owned my 91 Maxima GXE since purchasing it new in July of 1991. Currently reaching the 90k mark. I always kept another car for work. Only 3 things that bugged it, the Bose radio,the rear driverside window lift broke, and just a bit of rust starting to show in the right rear wheel well by the mud guard. Only 1 recall, but it did not apply to my car. Though this was my first Maxima, my brother owned a 85 Maxima Wagon, 90 and 95 model years automatic sedans. All were very reliable as well.
Post Title: Re: Seeking information on Nissan Maxima reliability (EGMaxmachine)
Posted by: Dracolove at 8:04 AM 8/8/2008
Ive got a 95 maxima about 500 miles from 200k and ive got only a small valve cover gasket leak and i use Royal purple synthetic oil!
Post Title: Re: Seeking information on Nissan Maxima reliability (sliveslar)
Posted by: MinisterofDOOM at 8:08 AM 8/8/2008
Welcome to all the new members!
Quote, originally posted by sliveslar »
Very cool. I'd love to have one of those today!
Post Title: Re: Seeking information on Nissan Maxima reliability (MinisterofDOOM)
Posted by: sotobean23 at 3:34 PM 8/28/2008
What's up y'all
Just got a 2000 Maxima, 75250 miles. Car is in great shape...doesn't shake, smooth ride...hoping it last me a while. BTW, it's my first car.
Peace
Soto
Post Title: Re: Seeking information on Nissan Maxima reliability (sotobean23)
Posted by: mkaresh at 11:17 AM 8/31/2008
We did post results for the 1998, 2000, and 2001 recently. The repair rate for the 2000 appears worse than average, the other two about average. But the sample sizes are too small for precise results, and so these results are asterisked.
It does appear that once these cars get over 100,000 miles they start to require "more attention." But that's likely true with many cars.
With more participants, we can cover more model years and provide more precise results.
Posted by: HeidiW at 9:15 AM 9/3/2008
I have a 1999 Maxima GLE that has 227K miles on it! Other than the usual repairs and upkeep -- no problems what so ever!
In fact, I was just involved in a major rear end collision (mostly becasue the exhaust got crumpled, puncturing the floorboard) the insurance company wanted to total it -- I negotiated for more $$ based on blue book value and had it repaired because I know there's still alot of life left in it.
P.S. The Lexus ES 350 that hit me suffered 4 times as much damage!
Posted by: bigdaddydog21 at 11:33 AM 9/10/2008
91 max pearl white 200,666 mile runs great
Posted by: Brewbr at 6:11 PM 9/18/2008
I have a 2000 GLE with 169,700 miles on it now. It's been a pretty good car up until about a year ago and now I'm having some major problems. I just recently replaced the water pump (Major PITA) ! I've replaced the rotors and pads twice and the CV axles once in the last year and I still have a steering vibration @ around 60-65 mph, and a pretty violent steering vibration when braking from 50 mph and up. The higher the speed the more violent the vibration (felt through the steering wheel). Last but not least, I can hear a dull knocking sound from under the right front floor area of the car, normally when driving @ slower speeds and hitting normal bumps and cracks in the road........That's my two cents!
Posted by: hustlingtech at 6:30 PM 9/21/2008
i own four nissans.a 96 maxima,2004 altima,97 sentra,and a 97 pickup.I ha ven`t had any major problems,just maintainace.the most things I`ve had to replace are oil pan gaskets on the maxima and sentra,and I had to replace a few sensors,like the crank sensor,knock sensor,and coolant temp sensor on the maxima,oh did I mention the engine has 240,000 miles,and the engine is in great shape.I am I certified auto technican,and I maintance my own cars.iv`e known others that don`t take care of there cars and one thing brakes down after the next
Post Title: Re: Seeking information on Nissan Maxima reliability (Brewbr)
Posted by: hustlingtech at 6:37 PM 9/21/2008
i`m a auto tech and I bet you need to replace your lower control arm,or just the lower ball joint.they sell it together,because its easier to replace,you have to press out the old ball joint,witch takes longer.I had to replace mine and a lot of maximas its very common
Post Title:
Posted by: CT_Maxima at 11:55 AM 10/9/2008
I think this thread is about a prospective study, i.e. going forward in time.
However, I can attest to 18 years of ownership of a 3rd generation Maxima. Not trouble free, but much better than the domestic junk.
Post Title: Re: (CT_Maxima)
Posted by: zacj3 at 9:53 AM 10/16/2008
I got a 97 with 122,000 and it still runs great, minor engine work like replacing gaskets but nothing big.
Post Title: Re: (zacj3)
Posted by: SunnyTk at 12:17 PM 10/27/2008
I have a 96 max with 325,000km! still runs smooth, little start up trouble here and there...
Posted by: 03maroon at 9:26 AM 10/30/2008
I have an 03 Maxima SE. Bought it with 18K miles, now have 80K miles. Only problem so far is my clutch went out....today actually! But, other than that, amazing car!
Post Title: Re: Seeking information on Nissan Maxima reliability (03maroon)
Posted by: jspagna1 at 3:49 PM 11/4/2008
Have owned 2 Maximas, a 1992 SE new & sold with 126,000 miles no problems. Girl down the street bought it and still has it.
Bought a 2003 SE new and now has 58,000 miles. Replaced alternator and rear brake calipers. Other than that no problems. Love Nissans
Posted by: joeltender at 8:33 PM 11/16/2008
Got rid of 97 se, with 155000 miles
spent repair money on 03 tit ed 6spd, great car with 99000 miles.
Awesome car, only problem is that i wish I had made this decision earlier.
Posted by: chudu at 8:34 AM 11/20/2008
Don't know if you are still looking for reliability information on the Maxima but here goes. My 2000 Nissan Maxima (bought new) has 211,000 miles on it and so far, I have only had to replace an O2 sensor twice. That's it. It's the most amazing car ever.
Post Title: Re: Seeking information on Nissan Maxima reliability (chudu)
Posted by: mkaresh at 5:26 PM 11/20/2008
Always looking--this study has no end date, and releases new results every three months.
Only data submitted through the survey process can be included in the analysis. So owners are encouraged to sign up.
Posted by: Tumbler at 4:42 PM 11/21/2008
1995 Nissan Maxima 197,000 miles and still going
I am on my second clutch, I replaced the alternator and Battery @ 190,000 (both OEM) It has fairly new suspensions ( quick struts on all 4 corners)
New pads and rotors all around (ceramics)
And put in a new rear main at 167,000
Overall I love my Maxima it get great mileage, is a very roomy 4 door for its size
It has more interior room than my sisters much larger Taurus, I have heated seats I love heated seats in the winter, a sunroof and a 5 speed.
I love my Maxima its the best daily driver I have ever owned.
Posted by: apollo2015 at 5:35 PM 12/1/2008
Well I have just purchased a 2000 Maxima GLE. It didn't get a lot of use before so there is some humidity buildup in the fuel system. Nissan recommended simply running a couple of gas tanks through it and it should be fine.
Let's hope so!
I'll let you know what develops as it happens. So far, 103000km.
Post Title:
Posted by: 2ndchancemax at 7:39 AM 12/10/2008
1999 GLE and 2000 SE Maximas, 90,000miles and 112,000 miles resp. Coils, coils, coils! I should have known this. The 2000 SE now has major issues with all electronics inside the car (windows, locks, seats, sunroof) all just stopped working! When I removed one of the battery terminals it works for a while but as soon as I insert the key in the ignition and turn everything dies. I replaced the drive belts on the SE as well as the CV joints. The front suspension also seems to be going out as well as the clutch... As a former Camry owner (130,000+ miles) The only thing Ive had to replace on my old (rebuilt due to multiple wrecks) were the light bulbs! The timing belt and plugs etc were replaced as a matter of regular maintenance. I am highly disappointed in Nissans. They tend to run better (whenever they decide to run) but I would remember to get another Toyota in the future because of reliability reasons. not bashing the Nissans but just speaking the truth depending on my experience.
Post Title: Re: (2ndchancemax)
Posted by: Future240 at 1:15 PM 12/14/2008
1988 Maxima 125,638 miles, sat down for three years, gas tank replaced, ps steering replaced, needs a slight(hopefully AC fix) Lights needs to be replaced.
Post Title: Re: (Future240)
Posted by: MinisterofDOOM at 2:33 PM 12/14/2008
Nice! The late-80s Maximas look great, especially SEs with the spoiler.
Post Title:
Posted by: kirbaay at 11:17 PM 12/14/2008
i have a 96 maxima its still a fast car its my first one got it for free i added 4 10" kicker comps with a jl audio 500/1 amp and 2 48" 2 36" and 4 9" led underglow i will have to get some pictures out soon and some more stuff done to the car
Post Title: Re: newbe
Posted by: buzzsaw at 6:55 AM 1/11/2009
Just stumbled on to this thread. I was on because I own an 82 King cab and have just purchased (yesterday) an 05 maxima with 55K for the wife. How do I go about signing up? I probably won't have much to report for a while, at least I hope not.
Post Title: Re: newbe (buzzsaw)
Posted by: mkaresh at 9:56 PM 1/14/2009
You can sign up by going to the following page then clicking on one of the links to enroll:
Posted by: DrAg0oN at 8:59 AM 1/23/2009
Quote, originally posted by Ops »
Mine does the same thing, my mechanic told me itz the fuse that controls the fan's speed, the fuse is most likely burnt and can be easily replaced!
I hope dat helps
Post Title: Re: Seeking information on Nissan Maxima reliability (DrAg0oN)
Posted by: JaHuStLa88 at 2:42 AM 1/27/2009
Have a 95maxima GXE
Problem with 1st engine fried...or so sister tells me. She forgot to check her Radiator, it was leaking and the engine over heated. Car ended at 133k Stayed garaged for about 4 years, i got a new-er engine into it off a 2k not sure the trim, was told of a GXE go figure, it had 39k on it. car was totaled from the back so engine was all good. Only problem now i have is not to sure oil leak and Power Steering leak. Seals seem to not be put on right, (bad mechanic to this day didnt pay him nothing to put it in just the engine). Tranny kicks when car is not warm. Above all car still runs great with a few daily check ups
Posted by: nismofong at 9:38 PM 2/3/2009
I own a 2003 Maxima i've just hit the 110,000 mile mark and all is well...the only thing i had to replace due to failure was the O2 sensor.
Posted by: 96 maxima fan at 7:40 PM 2/12/2009
can anyone out there help? got a 96 max, have a hesitation problemwhen i give it gas or punch it it starts to do dat. now its hesitating at red lights or when i take off slow, its driving me nuts!!!!!!!!! brought it to the dealer for a diagnostic test and came back egr solinoid senser needs to be replaced! we have 3 maximas in da fam and one is sitting in da driveway doing nothing, but was doing pretty much the same thing if not worse. we love our maximas but we also invested $$$$$$$$ in to them my bro-n-law and i , we replaced maf,o2, egr valve, just went today and pick up egr(bpt) for it , tommorow going to get solinoid hopefully something good will come out of this!!if anybody has had a problem like this and has found da solution im all ears!!! maxamilion baby!
Post Title: Re: Seeking information on Nissan Maxima reliability (turbobink)
Posted by: 96 maxima fan at 7:53 PM 2/12/2009
tell me about the egr cleaning?
Posted by: 96 maxima fan at 8:03 PM 2/12/2009
i had that problem and what ended up happening was it lock on me on that same side and had to replace it drove home like dat wit da wheel locked da to buy a new tire. good luck!
Post Title: Re: Seeking information on Nissan Maxima reliability (96 maxima fan)
Posted by: mkaresh at 8:06 AM 3/5/2009
We have updated results for the Nissan Maxima. In terms of successful repair trips per 100 cars per year:
1998: 138, about average, 142,800 average odometer
2000: 180, worse than average, 106,000 average odometer
2001: 132, average, 103,000 average odometer
2002: 37, better than average, 77,500 average odometer
Sample sizes were small, even very small, so these results are asterisked and only visible to members on the site. With more participants, it's likely that the reported repair rate for the 2000 would be lower. There are far fewer average miles on the 2002s in the survey, which explains some of the difference.
A big thanks to everyone who has been helping. We'll have further updates in May, August, and November. With more participants, we could provide more precise information and cover all model years.
We now have a separate results page for each model that includes the results for competitors. The page for the Nissan Maxima:
Nissan Maxima reliability comparisons
Posted by: mnmaxman at 6:01 PM 3/25/2009
I currently own 3 Maxima's, all very reliable.
1996 SE purchased in 2005 for a college student with 165k. This car was solid as a rock when I purchased it. Great acceleration and stopped straight and true. Has been a solid car with no major repairs. It has seen low use since I have owned it and it is currently around 175k.
1998 GLE - My daily driver. I love this car! Purchased in 2004 at 65k, this car now has 157k and counting. NO major problems. Just routine maintenance.
2000 GLE - Wife's car. Purchased in 2003 at 25k and today reading 140k. This car has had more issues than the others. The A/C has been repaired 2X and the cooling fans were replaced in 2008. No other major repairs. Drivetrain is still smooth.
I am a happy Maxima owner.
Also recently owned a 1996 GXE for 6 months as a spare car. It had some rust around the wheels and the front fenders but otherwise was a solid car that had great acceleration and had no problem sitting outside and starting in -20 deg MN weather!
Post Title:
Posted by: motionbleu at 10:43 PM 3/29/2009
2001 maxima...gold...117k. its a beautiful thing
Posted by: Street1 at 8:19 PM 4/8/2009
96' maxima own here...it's late i'll update tommorow some time..
Post Title:
Posted by: PapaTom at 9:49 PM 4/22/2009
I had a 92 that I bought off the original owner at 185k miles. Ran GREAT! A/C cold and Heater Hot. All power accessories work and the only thing I had to do was put on new tires and main seal. this guy kept the interior in better shape than 08 Maxima. I gave the 92 to my sister and she loves it. Awesome car.
Posted by: grndpounder95 at 1:57 PM 4/23/2009
i own a 95 maxima se
other than gen. maitinence the starter and trans were changed at 153K
it still runs very good now at 156K
Posted by: mkaresh at 9:41 AM 6/2/2009
We have updated results for the Maxima and I30/I35 to include owner experiences through March 2009. In terms of successful repair trips per 100 cars per year:
2002: 46, better than average
2001: 123, about average
2000: 130, about average
1998: 134, better than average
1997: 62, better than average
1996: 97, better than average
Sample sizes range from small to just a couple short of the minimum for a full result, so these are all just partial results. Largest sample sizes for the 1998, 2000, and 2001, so those are probably the most accurate.
A big thanks to AZhitman, this forum, and everyone who has been helping. We'll have further updates in August and November. With more participants, we could provide more precise information and cover all model years.
Posted by: mike23g at 1:44 PM 6/13/2009
IVE OWNED A 1986 MAXIMA GLE FOR 10 YRS IT HAD 120K BEFORE I LET IT GO HOW STUPID OF ME. I CURENTLY OWN A 1997 MAXIMA WITH 154K AND SHE IS IN BETTER THAN GREAT SHAPE, NEVER HAD ANY MAJOR PROBLEMS WITH HER. I ALSO OWN A 2007 MAXIMA SL WITH 14K ON IT, I SPEND MORE TIME DRIVING THE 97 THAN THE 07. MAXIMA'S ARE GREAT CARS!
Posted by: Zick at 2:23 PM 6/22/2009
1998 Maxima SE, automatic bought new. 88k miles (our weekend car) Car is in excellent condition.
Only non- scheduled repairs was CV boots & re-pack
I am now fighting a P0400 issue, but may have figured it out. Found carbon in EGR Temp sensor tube & EGR solenoid stopped up, repair pending. Use to run 89 octane but switched to 87 five yrs ago
I do regular maintenance as suggested. Started using Amsoil or Mobil 1 & Wix oil filter, K&N air filter after warranty period. I run a bottle of RXP to clean system every 4 months. Lucas fuel additive when I remember.
The SE sport tune suspension runs & drives GREAT @ 80mph with good mpg
Previous Nissans- 1971 240Z, 1977 280Z, 1981 280ZX. None were babied and held up very well.
My wife bought a Pulsar that I hated- Body & interior held up good but had NO Power & constant emission problems.
Post Title:
Posted by: oolatec at 12:44 PM 7/15/2009
2004 Maxima SE bought new in 2003 coming up on 49,000 miles.
Other than routine maintenance:
New alternator
and a ton of TSBs.
I've been one of the lucky ones. My tranny is fine, and I don't, as of yet, have the timing chain tensioner problem.
Currently dealing with some CEL codes, but that's all due to my headers.
Post Title: Re: (oolatec)
Posted by: mkaresh at 8:17 AM 9/3/2009
We have updated results for the Maxima and I30/I35 to include owner experiences through June 2009. In terms of successful repair trips per 100 cars per year:
2003: 18, very small sample size, actual repair rate likely higher but still better than average
2002: 39, better than average, small sample size
2001: 125, about average, marginal sample size, average odometer now over 100k
2000: 108, about average, marginal sample size
1998: 110, better than average, adequate sample size
1997: 104, better than average, small sample size
1996: 162, better than average, small sample size
A big thanks to AZHitman, this forum, and everyone who has been helping. We'll have further updates in November and February. With more participants, we could provide more precise information and cover all model years.
Posted by: zerotap at 2:05 PM 9/15/2009
I own a 93 Altima GXE I bought at 132K. I just had the 150K service done, new battery, alternator etc. Nothing major for a car with this many miles. The engine still runs strong, just passed emitions with flying colors. Only thing I need to do now is replace some gaskets ( 3 of em for under $300.00 with parts and labor ) and find a spedometer. My front sensor did go out so I replaced that at 158K, but the spedometer is still broken, so I am looking into where to find one online I can buy for around $100. Anyone got any tips on what part # I need and what not ?
Post Title: Re: Seeking information on Nissan Maxima reliability (zerotap)
Posted by: road_warrior05 at 3:39 PM 10/16/2009
I just got a '94 Maxima a few days ago with 161K miles. It runs really good, but I have to get a new switch for the window, and the is a "bump" noise from the front-passenger side whenever I hit a bump or I'm goin slow.
Posted by: sureshot37743 at 5:17 PM 10/17/2009
i have a 1996 maxima gle 5 spd. it has over 354,000 miles on it. i got it from a friend that needed a house payment for $600.00. man what a deal on a great car. only thing i've done to it is added a cold air intake kit and a performance module. i drive it everyday. and it does not live easy. it takes the punishment and begs for more. it has an insatiable hunger for hondas though. not one of them is safe in this town. hehehe.
