Can some one explain to me what happened here?
RCA
I did an "error check" for my C drive and when I restarted my laptop the process began. Mid way through I received that message, and I was wondering
- What is a bad cluster?- What causes it to go bad?- What type of file is it?- What are the repercussions of having this file replaced/go bad?
Thanks for your help guys
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
A cluster is not a file, but a physical division of the drive's storage space.
Bad clusters don't function correctly and thus can't be read or written to correctly. Looks like Windows was able to recover the affected file and move it somewhere else (physically) on the disk.
You can't fix bad clusters. They're gone for good. But you can partition the hard drive around them so that they're no longer an issue. Unfortunately, oftentimes bad clusters means further hard drive failures are imminent.
RCA
::sigh::
Do you know what that file is/does?Is it important?
This is the first time I have seen this, and I usually "error check" once a month or so. How long does it take for my HDD to crash?
Infinitiguy19
If the file was recoved sucessfully then I would'nt worry about it.
Might want to try this if your worried about it: http://www.grc.com/sr/spinrite.htm
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
sysevent.evt is a "crash log." It's not a critical thing but, as Paul said, even if it was it wouldn't be a big deal since Windows was able to recover it. The crash log is just there for you to examine if you want to find out specifics about a windows crash (not necessarily related to that hard drive failure...could be left over from an old windows crash).
It's hard to say how long the drive has left.
Infinitiguy19
Actually most if not all new drives use a thing called S.M.A.R.T to tell you how long the HD has left.
http://en.wakopedia.org/wiki/S.M.A.R.T.
But all drives with moving parts can fail ANYTIME, Wonder if SSD is any better?
ka24boos13t
Car: 91 300zx tt
I've heard that it's longevity is quite high, especially when compared to HDD. Many are quoting 10+ years now and much more depending on the situation. In a server environment where a majority of the activity is reading data, the longevity is considerably higher since there is only limitations on write cycles (not that this is a huge issue, more on that in a second). Hardware failure is really a non issue and given that current SSD have error correction, I don't see why one should really expect less than what it is "rated" for. The whole system is really superior by simplicity, no need to spin up/down the platters, no moving heads etc. A lot of the earlier complaints were about the amount of write cycles allowed but what most people didn't realize is that it's rated for that many write cycles to EACH CELL. An efficient controller would spread out the writes across as many cells as possible, virtually eliminating this problem for the majority of peoples use for an SSD.
I'm concerned about the ability to obtain data once one does crash though. So far it's been extremely hard if not right near impossible to recover data off a fried SSD. Most consumers are to ignorant and worry free to back up there data. Although 90% of the time it's not a terribly big deal since they don't have anything extremely important stored on their HDD but when they do, and it crashes, it's usually possible to get the important data back no matter if it was a bad sector/cluster/partition or a hardware failure. Hopefully it will teach some people a lesson.
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
basically what they said, the computer is pretty much fixing it self.
two years ago my laptop did the same thing, then actually 3 days ago the harddrive finally failed. so now im stuck to the desktop lol.
well anyways, expect your harddrive to go anytime, basically back up all important data, but if you want still use the computer till she drops.
sorry if this doesnt make sense its kinda late here.
chemao
Car: 2019 Tesla Model 3 - preordered
1997V2 AM General H1 with 6.6L Duramax (LML) running biodiesel swap
2015 Lexus CT200H
2003 Hummer H2 with 6.5L Detroit Turbodiesel swap
Avoid the solid state drives for now; you'll regret if you don't. They have a tendency to lose data.
rsagen
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
google Ubuntu and install it on your computer, it works great for harddrives that are failing.
i use it now.
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
chemao wrote:Avoid the solid state drives for now; you'll regret if you don't. They have a tendency to lose data.
Avoid cheap SS drives...the Intel ones have a lot less issues.
stebo0728
Car: 1993 300ZX, White, T-Top
There is actually a hybrid drive available now, it has a SSD portion, as well as magnetic platters. It intelligently stores commonly accessed data on the SSD portion for faster access, while keeping more mundane data on the platters. Works well without going completely SSD, cheaper too.
AppleBonker
FWIW, I've got five and have had no issues with any of them. Three are OCZ and two are Intel. I believe there were issues when the technology was brand new, but I think nearly all of the drives on the market now are probably ok. The benefit when buying higher priced drives is in the performance. Also, capacity is costly on SSD, so if you need the storage space, SSD is probably not ideal.
